[ RK3288 ROM ] Insignia Flex Elite LP 5.0.2 custom root firmware (2015/08/08)
graphdarnell
Forum Posts: 41
61
2016/01/19 - 19:58
Download rkdumper: http://forum.xda-developers.com/showpost.php?p=56219924&postcount=1
Open the command interpreter with admin rights. Then type:
rkdumper swt
Check in RKAndroidTool if the device is in Loader Mode. Try to flash.
I'll try this as soon as I can get the tab to run again. Still looking for the screen to replace my broken one.  But thanks again for the info.
bobb
Forum Posts: 40
Thanks Received: 9
62
2016/01/28 - 00:48
Is there a chance we might get a marshmallow rom for the insignia flex elite?
Thanks.
Onda V972
Ainol Fire
iFive mini 3
Teclast P90HD
bobb
Forum Posts: 40
Thanks Received: 9
63
2016/02/05 - 02:07
Thanks for the tip graphdarnel.
Managed to put a 6000mah battery into the tablet (3.5 x 66 x 125) added about 8 grams to the weight. Was a pain!!
Running it down now, so i can charge from empty and see how long it lasts.
Onda V972
Ainol Fire
iFive mini 3
Teclast P90HD
graphdarnell
Forum Posts: 41
64
2016/02/09 - 11:19
So what's the verdict?  Does it get hot while either charging or using?
bobb
Forum Posts: 40
Thanks Received: 9
65
2016/02/09 - 20:06
Temperature is good, gets a bit warm, but not much. I use a 2.5A charger and it doesn't heat up while charging (charge takes approx. 1 1/2 hrs).
Overall, usability is much longer. I don't play games, but for streaming video and browsing lasts much longer.
A 6.0 rom would be nice..., hint, hint.
Onda V972
Ainol Fire
iFive mini 3
Teclast P90HD
resinis
66
2016/02/13 - 20:31
Trying to get OMA rom on mine.  I bought it used and someone must have been messing with the rom because it runs like dogpoo.
forcesystemclose at startup and it takes about 5 min to boot.   i dont think its hardware issue because once i eventually get it into an app it works really fast.
just got it rooted with kingroot, but now it boots to a black screen, all i have is the home buttons and the nav bar on top.   frustrating
what a nice piece of hardware with really crappy software :/
bobb
Forum Posts: 40
Thanks Received: 9
67
2016/02/16 - 00:09
For the Pipo P7 LP 5.1.1  Oma said to try this fix for netflix:
For netflix pls try this: http://crewrktablets.arctablet.com/?wpfb_dl=2765
I used it for the insignia flex elite and netflix is now working.
copied the oma... /system/etc files to /sytem/etc on tablet
copied the oma.../system/lib/libdrmdecrypt.co to /system/lib/ on tablet
copied the oma... /system/vendor/lib to /system/vendor/lib on tablet
The following users say thank you to bobb for this useful post:
Onda V972
Ainol Fire
iFive mini 3
Teclast P90HD
bobb
Forum Posts: 40
Thanks Received: 9
68
2016/02/17 - 01:43
Oma, would it be possible to use the kernel from the iFive air MM 6.0.1 for this tablet?
Not that clear on how all this fits together.
Thanks.
Onda V972
Ainol Fire
iFive mini 3
Teclast P90HD
69
2016/02/17 - 17:40
You can use the Flex LP sekernel. Our AOSP 6.0.1 or our CM13 build should boot on it.
However, I have not seens the tab starting into flash-mode by now ....
psiufoxx
70
2016/06/24 - 20:43
Really? We can get AOSP 6.0.1 or CM13 on this? Could you post instructions?
psiufoxx
71
2016/06/26 - 16:11
bobb said
Here's what I did to get the rom installed:
1.Go to http://forum.xda-developers.com/android/apps-games/one-click-root-tool-android-2-x-5-0-t3107461 and download KingRoot and install it and open/run it then restart tablet.
2. go to playstore and get esfile explorer, terminal emulator and busybox and install/open them (you want to give them super user access when it asks)
3. Download Oma's rom to your windows machine and unzip it.
4. plug a micro sd card into your windows machine and copy resource.img, kernel.img, boot.img, recovery.img and system.img from Oma's unzipped rom onto the sdcard.
5. take the microsd card and plug it into your tablet, turn tablet on.
6. Using esfile explorer, copy the above files onto the sdcard in your tablet (not into a folder on the sdcard, just the sdcard itself)
7. Open terminal emulator, type in 'su' without quotes and hit enter.
8. you will see a # at end of the next line (means you have super user access)
9. type in 'dd of=/dev/block/mmcblk0p3 if=/mnt/sdcard/resource.img bs=4096' without quotes, hit enter (it will say it copied a file across for all of these as you do them, system.img will take some time)
10. type in 'dd of=/dev/block/mmcblk0p4 if=/mnt/sdcard/kernel.img bs=4096' without quotes, hit enter
11. type in 'dd of=/dev/block/mmcblk0p5 if=/mnt/sdcard/boot.img bs=4096'  without quotes, hit enter
12. type in 'dd of=/dev/block/mmcblk0p6 if=/mnt/sdcard/recovery.img bs=4096'  without quotes, hit enter
13. type in 'dd of=/dev/block/mmcblk0p10 if=/mnt/sdcard/system.img bs=4096' without quotes, hit enter
14. Tablet should be rooted, restart it.
15. KingRoot will let you turn off some things at start (Auto-start), I uninstalled Purify (in KingRoot).
16. I also installed droidwall to stop apps from accessing internet as KingRoot tries to contact some server sometimes.
Hope this covers it...
Many thanks to Oma!
I'm trying to follow your instructions to install OMA rom on the Insigna Flex Elite, and while it mostly works, when I get to the system.img step I always get "No space left on device" after running the command.
Might you have any guidance here?
psiufoxx
72
2016/06/26 - 16:45
Or, it just freezes up. How long should this step take?
73
2016/06/26 - 19:51
Do you still have connection to the tab?
psiufoxx
74
2016/07/01 - 18:57
No, I can only boot into stock recovery or ADB sideload now. Totally soft bricked. Any advice?
75
2016/07/01 - 19:01
Is adb still working?
170 Guest(s)
2 Guest(s)
Devices in use: Desktop (158), Phone (12)
pinsky
louinsky
Arhreanymator
Bestmengqin
jr120065
Mark Naficy
