CM12.1 has landed on Pipo P1 3G/Wifi 😉
CrewRKTablets RK32 P1 CM12.1 build v1.1
CrewRKTablets RK32 P1 CM12.1 build v1.0
– homebrew kernel mussonero #102
– 3G support
– GPS support
– HDMI support
– multi user
not working:
hints:
– use RKBatchTool to install, in TWRP do factory reset and wipe data and internal_sd
– Oma's favourite apps for LP
– Xposed framework test pack
further hints to improve UI feeling:
- disable all animation scales in developer options,
- use Nova launcher and set animation/scroll to “faster than light” and
- enable Entropy Fixer with value 256
Special thanks to mussonero !
2013/10/27
Have not been able to get this to install. everything seems to go well, it boots to TWRP? After reboot i get into an endless loop of the TWRP start up screen. Any suggestions. Boot loader problem?? The other 5.1.1 loads fine gut no GPS which is important to me.
Thanks for you help.
2014/08/02
davel1232
after installing it with RKBatchTool , it should boot in TWRP ,from TWRP you should do first a normal factory wipe-out, after try redo an advance wipe-out for the following partitions Data and the Internal_sd "internal storage" ,
Best regards.
2012/11/17
Hallo @all,
Installed this fine ROM on my Pipo P1-Wlan and i must say, it is the best rom ever.
Everything is working well and fast.
No problems so far.
Only little bug is that i can't wake up the tablet, when it's in sleepmode after a while.
I don't know if this bug is normal, because the rom is for 3G-Version.
But i'am using auto-screenon-app from Dougi Hsu and now it's working perfectly.
Thank you oma and mussonero for your good work!
Regards
Daniel
2014/08/02
davel1232 said
Has anyone tried earphones on this rom? They dont work for me.
Thanks for reporting this, i am personally did not test them before the release ,as i use a bluetooth for headset .
But keep in mind this is a home-brew kernel with no source from the manufacture,,but any bugs reports from the users side are always welcome.
Best regards.
2015/09/25
Hi Mussonero.
Fine job.
Every thing seems to work, ... Exept earphones.
When you plug them, noting happens, sound continue with the small tablet HP.
And as DADOS, tablet wont awake after going to sleep mode...
Do you think it could be possible to fix ?
Another thing, coz i like to install a lot of stuff, could offrer the option to extend the app partition to 6 or 8 GIGs (as riley managed to)
Thanks a lot for your job.
Regards
Serge.
2014/08/02
raoulito10
Do you have P1-3g or P1-wifi ? in any case could you upload the last_kmsg log ,and it should be taken after you had the sleep of dead issue.
For earphones, i will try my best to look for a solution. thanks for reporting it again.
Regarding the data partition resizing ,it is possible ,maybe i will post how-to later on, or you could try link2sd apps "" personally i have never tried but it should work too ""
Best regards.
We had some server issues and maybe lost some posts. Pls upload it again. Thank you!
Use this tool: http://forum.xda-developers.com/showthread.php?t=1944776
2015/09/25
I had a nice sunny sunday with family. 🙂
Here is my file last_kmsg.txt (attached file)
The crash happens every time.
I does not happen while charging, an nor while usb is connected.
I tried to shut of networks (other than wifi and bluetooth) because i own a wifi version, changed nothing.
I have tu push reset button 10 seconds, the tablet accepts to boot.
If you can manage to fix this and the earphones issue, i would be very happy !!!
2014/08/02
raoulito10 said
I had a nice sunny sunday with family. 🙂Here is my file last_kmsg.txt (attached file)
Thanks for the log, but are you sure it is " last_kms ", for me it seems corrupted 😐 ..
In any case on my p1-3g i did not get any issue so far, maybe the best way for you is installing p1-wifi kernel for now , until i send You another one to test.
For P1-wifi kernels you can look at the kernels archive http://crewrktablets.arctablet.com/?page_id=4055
Look for p1 kernels released in 2015 .
Best regards
btw:
even on the stock p1-3g Kernel has an issues with earphone 😉 tested last night, you can hear the sound from the earphone and at same time from the internal tablet speakers O_o , so the sound plays in both ways loool ... che bello.
64 Guest(s)
Devices in use: Desktop (59), Phone (5)
tdomnic024
otismaibe
Tsuna77
docentik2006
nechey
