[ RK3288 ROM ] Insignia Flex Elite LP 5.0.2 custom root firmware (2015/08/08)
graphdarnell
Forum Posts: 41
136
2016/08/31 - 21:04
graphdarnell said
Finally some great news.  I flashed successfully!  It's working fine now.  I will recount the process in details later in case people need to replicate it to resuscitate their stuck tablet.  Again many thanks to Oma the Man.  You beat it!
Fine. I can repack the build later. Pls try the TWRP first. Rename it to recovery and flash it, just ticking parameter, misc and recovery.
Yes, sire. I'll get to it later and report back.
graphdarnell
Forum Posts: 41
137
2016/08/31 - 21:07
The faint-of-hearts might hesitate. But given that a stuck tab is of little use, one stands to lose little by diving in. I'll list the steps in chronological order:
ALWAYS DISCONNECT the battery FIRST.
1. Peel the silver tape off the surface of the board. Be careful where it sticks to the lcd amber ribbon underneath as you might tear it with too much force. Go slowly;
2. Pry off the metal shield covering the CPU with a pointed flat blade at the tiny clips around the perimeter. Be careful not to insert the blade too deeply as some components are tiny and can be easily damaged;
3. With the components exposed, locate the FORESEE chip; locate pins 8-9 and mark them (see Post # 93 – red rectangle). I had to count the pins under a magnifier because they're so close together;
4. Copy all files in the rockdev/image folder + the “oma_parameter_lp.txt” in the zip package in post # 1 to the same folder in the package in post # 129. Launch RKTool of the # 129 package. In the GUI, select all the correct files. Uncheck all but the loader (first column);
5. Ain't no other damn way to flash the loader with this thing.  With power off, connect the data micro USB cable to the tab; short and hold 8-9 with a tiny flat screwdriver tip, then connect the USB cable to the PC. Done correctly, the GUI should switch from “No DEVICE Found” to “Found One MASKROM Device” at the bottom. If not, repeat this step again. Before repeating, make sure the tab is completely off again (I had to do it several times at each attempt to get it right so don't expect it to work at first try).
6. Flash the loader. If successful, the GUI will show “Found One LOADER”;
7. Lower Format the tab;
8. Uncheck loader; re-check all other items; flash them all.
It takes quite a few minutes (in my case) to finish. Once the download is complete, the tab will reboot on its own. First boot might take some minutes so be patient. When it gets to the “Oma” animation, you know you're good to go. Have fun.FlexMB1.jpgImage Enlarger
Illustration: Motherboard with metal shield removed.
Yellow: mesh tape patch. There are 2: one covering the metal shield that needs to be peeled off first.
Blue: this is where the lcd ribbon connects. Be careful in separating the covering tape from the ribbon.
Red: clips holding the metal shield (I did not highlight them all, but you get the idea).
graphdarnell
Forum Posts: 41
138
2016/09/01 - 00:03
Tried flashing.  Came out ok as you can see in the picture, except touch functionality is not there.  No touch, period.  OTG mouse likewise does not work because the 5V supply is unavailable.  A CWM alternative might, if one exists, but what do I know?  Tempted to try THIS, but maybe should wait for your advice thereon.
Question on the side:  We had to resort to MaskRTWRP.jpgImage Enlargerom Mode where there's no ADB because no OS.  However, if ADB in developer's options is available, can we not flash the recovery through ADB shell, the way you and bobb did it with all images?
graphdarnell
Forum Posts: 41
139
2016/09/01 - 10:41
As reported, TWRP installed but touch not working.  I know Oma may be super busy so I jumped the gun and installed CWM (Oma crew's own) using ADB shell commands (page 3 & 4).  Seemed to stick ok.  I'm testing to see how it works.  First impression:  Must use volume + button only.  Volume - button acts like power button.  Sd card formatted in NTFS cannot be mounted.  Fat 32 ok.  Which makes it rather inconvenient since the OS only recognizes NTFS.  Otherwise, it backs up fine.  Haven't tried to restore yet.  But will post results once done.
mjsharon
140
2016/09/02 - 02:15
Hi - trying to install the rom.  Everything is fine until I get to step 13 - installing system.img.  Won't install and says "Operation not permitted".  All help appreciated.
Thanks.
graphdarnell
Forum Posts: 41
141
2016/09/02 - 03:17
Thanks.
If I were you, I'd make sure of the following:
1.  The system.img is not corrupted in any way.  This could happen during download, extraction, and copying;
2.  Recheck for syntax errors;
3.  Use the PC to issue commands instead of Terminal Emulator.  The touch sensitivity on this model is not the best I've seen.
Good luck.
BTW, has anyone experienced this tab not connecting to Linux as an MTP Device?  There's obviously communication in Linux since I can issue ADB commands, just not as a media device.  Mine shows up fine in Win 7, but not otherwise. Wonder why.
mjsharon
142
2016/09/02 - 14:21
All set.  Used a different emulator.  Thanks.
Thanks Received: 1382
143
2016/09/03 - 05:39
Missing touch support in TWRP is kernel related. Pls use CWM from here: http://crewrktablets.arctablet.com/?p=5336
graphdarnell
graphdarnell
Forum Posts: 41
144
2016/09/03 - 10:57
Flashed CMW through ADB shell without incident.  Tested with full NAND backup successfully.  However, I'm a bit concerned about testing restore since I don't know if it works reasonably well.  Any precautions I should take?
On the side, I see no difference between package 2.2 and 3.0 insofar as the CWM.img, apart from the volume buttons' function.  I got 6.0.5.1 both times, I believe.
Lastly, you mentioned in post #69 about the possibility of using another kernel and system.img.  I assume the stock kernel can't be modified to activate touch for TWRP.  Any chance that the other kernel might do it?  Hopefully my tinkering would be of help to others.
I know you're way too busy so I'll wait until whenever.  I do appreciate your guidance very much.  Thanks again.
145
2016/09/03 - 12:28
A kernel (hardware abstraction layer) is a binary and tab specific. Consequently it cannot touched and without kernel sources this is a dead end.
The mounting and other stuff (i.e. PMC driver) are different in LP. So, I would recommend to use the CWM compiled for LP.
If the CWM can backup it also will restore. It is only the reversed way.
Can I also have a screenshot of settings/storage (full length)?
graphdarnell
graphdarnell
Forum Posts: 41
146
2016/09/04 - 06:38
At your request.  I also noticed that the internal storage is about ~12GB. However, with only 2.40GB of data, it's reduced to 5.71GB left, which does not add up.  Anyway.....Storage2.pngImage EnlargerStorage1.pngImage Enlarger
The following users say thank you to graphdarnell for this useful post:
147
2016/09/04 - 21:29
Here is the re-packed firmware: http://crewrktablets.arctablet.com/?wpfb_dl=2957
It does contain the mini-loader, the stock parameter file (for max partition sizes) and a CWM.
I guess it is possible to flash this firmware in Loader-Mode now.
Can somebody try to flash the CWM, pls (see attached picture)? It is a limited risk. If the loader will not work it won't flash anything.
flash_CWM.jpgImage Enlarger
graphdarnell
graphdarnell
Forum Posts: 41
148
2016/09/05 - 00:34
I'll try to flash CWM in Loader Mode tonight and report back.  One thing I forgot to mention is that if you flash Oma's Rom using the stock (lollipop) parameters, you'll get stuck at the Insignia Logo page.  You need Oma's parameters instead.
BTW, Oma, how do I format the data partition thoroughly as with TWRP?  CWM does it in a flash, and I don't think that's thorough because I still miss about 4GB of space afterwards.  I ran eMMC Brickbug Check and memory block check and they both came back positive.  Or if you point me to a site that shows how to do that with ADB, I'd appreciate it.  I've been looking online, but no one provides complete analysis and instructions.  Thanks.
graphdarnell
Forum Posts: 41
149
2016/09/05 - 06:17
It's a no go with the new repacking.  See enclosed thumbs.
CWM.pngImage Enlarger
Edit:  Can't dash the question I asked above about formatting the internal storage.  I was able to do it with CWM and reclaim the "lost" storage.  Also I did restore the tab with CWM backup, and it worked quite well.  At least if you install CWM through ADB shell, we don't have to worry about OTAs bricking the tab like it happened to a few of us before.  Big step forward, I'd say.
150
2016/09/05 - 18:04
The stock recovery running first will format all user partitons. In TWRP or CWM one will get the same doing a factory reset.
So, to recap:
- we can now flash the rooted system.img and CWM.img through adb (with dd comand)
- in case of a bricked tab it is necessary to flash the repacked build in MaskRom mode
Do I miss something?
92 Guest(s)
Devices in use: Desktop (82), Phone (10)
panchaud
ionmih83
brau10g21234
brau10g2
ccie2006
silver.surfer
