Gents,
Just playing around with a dump of the stock firmware V01.00.09 😉
Thanks to Dan EE for providing the dump!
Oma Flex Elite LP 5.0.2 build v1.0
– stock recovery 5.0.0
– sekernel #137 preempt 17 Jun 2015
– Reboot Menue
– Soft Volume Buttons
hints:
– Oma's favourite apps for LP
– Oma -
graphdarnellPer aspera ad astra, we rock the Tablets !
2015/07/17
Oma,
I still have not had any luck flashing a partition even going straight the rommask. I enter the rommask by pushing the rest button through the pinhole while holding down the +volume button. I am running Windows 7 on the PC and launching the AntroidTool with admin rights.
Dan EE
Most likely a driver issue. Use the included Driver Assistant. De-install driver first, then install again.
Dan EE said
I ran into a snag. It won't lower format the e-MMC. It just stays at 0%. It also reports "Device Test Start" and "Device Test Fail" If I try to flash a partition.
From the other thread ... is the tab still booting?
2015/07/17
Yep, still boots. If I could brick it, it should go to the rom mask loader. It may need a signed update.zip to get a rom onto it. I could try to ground the recovery pin on p21 of the processor. This would take a bit of effort and would be impossible if there's no via to scrape and mag wire to.
Pls try:
adb reboot bootloader
One step back. Pls check the usb driver: http://www.nirsoft.net/utils/usb_devices_view.html
Flash driver is: VID_2207&PID_320A
2015/07/17
I can't get to the website now. The VID=2207,PID=320A in device manager and Linux when in bootloader. Matches .inf file for a 3288. I am at work now and I am pretty sure about the PID. It may be 310A? I tried using a bootable image of firefly 4.4. It hung which may be promising since it doesn't have the LCD driver. Maybe a bootable TWRP image?
Sorry, VID_2207&PID_320A is the correct one for RK3288.
I would like to know if the tab gives this ID in flash-loader modus (all cable plugged, Reset, then Power & Vol+) and if the ID gets lost while action in the flash tool.
50 Guest(s)
Devices in use: Desktop (39), Phone (11)
