Gents,
LineAgeOS 14.1 has landed on Pipo P1 😉
mussonero RK32 P1 3G LineAgeOS 14.1 build v1.4 - 14.06.2017 & 3G off
mussonero RK32 P1 3G LineAgeOS 14.1 build v1.3 - 10.06.2017 & 3G off
mussonero RK32 P1 3G LineAgeOS 14.1 build v1.2 - 24.05.2017 & 3G on
mussonero RK32 P1 3G LineAgeOS 14.1 build v1.1 - 01.05.2017 & 3G off
mussonero RK32 P1 LineAgeOS 14.1 build v1.0 - 09.04.2017
– recovery TWRP 3.0.2.0
– homebrew sekernel @ 1.85 GHz
– sleep of death fix
– unified storage
– LineAgeOS su, su-binary
installation:
hints:
– developer options: enable by tapping 5 times onto build number (settings/about the tab)
– screenshots: enable in settings/buttons/power menue
– advanced reboot: enable in settings/developer options
– root access: enable in settings/developer options (apps and adb)
– local terminal: enable in settings/developer options
– better UI performance: set all animation scales to 0 in settings/developer options
Build by mussonero
– Oma -
Update post #1 with build v1.2 🙂
2015/11/27
This bricked my tablet. Unable to mount or format data from recovery. When booted to system, it asks me for decryption password. When I again reboot to recovery, again unable to mount or format data (invalid argument).
Tried lower format, still the same. Any idea how to make my device usable again?
2014/08/02
giaur500 said
Ok, now I remember what to do. Advanced format not working from some reason, need to press Wipe button (strange, this should be the same).Rom works fine. As always, SOD is there. Also, GPS not working and charging indicator when device is off always shows 0%
Hi Giaur, Could you please test these all together "kernel, resource and the bootloader"
Please report back if you managed to flash them/
https://mega.nz/#!Oc13GRzL!UlmzN8uNfvZ7LmXunobcXYQoK2iOTNAQDO_0O8VZA7A
Note;
Gps Should work fine , if you have set the gps to high in device location menu .
2014/08/02
giaur500
Could you please also test this for SOD , thanks in advance.
https://mega.nz/#!fBchDJDL!HnQsFpEor87mwEFtx9xZf6_C9PHB0XJq5LE1AjTY1vI
2015/11/27
Thanks for support. I think I can make some tests next week. Shame your updates are not TWRP compatible (yep, I think I have already mentioned this, sorry for being snippy).
Regarding to gps - no matter what, my tablet will always see 0 satellites (0 in view and 0 in use). So I guess agps not working too in my case.
Charging whlie powered off - as I can see, charger indicator always starts from 0%, then grows and never reaches 100%, is it expected behaviour? It rather should start from current battery level.
piqPer aspera ad astra, we rock the Tablets !
2014/08/02
piq said
Could you please try flashing this kernel with V1.3
2014/08/02
piq said
mussonero1Installed. Writes Unable to mount storage.No OS Installed!
hangs on the logo.
OK, after flashing the firmware, did you managed to go into recovery TRWP.
If you have managed to go into recovery, please try format the data partition first, after do a wipe for factory reset.
2014/08/02
piq said
Ok , now it is clear picture.
you need to do low format first.
after flash again the firmware
Make sure you have all the checkbox selected before flashing or low format.
Press 1, and after wait for 10 sec.
Press 2 to flash the firmware.
Good luck
note:
use all the files inside the zip file, like in the picture.
73 Guest(s)
Devices in use: Desktop (64), Phone (8), Tablet (1)
hakhiem
jenom
kfwacky
fer30
culo1
dfrt
