[ RK3288 ROM ] Insignia Flex Elite LP 5.0.2 custom root firmware (2015/08/08)
106
2016/08/18 - 17:38
What kind of special cable should that be? Do you have the tab?
Astralix
Germany
Forum Posts: 27
Thanks Received: 7
107
2016/08/18 - 17:40
Unfortunately no reply till yet...
However, I personally had one USB cable that had contact problems and while trying to short the flash, hold the tablet, press the buttons, there is a lot of movement... So yes, trying a different cable is always a good idea.
However it is only a rare chance for the logged problem of incorrectly identified eMMC / NAND... But yes, try a different cable, just to be sure.
I report back if I have news for you guys.
buzzly
Forum Posts: 14
108
2016/08/18 - 22:05
I am far from being an expert.   In fact, I am stuck with a problem already which I'll post it for help later.
I only recently acquired 3 used Flex Elite tab (just tab, no cable) for my kids.   My  understanding is that the original supplied USB cable is an OTG-USB cable.    That's why I was GUESSING an OTG-USB cable may be needed for certain communication/connection.
109
2016/08/18 - 22:54
I don't know if the kernel supports host functionallity. If so one need an USB-OTG cable to use an USB-stick or USB-mouse.
Nothing to do with the unability to write something on this Foresee eMMC chip.
Flashing on other rk32boards (Samsung, Toshiba chips here) normally looks like this:
15:39:21 915 AndroidTool v2.3.0.0 start run
15:40:37 472 Layer:Test Device Start
15:40:37 488 Layer:Test Device Success
15:40:37 504 Layer: Download parameter...
15:40:37 579 Layer: Download misc...
15:40:37 638 Layer: Download resource...
15:40:37 809 Layer: Download kernel...
15:40:38 488 Layer: Download boot...
15:40:38 693 Layer: Download recovery...
15:40:39 011 Layer: Download system...
15:44:18 868 Layer: RunProc is ending, ret=1
15:46:36 903 Layer:Test Device Start
15:46:36 930 Layer:Test Device Success
15:46:36 955 Layer: Download parameter...
15:46:37 025 Layer: Download misc...
15:46:37 073 Layer: Download resource...
15:46:37 146 Layer: Download kernel...
15:46:37 848 Layer: Download TWRP_1920x1200_CrewRKTablets_v3.0...
15:46:38 360 Layer: RunProc is ending, ret=1
15:55:39 291 Layer:Test Device Start
15:55:39 296 Layer:Test Device Success
15:55:39 315 Layer: Download parameter...
15:55:39 415 Layer: Download resource...
15:55:39 573 Layer: Download kernel...
15:55:40 592 Layer: RunProc is ending, ret=1
Can you pls test the integrity of the Foresee chip: https://play.google.com/store/apps/details?id=net.vinagre.android.emmc_check&hl=de
v1.0_emmc.pngImage Enlargerv1.0_emmc_check.pngImage Enlarger
buzzly
Forum Posts: 14
110
2016/08/18 - 23:22
Did the eMMC Brickbug Check
"No Brickbug.   Sane chip"
Check Memory.    Almost 7 minutes long     "Test Passed"
So this is completely over my head.
111
2016/08/19 - 16:55
Ok, thanks!
Is there the same firmware on all three tabs? Can you pls post a screenshot of settings/about the tab?
112
2016/08/22 - 19:30
graphdarnell said
I was able to enter MaskRom Mode at last.
Here is a loader, which should support the Foresee eMMC. Pls flash with RKAndroidTool.
graphdarnell
graphdarnell
Forum Posts: 41
113
2016/08/23 - 01:32
Could you tell me if this is a revised version of the 2.19 loader?  The version I used initially was 2.19.07, enclosed in the original rom package.  This one bears the designation 2.19.04, which normally means it's older.  But so long as it's different, I'll be willing to give it a try.  Can you confirm?   Thank you.
Edit:  flashed 2.19.04 successfully.  The rest is same old....  "test device fail"...LF stuck at 0%.  From what I can gather, people have had no problems flashing RK3288-based devices with RKAndroidTool, just not with Foresee eMMcs?
Astralix
Germany
Forum Posts: 27
Thanks Received: 7
114
2016/08/23 - 06:55
I requested this loader from RK for you. They confirmed that it is certified for this type of eMMC. Just give it a try and please report if works.
The following users say thank you to Astralix for this useful post:
graphdarnell
graphdarnell
Forum Posts: 41
115
2016/08/23 - 08:27
Thanks for sending in the request.  As said above, I flashed the specific loader (2.19.04) fine in MaskRom Mode.  But thereafter when I tried to flash the parameters along with the kernel in "Found One Loader Device" Mode, the Tool ran the "test device" routine, returned with "test device fail" and would go no further.
Another direction perhaps?  If I remember correctly, you designed a rom once for the Nextbook 7.85 equipped with an RK3188 to run off the external SD Card.  Is such a scheme feasible at all with the current CPU (3288)?
On my tab, I know the firmware has been erased.  However, it acts as if it's still searching for the rom to boot up, going past the initial big logo (INSIGNIA) to the second page where it beams the small "insignia" and remains frozen there.  If I leave it on long enough, it would restart the tab to go through the same stages again and again.  Is it even possible to get it to read the external SD at this point?
The device isn't worth much now.  It makes little economic sense to try to save it.  Nevertheless, I'm still interested in solving the technical problems.  Why the glitch?
Astralix
Germany
Forum Posts: 27
Thanks Received: 7
116
2016/08/23 - 08:53
The issue I have is, that I cannot see, what your tablet is really doing...
Are you able to attach a 3V serial port adapter to the RX and TX tespoints of your tablet? I do not know if you can do that or even have such a thing. Beware, that there are 5V (Arduino) adapters and 3V3 versions. The 5V version will kill your SOC, so if you can do that, take care.
If not... It is a bit difficult to analyze the issue without having more details...
graphdarnell
Forum Posts: 41
117
2016/08/23 - 12:23
I don't see TX and RX testpoints on the board; or if there are, they are unmarked.  I guess we have to let it go at that since even RK can't help.  I did try to flash the loader in MaskRom mode 3 times. They all came out ok but only up to that point.  Never seen anything like that.  But thanks again for all the help.
Astralix
Germany
Forum Posts: 27
Thanks Received: 7
118
2016/08/23 - 14:41
I checked your photo, even it is not very big... I cannot see any obvious test-points. But there are several cables and stickers on it where I can't see through. On one tablet I had, all the test-pins where on the bottom side, on several others these two pins, together with a ground pin where routed to an exposed position...
buzzly
Forum Posts: 14
119
2016/08/24 - 14:56
Off topic.
Would someone show me which 6000mah battery purchased from Aliexpress would fit this tab?   A link would be very helpful.  TIA.
graphdarnell
Forum Posts: 41
120
2016/08/24 - 21:24
I don't see RX or TX anywhere on this board.  The back side has a mylar insulation, and there's no visible testpoints.  I would think those would be exposed as there's no point having them hidden.
But the issue is not so much whether the RKAndroidTool would work as there's anything that works at all.  So my question to either Oma or Astralix is this:  bobb's method obviously works.  I'd done it myself before the catastrophe befell my previous tab.  Only, it requires ADB.  Another member (psiufoxx) reported that her tab was stuck at the pulsating logo (exactly like mine), and s/he only had access to stock recovery (See posts # 71 & 74).
Nevertheless, s/he was able to flash most anything (I assumed from this recovery) per bobb's instructions except the system.img. The only ADB I could see on stock recovery is Sideload.  I tried to sideload Oma's update.img but the machine reported no signature, so no go.  However, if this functions as ADB, then is it possible to flash with all the files on the external sd card, and issuing ADB commands from PC per bobb's instructions?
176 Guest(s)
Devices in use: Desktop (162), Phone (13), Tablet (1)
pinsky
louinsky
Arhreanymator
Bestmengqin
jr120065
Mark Naficy
