Gents,
This is a Lollipop 5.1.1 build for Pipo P1 😉
– stock recovery 5.0.0
– sekernel #24 preempt 16 Jun 2015
– Reboot Menue
hints:
– Oma's favourite apps for LP
– Oma -
2014/08/02
hello every one.
here is a home made kernel for Pipo-p1-3g
link https://www.4shared.com/archive/fPC6sdDEce/P1-3G_kernel_by_mussonero-enab.html
completely newly written 3g driver in kernel .
test and it is working on the Pipo-p1-3g with Pipo enabled 3G version of P1 LP 5.1.1 ..
<6>[ 0.871272] [3g_modem]: Enter pipo_p1_3g
<7>[ 0.871387] of_get_named_gpio_flags exited with status 232
<6>[ 0.871397] [3g_modem]: modem_platdata_parse_dt: get property: 3G,power_gpio = 232.
<7>[ 0.871412] of_get_named_gpio_flags exited with status 245
<6>[ 0.871421] [3g_modem]: modem_platdata_parse_dt: get property: 3G,en_gpio = 245.
<6>[ 0.871434] [3g_modem]: initing 3g_modem
<6>[ 0.871454] [3g_modem]: by mussonero
<7>[ 0.871484] _gpio_request: gpio-0 (3g_modem_power_reset) status -16
<6>[ 0.871494] [3g_modem]: 3G-Modem device registered.
<6>[ 3.527566] usb 3-1: New USB device found, idVendor=0e8d, idProduct=00a7
<6>[ 3.527581] usb 3-1: New USB device strings: Mfr=9, Product=10, SerialNumber=0
<6>[ 3.527591] usb 3-1: Product: Product
<6>[ 3.527599] usb 3-1: Manufacturer: MediaTek Inc
<6>[ 3.528655] cdc_ether 3-1:1.0 usb0: register 'cdc_ether' at usb-ff540000.usb-1, CDC Ethernet Device, 02:00:ff:aa:aa:aa
<6>[ 3.529022] option 3-1:1.2: GSM modem (1-port) converter detected
<6>[ 3.529195] usb 3-1: GSM modem (1-port) converter now attached to ttyUSB0
<6>[ 3.529485] option 3-1:1.3: GSM modem (1-port) converter detected
<6>[ 3.529615] usb 3-1: GSM modem (1-port) converter now attached to ttyUSB1
<6>[ 3.529897] option 3-1:1.4: GSM modem (1-port) converter detected
<6>[ 3.530031] usb 3-1: GSM modem (1-port) converter now attached to ttyUSB2
<6>[ 3.530318] option 3-1:1.5: GSM modem (1-port) converter detected
<6>[ 3.530451] usb 3-1: GSM modem (1-port) converter now attached to ttyUSB3
Best Regards
The following users say thank you to mussonero1 for this useful post:
Hi mussonero1 and welcome to arctablet!
Thanks you for sharing, which indicates a strong community 🙂
Can you please post a screenshot of settings/about the tab? I would like to publish your great work on our blog.
2014/08/02
Here is some info and screen-shots from -oma- build 5.1.1
https://www.4shared.com/archive/eMDHfkglba/Screenshots_P1-3G_using_Oma_Lo.html
https://www.4shared.com/office/DvAhgPF7ce/P1-3G_using_Oma_Lolipop_Logcat.html
Best regards.
Thanks! Kernel #150 by mussonero is now in the archive: http://crewrktablets.arctablet.com/?wpfb_dl=2623
Update blog: http://crewrktablets.arctablet.com/?p=5449
Can somebody pls test our CM12.1 build on Pipo P1?
Build v1.2.1: http://www.arctablet.com/blog/forum/rk3288-entwicklung-und-customroms-development-and-croms/cm12-1-has-landed-on-rk3288/
Use Kernel #150 by mussonero and change kernel and resource in folder rockdev/Image before flash: http://crewrktablets.arctablet.com/?wpfb_dl=2623
Edit: choose TWRP 2048 x 1536
First boot is in TWRP: do a factory reset and install this P1 model fix: http://crewrktablets.arctablet.com/?wpfb_dl=2626
Reboot system and wait 3 minutes.
2014/08/02
I managed to do more test with my privet build.
here is some screen shots .
To get the sim working properly ,you need to remove the SIM PIN LOCK first, before putting the SIM in the tablet it should be unlocked, seems there is a bug with the Stk sim app 😕 ..
APNS names ,it still need to be fix it too (( carrier names)) and SPN too ,,, init.rc should include the right service to call the poppe deamon i suppose,,So far it is working nice with kernel. same thing with OMA LOLIPOP 5.1.1 the kernel it is working nice.
Best Regards
Great. I noticed a lot of downloads without any feedback. So, I guess all is fine 😉
A great tool to assist is PPP Widget: http://www.draisberghof.de/android/pppwidget2.html
Other question: is there still this with the Pipo kernel reported bug?
Enr1988 said
Flashed with Op build, No graphical glitch but the same screen off(pmu) bug...
For the Pipo P9 kernel (other PMU, Ricoh) we see still fragments of the driver in the kernel and a lot of creepy data in the dtb.
2013/04/16
Can somebody pls test our CM12.1 build on Pipo P1?Use Kernel #150 by mussonero and change kernel and resource in folder rockdev/Image before flash: http://crewrktablets.arctablet.com/?wpfb_dl=2623
Edit: Use TWRP 1920 x 1200 from this pack. To load it into RKAndroidTool just click on the empty box behind TWRP.
i'll test it later, hope that all working good! Thx Oma and Mussonero
Tried... The same behavior..screen don't turn on after go off
Thank you for testing! Any ideas mussonero1?
2014/08/02
relay dunno, but something so strange in the log,, why i can not see the DisplayPowerController service in logcat ?_?..
No wonder you can not turn your screen on,,,, maybe have bad boot.img or another build not from OMA.
look at my logcat from OMA Build Lolipop 5.1.1 from post .number 4 ..
Best Regards
2014/08/02
mussonero1 said
final fixed 3G , Phone calls , Baseband and GPS <<< 😉 with new kernel mod for Pipo P1 3G model with Lolipop 5.1.1.
Sorry, I was a few days abroad. Did I miss something here?
2014/08/02
Hi
No you did not miss much , just finished building my privet CM12.1 for "rk3288" pipo p1-3g here some screen shots link cm12.1 screen shots and I was wondering if I can post the release link here .
Cameras, 3G modem,GPS,VPU for video decoding ,HW acceleration, Bluetooth ,Wif and moded recovery TWRP.
Currently Online: shauman
6 Guest(s)
Devices in use: Desktop (5), Tablet (2)
rkg2303
sergey-tax
houseofcandy
duviauxi
benevento89
pablovs
