Ok, thank you for feedback! We cannot simulate this issue here on our hardware. Go back to a working firmware for the moment.
We will try to find a solution anyway.
Anybody else here with this issue?
One quick idea, pls check: https://mega.nz/#!vI0gnQRS!e3Fr0PLlJMMVLMly9wq7j2o9npw9mCybFo1pcLZf3lE
piqPer aspera ad astra, we rock the Tablets !
2017/06/12
One quick idea, pls check: https://mega.nz/#!vI0gnQRS!e3Fr0PLlJMMVLMly9wq7j2o9npw9mCybFo1pcLZf3lE- Oma -Â Â
Working
Ok, build v1.4 running now with this kernel? Anything else to noticed?
To doublecheck, pls install this build: http://crewrktablets.arctablet.com/?wpfb_dl=3047
Just change kernel/resource from post #32 in folder rockdev/Image before flash.
2014/08/02
piq said
Menu mobile network settings not available. Â
The fast and easy way to know if you have Pipo P1 3G , one need to provide logs DMESG of the current running kernel.
2017/06/12
kernel
To doublecheck, pls install this build: http://crewrktablets.arctablet.com/?wpfb_dl=3047Just change kernel/resource from post #32 in folder rockdev/Image before flash.
- Oma -Â Â
 Also not available
Settings menue not available? Other issue like SOD or scrolling current?
Ok. Pls flash kernel/resource of build v1.2.
64 Guest(s)
Devices in use: Desktop (54), Phone (10)
