2014/08/02
piq said
I did everything according to the instructions. Did not help.The same screen.
v 1.3 not working
If you have manged to flash version V1.2 , then it is same for V1.3.
Please wait for other users if they have the same issue, because that dose not make any sense for me.
Note:
If you really managed to flash V1.2 then you can replace the system from 1.2 with V1.3 and try if it boot.
Good luck
Hm, sorry. Try this for the moment: https://mega.nz/#!DUMzFSpK!7eRDE5C8He5j0KH7jsD_c8ybewvCC0KZGij4GJUg1vA
2017/06/12
Ok, one step back. I'd like to understand the formatting issue first.Please use the v1.4 build as is. Do a clean install, incl. Lower Format.
In TWRP do Format Data (confirm by typing Yes) and then a Fatory Reset.
I do everything according to the instructions. The firmware is installed, I go to TWRP click the format data, yes and appears
Curious. Same when using v1.2 pack as is?
2017/06/12
Curious. Same when using v1.2 pack as is?- Oma -
Kernel 1.2 works, 1.3 is not. Now, I installed cm 13, then 14 v1.4 clicked the data format, the formatting passed, but when loading an endless logo.
If press again the data format, it displays a blue screen (unable to mount storage).
What do you mean by kernel 1.2 works?
The kernel has two parts: kernel.img and its database, which is in resource.img. Please do not mix up!
I'd like to know if the firmware pack v1.2 will give you this formatting issue?
2017/06/12
The kernel has two parts: kernel.img and its database, which is in resource.img. Please do not mix up!I'd like to know if the firmware pack v1.2 will give you this formatting issue?
If you replace the kernel of any firmware version with the 1.2 kernel, even without changing the resource.img, then everything will be formatted and the system will boot.
resource.img almost the same.
Firmware 1.2 does not give a blue screen, the system boots normally without errors.
67 Guest(s)
Devices in use: Desktop (59), Phone (8)
