[ RK3288 ROM ] Pipo P7 Android 4.4.4 multi-window custom root firmware (2015/01/21)
2015/01/24 - 14:41
Gents,
This is a Multi-Window build for Pipo P7 ;-)
P7 by Oma build v2.1
udate 17.03.2015: kernel #825 (change kernel/resource in folder rockdev/Images before flash)
– stock recovery 4.4.0
– CrewRKTablets recovery CWM 6.0.5.1
– kernel #700
– 4 GB internal storage
– multi-window 2.0
– init.d support
– Dateimanager HD (Root)
– Nova Launcher
How multi-window works.
Hints:
– to prettify the build use
Xposed Framework > Starter Pack
– Oma -
084-2.jpgImage Enlarger
 Oma-RK32-P7-build-v2.1-21.01.2015.pngImage Enlarger
  TWRP_CrewRKTablets_v2.1_1-3.jpgImage Enlarger
TuscaniV6
TuscaniV6
2015/01/26 - 15:33
Thank you very much for this rom OMA, everything runs nicely on this one.
There is only a single flaw on this rom that gets really annoying, and that's the internal storage being used as the default write disk without the ability to switch to external SD for application data.
Do you think you can add this feature with a small new update for this rom?.
Thank you again for your hard work on all the devices.
Update:
I managed to swap the default mount points specified in fstab.rk30board.bootmode.emmc and fstab.rk30board.bootmode.unknown found in boot.img by extracting and rebuilding the kernel image.
The problem now is that the REAL SD card is named "Nand Flash" and the REAL Nand flash is now named "SD Card". I'm unable to rename these mount points anywhere, if you could give some help in achieving this or include this feature in a small new update, that would be awesome.
2015/01/26 - 15:50
You have about 4 GB internal storage and about 10 GB internal sdcard. This should be more than enough. Why do you like to use the slower medium?
TuscaniV6
2015/01/26 - 16:03
It's a 64GB Samsung EVO with 48MB/s transfer rate, wich is fast enough for me. I dont really mind waiting about 2~5 seconds longer between transfers if i am able to store 5 times more data.
10GB is a joke if you plan on install heavy games on the device, wich is the main reason i bought this tablet (powerful GPU + relatively low resolution screen), movies are also very heavy in size depending on the quality.
There are many reasons to need more than 10Gb of storage. Android apps keep getting bigger and bigger as time passes.
Google probably tought the same at the earlier stages of android, when HTC G1 had 56Mb of app storage and the later allmighty Nexus One had just 156mb.
Either way, do you think that what i'm trying to do is possible, or at least somewhat easy to achieve?, it's just renaming things as they should be.
2015/01/26 - 16:26
Doesn't matter what is advertised for the sdcard. In fact (if the tab has eMMC) you will get a performance as shown in attached pic.
Anyway, I do not recommend to touch the mounting. You will face some untraceable errors after a while.
Simply install Exposed Framework and use the module obb on SD.
v1.0_emmc_durchsatz.pngImage Enlarger
pajohnx
2015/03/12 - 13:52
I can't make it work. I installed TWRP with flashify. Can i install the rom via TWRP? What file should i flash? "system.img"??
2015/03/12 - 19:33
No. The way is to use the included Flash-Tool.
pajohnx
2015/03/12 - 20:34
I can't make it work.It keeps popping "config file failed etc".(windows 7 sp1,greek language).Any ideas?
2015/03/12 - 21:06
Hm, copy the pack to the root folder (c:) and make sure there are no greek letters in the path.
pajohnx
2015/03/12 - 21:15
I'll try asap and i'll let you know. Thanks...
pajohnx
2015/03/12 - 23:37
Wow, it worked that way... I'll try the rom and i'll get back to you.... In case i want to go back to stock rom (saved it in ext sd) i should do it via TWRP (restore from sd etc)? Thank you again....
pajohnx
2015/03/13 - 00:25
Something minor so far. When i charge the tablet it keeps powering on by itself! I've tried shutting it down with various ways but it always power on when i connect the charger or the usb cable... Strange....
2015/03/13 - 06:15
This just reflects the current way of life. The majority of tabs comes with an "always on strategy". The only "possibility" to power-off is when you are away from any cable.
The stock firmware is available on the Pipo homepage.
flanders
2015/03/16 - 21:20
Thank you Oma7144 for this rom, it looks great!
Edit: never mind, I flashed everything including RK3288 loader uboot and except cwm and TWRP and then TWRP and parameter. It's working fine so far
But kodi (xbmc) does not work at all :'(
I've tried with 14.1 and latest rc 14.2
Is kodi working for anyone on this device?
________
I just flashed it following your instructions attached, but I don't know if I did it correctly
First I did lowerformat and flashed everything that was checked by default in androidtool (everything except RK3288 loader uboot, TWRP and CWM)
 Then I flashed just parameter and TWRP
Did I do it correctly?  Should I flash the rk3288 loader uboot file too?
2015/03/17 - 18:23
When youi did it acc. to instructions yyou should be fine.
61 Guest(s)
Devices in use: Desktop (53), Phone (8)
