[ RK3288 ROM ] Insignia Flex Elite LP 5.0.2 custom root firmware (2015/08/08)
gaetanolip
Forum Posts: 28
31
2015/11/02 - 15:04
HI
does this rom work on ifive mini 4?
bobb
Forum Posts: 40
Thanks Received: 9
32
2015/12/16 - 21:54
I tried the Factory Tool on windows 7 and got:
10:10:51 646 Factory Tool v1.3.9.4 start run
13:06:27 448 Factory Tool v1.3.9.4 start run
13:07:34 247 Layer<14,2-1-6>:Test Device Start
13:07:39 280 Error:RKU_Read-->ReadFile failed,bRet=1,err=0,size=13,read=0
13:07:41 293 INFO:RKU_ResetPipe-->DeviceIoControl OK
13:07:41 293 <LAYER 2-1-6> ERROR:TestDevice-->RKU_TestDeviceReady failed,Total is zero
13:07:41 293 [Error] Layer<14,2-1-6>:Test Device Fail
13:09:39 623 Factory Tool v1.3.9.4 start run
13:11:29 952 Factory Tool v1.3.9.4 start run
13:15:24 083 Factory Tool v1.3.9.4 start run
13:24:33 402 Factory Tool v1.3.9.4 start run
13:25:07 606 Layer<14,2-1-6>:Test Device Start
13:25:07 606 <LAYER 2-1-6> ERROR:TestDevice-->RKU_TestDeviceReady failed,Total is zero
13:25:07 622 [Error] Layer<14,2-1-6>:Test Device Fail
13:27:58 049 Factory Tool v1.3.9.4 start run
13:30:37 750 Factory Tool v1.3.9.4 start run
13:34:21 425 Factory Tool v1.3.9.4 start run
13:35:58 753 Layer<14,2-1-6>:Test Device Start
13:35:58 753 <LAYER 2-1-6> ERROR:TestDevice-->RKU_TestDeviceReady failed,Total is zero
13:35:58 753 [Error] Layer<14,2-1-6>:Test Device Fail
13:48:03 223 Layer<14,2-1-6>:Test Device Start
13:48:03 223 <LAYER 2-1-6> ERROR:TestDevice-->RKU_TestDeviceReady failed,Total is zero
13:48:03 223 [Error] Layer<14,2-1-6>:Test Device Fail
13:50:50 478 Factory Tool v1.3.9.4 start run
13:51:33 410 Layer<14,2-1-6>:Test Device Start
13:51:33 410 <LAYER 2-1-6> ERROR:TestDevice-->RKU_TestDeviceReady failed,Total is zero
13:51:33 410 [Error] Layer<14,2-1-6>:Test Device Fail
Ready to try any other solutions.
Thanks.
Onda V972
Ainol Fire
iFive mini 3
Teclast P90HD
bobb
Forum Posts: 40
Thanks Received: 9
33
2015/12/16 - 22:37
Also tried RockChip Batch tool v1.8:
***********Switch Action************
<Layer 2-1-6> This operation didn't do, because of not supporting!
Log:
14:21:16 693 Rockchip Batch Tool v1.8.5.0 start run in vs2008 build
14:23:38 756 Rockchip Batch Tool v1.8.5.0 start run in vs2008 build
14:25:47 927 Rockchip Batch Tool v1.8.5.0 start run in vs2008 build
14:29:46 972 Rockchip Batch Tool v1.8.5.0 start run in vs2008 build
14:31:05 598 Rockchip Batch Tool v1.8.5.0 start run in vs2008 build
Onda V972
Ainol Fire
iFive mini 3
Teclast P90HD
bobb
Forum Posts: 40
Thanks Received: 9
34
2015/12/16 - 22:56
I have version 5.0.2 on tablet, I see the update.img is 5.0.0.
Onda V972
Ainol Fire
iFive mini 3
Teclast P90HD
35
2015/12/20 - 11:48
Is this Win7 native or in a virtual machine? Do you use an usb2.0 port?
Did you install the driver with the included DriverAssistant 4.3? You need to un-install the driver first. Make sure the new driver package is the first on root.
Is the FactoryTool showing a loader device?
Instructions-DriverAssistant.pngImage EnlargerInstructions-FactoryTool.pngImage Enlarger
bobb
Forum Posts: 40
Thanks Received: 9
36
2015/12/21 - 20:28
This is a native win 7 machine. I have used it before to flash your rom onto my P90HD.
Yes, used a usb 2.0.
Uninstalled then installed the driver.
Can see the tablets sd card and external sd card when I connect the tablet (already running) to my computer.
Steps I did after above:
Turn tablet off.
Start factory tool.
Select Firmware.
connect tablet to pc.
Hold down + vol while holding down start button on tablet.
I see Loader .
Click Restore.
Click Run.
Test device fail.
Log:
12:11:52 827 Factory Tool v1.3.9.4 start run
12:16:10 722 Factory Tool v1.3.9.4 start run
12:18:31 770 Layer<14,2-1-6>:Test Device Start
12:18:31 772 <LAYER 2-1-6> ERROR:TestDevice-->RKU_TestDeviceReady failed,Total is zero
12:18:31 774 [Error] Layer<14,2-1-6>:Test Device Fail
Suggestions?
Thanks for your time!
Onda V972
Ainol Fire
iFive mini 3
Teclast P90HD
37
2015/12/21 - 21:34
Still a driver issue. Can you pls try to root from "inside"? http://forum.xda-developers.com/android/apps-games/one-click-root-tool-android-2-x-5-0-t3107461
bobb
Forum Posts: 40
Thanks Received: 9
38
2015/12/22 - 04:04
That did it, got root using their .apk
Was able to install busybox, teminal emulator, etc. and remove some of the installed .apk's
Will try to flash your firmware tomorrow.
Thanks!!
Onda V972
Ainol Fire
iFive mini 3
Teclast P90HD
bobb
Forum Posts: 40
Thanks Received: 9
39
2015/12/22 - 19:16
Tried flashing update.img via Linux, but it does not see the tablet (driver issue again?)
If tablet is on and connected to linux machine, I can see files on it.
Can I not do the update.img on tablet itself?
Thanks.
Onda V972
Ainol Fire
iFive mini 3
Teclast P90HD
40
2015/12/22 - 19:38
Is adb working? Try to push the images via dd command.
Edit: you can also do it on the tab via terminal emulator.
dd of=/dev/block/mmcblk0p3 if=/mnt/sdcard/resource.img bs=4096
dd of=/dev/block/mmcblk0p4 if=/mnt/sdcard/kernel.img bs=4096
dd of=/dev/block/mmcblk0p5 if=/mnt/sdcard/boot.img bs=4096
dd of=/dev/block/mmcblk0p6 if=/mnt/sdcard/recovery.img bs=4096
dd of=/dev/block/mmcblk0p10 if=/mnt/sdcard/system.img bs=4096
bobb
Forum Posts: 40
Thanks Received: 9
41
2015/12/22 - 19:51
Which commands under terminal emulator?
Just to be clear, put .img files on external sdcard?
Thanks.
Onda V972
Ainol Fire
iFive mini 3
Teclast P90HD
42
2015/12/22 - 19:52
See post #40. Better to use internal sdcard.
bobb
Forum Posts: 40
Thanks Received: 9
43
2015/12/22 - 20:30
Ok, ran the commands thru termiinal emulator (su first).
looked like it worked, rebooted, looks the same.
Onda V972
Ainol Fire
iFive mini 3
Teclast P90HD
44
2015/12/23 - 10:00
??? Did you flash the images from post #1?
Elite-Tab-1.pngImage Enlarger
bobb
Forum Posts: 40
Thanks Received: 9
45
2015/12/23 - 17:10
Yes, I did.
After further investigation, it appears BusyBox did not fully install.
It did not symlink in some components like dd, rm, etc.
I had to reinstall busy box and choose the options to symlink in all
SUCCESS!! Your rom is installed!!
Thanks!!
Onda V972
Ainol Fire
iFive mini 3
Teclast P90HD
53 Guest(s)
Devices in use: Desktop (43), Phone (10)
cutierogue
