[ RK3288 ROM ] Insignia Flex Elite LP 5.0.2 custom root firmware (2015/08/08)
graphdarnell
Forum Posts: 41
151
2016/09/05 - 19:28
The stock recovery running first will format all user partitons. In TWRP or CWM one will get the same doing a factory reset.
So, to recap:
- we can now flash the rooted system.img and CWM.img through adb (with dd comand)
- in case of a bricked tab it is necessary to flash the repacked build in MaskRom mode
Do I miss something?
Correct, with one small different detail. A factory reset will not clear a (data) partition of residual data (recognized but unseen and unreadable by Explorer) from a failed update.  For that, a total format of internal storage is necessary.
graphdarnell
Forum Posts: 41
152
2016/09/06 - 03:08
Talked to an acquaintance today who tried to install CWM on his.  Reported that he couldn't use the CWM3.0.img, although the 1.1.img flashed ok.  Thereafter, he said it backuped without problems.  Given they are both 6.0.5.1 version, I don't see why one should be preferred to the other, so long as they work.  I just make a note here for those who might run into the same problem.
Edit:  I toyed around with the recovery and made myself a flashable zip for CWM 3.0.  Once again, I guinea-pigged myself and flashed it with the installed CWM 1.1.  Seems to work fine in case someone wants to "upgrade" from CWM 1.1.img to CWM 3.0.img, though I'd be damned if I can tell the difference between the two.  In any case, here's the link:
http://s000.tinyupload.com/index.php?file_id=54262539025371266969
The usual disclaimer:  you do this at your own risk.  If you blow up something, I don't want to know.  Well, actually I'd like to know, I'm just not responsible for any undesirable consequences.
mjsharon
153
2016/09/06 - 21:30
Successfully installed CWM 1.1 img using terminal emulator on tab.  Think I'll stick with this version.  Many thanks.
Korishan
154
2016/09/20 - 04:15
Ok, hey alll! This is my first post here.
I have been scouring the net looking for a solution to my non-working tablet. I've heard about Oma and seen plently of links to his files, but not till now have I stumbled across an active forum.  🙂  Jackpot!
I have an Insignia Tablet Model NS-P10A6100. I had installed KingRoot and sometime later, it started acting wierd (not sure if it was related to KR) so I rebooted it. The Insignia logo just pulses there.
I can get into Recovery Mode. In "Load from ADB", the device shows up and I can see it with "ADB devices". RKFactoryTool I don't see it at all, though. When I try to sideload anything, it fails when the tablet opens it up. I do have acess to the SDCard, but not sure what I should try to send through that.
I've read through this whole thread, and am wondering if these methods would work on my tablet.
I'm running on Windows 10. However, I have a second PC I can run Linux on if need to (will have to install it first).
Thanks for the help.
Kori
155
2016/10/02 - 12:05
As far as I can find out this is not a Rockchip architecture. The tab has a MediaTek MT8127B. Unfortunately I cannot help with that.
Korishan
156
2016/10/09 - 03:37
🙁  Drat, ok thanks OMA
Korishan
graphdarnell
Forum Posts: 41
157
2016/10/16 - 20:08
I learned that Lollipop 5.0.2 and lower have a horrible memory leak issue.  Has anyone experienced this with the current rom?  If yes, what is your personal remedy?  I installed Lollipop Memory Leak Fix but haven't used the tablet enough to notice the difference, if any.
buzzly
Forum Posts: 14
158
2016/11/21 - 21:23
oma,
You have mentioned this before.  Just want to clarify this.
Do you recommand   flashing iFive Air CM13 (replace the kernel and resource img) on this tab?
ghanashyaml2
159
2017/01/23 - 03:42
Hi guys, I stumbled upon this thread while searching for info on unblocking my Tronsmart R68. My tv box is bricked and also has Foresee eMMC which is discussed in this thread. I am however, for the life of me, unable to get this into loader or mask rom mode no matter what I try. Even shorting pins 8-9 while starting the power isn't getting it into mask rom mode.
OMa or graphdarnell, can you help me out?
160
2017/01/23 - 09:36
You will find specialists for the device here: http://freaktab.com/forum/tv-player-support/rk3688-devices-aa/tronsmart-rk3368
I am sure the collegues can answer your question.
193 Guest(s)
Devices in use: Desktop (177), Phone (15), Tablet (1)
pinsky
louinsky
Arhreanymator
Bestmengqin
jr120065
Mark Naficy
