[ RK3288 ROM ] Pipo P4 3G/Wifi Lolipop 5.1.1 custom root firmware (2015/11/15)
by Oma7144
bloodgnome
Forum Posts: 11
Thanks Received: 4
2015/11/16 - 11:07
Hi everyone,
Oma7144 seems to be very busy so that we don't have a thread for his Pipo P4 Lolipop Rom release that you already can find on the main page:
http://crewrktablets.arctablet.com/?p=5721
So far i tested it and its a nice and fast rom.
Bugs i found so far:
- Xposed doesn't work (i tried every build up to Version 78)
- Some games have a strange high frequency audio noise. Try Hungry Shark Evolution (its free) for example. You can say that sound is unusable with that games (its just loud noise). Other Games work fine (soundwise)...
Other than that its a great rom. Thanks Oma7144.
Oh maybe one more thing: Oma7144 wrote latest Busybox but 1.22 isn't the latest 1.24 is the latest since 2 weeks, playstore is also updated to version 6 on 2015/11/13 and services too 🙂 just saying, not a big thing to update those for everybody.
P4 by Oma LP 5.1.1 build v1.0
P4_v1.0_01
Lollipop has landed
on Pipo P4 ;-)
– stock recovery 5.0.0
– CrewRKTablets recovery
TWRP 2.8.4.0
– sekernel #70 preempt 22 Sep 2015
– Reboot Menue
build v1.0
instructions are included in the download pack
not working:
- GPS
hints:
– Oma's favourite apps for LP (install via apk installer)
The following users say thank you to bloodgnome for this useful post:
admin, jastaz23
jastaz23
Forum Posts: 28
2015/11/16 - 14:05
Hi Blood! do you have a 6gb parameter file, can you upload that too? thanks!
bloodgnome
Forum Posts: 11
Thanks Received: 4
2015/11/16 - 16:39
Yes I made one myself.
I will upload it later when I'm back home 🙂
bloodgnome
Forum Posts: 11
Thanks Received: 4
2015/11/16 - 19:40
Here is the 6gb parameter file:
http://www.mediafire.com/download/42ftv65rqm55ky2/parameter
Enjoy.
I hope Xposed will work soon...
jastaz23
jastaz23
Forum Posts: 28
2015/11/17 - 01:09
Thanks!
2015/11/22 - 19:51
Hungry Shark Evolution will show this behaviour on all my tabs with LP builds. So, it is more an issue of the app.
4 GB internal storage for installation of apps is enough. One will need the remaining internal storage (P4 has only 16 GB eMMC) for apps like Gameloft which will store its game data (obb files) on the internal storage.
Xposed will not work on the customized RK framework. However, I guess it is widely untested on RK devices. Talk to rovo89 if he is able/willing to deal with this.
Btw Xposed works fine on our CM12.1 build, but almost unnecessary 😉
- Oma-
bloodgnome
Forum Posts: 11
Thanks Received: 4
2015/11/26 - 14:09
Hi Oma7144,
thanks for your reply.
About the Audio Problem:
Not only Hungry Shark has this. PewDiePies's game has it. Some Telltale Games have it. Using these Games on other Lolipop devices works fine. I'll try to test that games on my R89 TV-Box running 5.1.1 Lolipop (Wasser). Since it also a RK3288 Device it should show if this is a Rockchip Problem.
About xposed:
I will write rovo89. I need xposed mainly for Youtube adaway.
Greetings.
hawkdown77
2015/12/15 - 19:35
My netflix dont work 5.1.1 p4
Only stay loading....
2015/12/29 - 17:00
Can somebody pls check if netflix works with this widevine engine? http://crewrktablets.arctablet.com/?wpfb_dl=2765
v1.1_46-2.pngImage Enlargerv1.1_47-2.pngImage Enlarger
keteden666
2016/01/04 - 18:53
I've checked it and Netflix still doesn't work. It is always stuck in loading screen.
2016/01/04 - 18:55
Can I have a logcat log from this situation?
keteden666
2016/01/04 - 18:58
How can I do that? I have no idea what logcat log is 😛
50 Guest(s)
Devices in use: Desktop (47), Phone (3)
tdomnic024
otismaibe
Tsuna77
docentik2006
nechey
