Gents,
just playing around ... can I have a dmesg log from the running build?
– stock recovery 5.0.0
– CrewRKTablets recovery TWRP 2.8.3.0
– sekernel #130 preempt 6 Mar 2015
– Reboot Menue
not working:
- GPS
hints:
- Oma's farourite apps for LP (install via apk installer)
– Oma -
Enr1988Per aspera ad astra, we rock the Tablets !
2013/04/16
Thank!! i'll test it tomorrow 🙂
Edit. Dmesg.log attached
Edit2. Unfortunally like the P9 build, even this one suffer of the screen Off problem. Hope you can solve it.
Also the keyboard don't work good like on P9 build based on 5.1.1
The following users say thank you to Enr1988 for this useful post:
Thank your for the log!
Seems an issue with the PMU chip, which is in this case an ACT8846.
Can you pls check with this app? Start with full wake lock.
2013/04/16
Thank your for the log!Seems an issue with the PMU chip, which is in this case an ACT8846.
Ok, i need to reflash the rim because returned to KK. Can I flash P9 5.1.1 and kernel/source then try this app and get log? Or you need a log from this 5.0.2?
2013/04/16
Best is with the 5.0.2 build.When you have the time can you also load the tab full, unplug all cable and run a video for about 2 hours? I'd like to see a screenshot of settings/battery of this screnario.
Many thanks in anticipation!
Ok, reflashed 5.0.2 than starts the app you suggest and tap Full wake lock... After this what I should do? Because never used this app before now.
Also later I'll post battery status after playing movie..
Just check if the tab comes back when the screen is off.
2013/04/16
Just check if the tab comes back when the screen is off.- Oma -
Alter 1min even with this app the screen don't come back.
even when charging and turns off the screen for 2-3 minutes is necessary to manually restart.
Maybe it's necessary a kernel "adjustments".
Don't know what I can do, later after charge post battery stat
2013/04/16
#define RICOH619_BATTERY_VERSION "RICOH619_BATTERY_VERSION: 2014.05.06
So the latest PMU driver dated 2014.05.06 doesn't work for our and for Pipo's kernel. Maybe we can find some older driver for a 3.10.49 kernel.
Currently the forum software gets an update, so your post is most likely not visible. But to answer your question, go back to KK for now.
2015/06/08
Thank you!#define RICOH619_BATTERY_VERSION "RICOH619_BATTERY_VERSION: 2014.05.06
Which kernel version are you/pipo using for this build? Is there full VPU/Mali support already at this point?
Just curious. I've been watching various public kernel sources for RK3288 for some time now. Obviously I have not seen the VPU or Mali sources, though 🙁
Thanks and cheers!
-SB
Not really. PMU is still the major issue on all tabs.
68 Guest(s)
Devices in use: Desktop (63), Phone (5)
revoltown
tdomnic024
otismaibe
Tsuna77
docentik2006
