[ RK3288 ROM ] Pipo P1 LP 5.0.2 custom root firmware (2015/06/12)
2015/08/07 - 20:10
In the Pipo forum there was a thread showing a 5.1.1 build (around 30 June). Maybe somebody can provide this test build or at least the kernel.
zulfurion
2015/08/08 - 10:26
the site pipo.cn is so slow it is unusable for me.
would it be possible to upload the firmware file to give me a 5.1.1 link please?
2015/08/08 - 19:54
Ok, here is the P1 kernel #24, preempt 16 Jun 2015. Pls test with the build from post #1. Change kernel and resource in folder rockdev/Image before flash.
Enr1988
Enr1988
Forum Posts: 34
Thanks Received: 6
2015/08/08 - 20:26
Flashed with Op build, No graphical glitch but the same screen off(pmu) bug...
No working wifi..
2015/08/08 - 20:34
Ok, then let's test the kernel with our AOSP build.
Sawbones
Forum Posts: 29
2015/08/08 - 21:22
Is there a git of the AOSP build somewhere?  I would really like to try modifying it to see if I could get it working with a different model.
Thanks!
-SB
Enr1988
Forum Posts: 34
Thanks Received: 6
2015/08/09 - 09:59
even with aosp build there is screen off bug
mussonero1
Forum Posts: 350
Thanks Received: 70
2015/08/15 - 00:58
hello every one.
here is a home made kernel for Pipo-p1-3g
link https://www.4shared.com/archive/fPC6sdDEce/P1-3G_kernel_by_mussonero-enab.html
completely newly written 3g driver in kernel .
test and it is working on the Pipo-p1-3g with Pipo enabled 3G version of P1 LP 5.1.1 ..
Download dmesg.txt
Download logcat.txt
<6>[ 0.871272] [3g_modem]: Enter pipo_p1_3g
<7>[ 0.871387] of_get_named_gpio_flags exited with status 232
<6>[ 0.871397] [3g_modem]: modem_platdata_parse_dt: get property: 3G,power_gpio = 232.
<7>[ 0.871412] of_get_named_gpio_flags exited with status 245
<6>[ 0.871421] [3g_modem]: modem_platdata_parse_dt: get property: 3G,en_gpio = 245.
<6>[ 0.871434] [3g_modem]: initing 3g_modem
<6>[ 0.871454] [3g_modem]: by mussonero
<7>[ 0.871484] _gpio_request: gpio-0 (3g_modem_power_reset) status -16
<6>[ 0.871494] [3g_modem]: 3G-Modem device registered.
<6>[ 3.527566] usb 3-1: New USB device found, idVendor=0e8d, idProduct=00a7
<6>[ 3.527581] usb 3-1: New USB device strings: Mfr=9, Product=10, SerialNumber=0
<6>[ 3.527591] usb 3-1: Product: Product
<6>[ 3.527599] usb 3-1: Manufacturer: MediaTek Inc
<6>[ 3.528655] cdc_ether 3-1:1.0 usb0: register 'cdc_ether' at usb-ff540000.usb-1, CDC Ethernet Device, 02:00:ff:aa:aa:aa
<6>[ 3.529022] option 3-1:1.2: GSM modem (1-port) converter detected
<6>[ 3.529195] usb 3-1: GSM modem (1-port) converter now attached to ttyUSB0
<6>[ 3.529485] option 3-1:1.3: GSM modem (1-port) converter detected
<6>[ 3.529615] usb 3-1: GSM modem (1-port) converter now attached to ttyUSB1
<6>[ 3.529897] option 3-1:1.4: GSM modem (1-port) converter detected
<6>[ 3.530031] usb 3-1: GSM modem (1-port) converter now attached to ttyUSB2
<6>[ 3.530318] option 3-1:1.5: GSM modem (1-port) converter detected
<6>[ 3.530451] usb 3-1: GSM modem (1-port) converter now attached to ttyUSB3
Best Regards
The following users say thank you to mussonero1 for this useful post:
2015/08/15 - 08:12
So I guess it will work in the 5.0.2 build, too.
Currently Online: hoholms
46 Guest(s)
Devices in use: Desktop (41), Phone (6)
hoholms
rammaiden
iongeorge411@gmail.com
legrandhommer
mindra
xstouf
