Thank you very much! Well appreciated to cover server costs.
An AOSP 6.0.1 rom is btw here: http://crewrktablets.arctablet.com/?p=5983
Same procedure as described in post #14 if someone would like to discover the new ground 😉
Thanks. You will find the stuff of v1.1.9 in post #11.
tokecinPer aspera ad astra, we rock the Tablets !
No.
ro.build.id=LMY48Y
ro.build.display.id=F516-userdebug 5.1.1 LMY48Y user.root.20160623.105813 release-keys
ro.fota.version=ifive_Pro_2_V1.1.9_20160623
2016/07/25
Hi Oma
I've just recieved my Ifive por 2 but I had a problem with the step number 4 you put in #1
4) flash the firmware with AndroidTool
a) click Lower Format
b) click Run
c) stock recovery will format the NAND
d) wait 2 minutes
When I clicked lower format I got match device type failed stop running. What can I do?
BTw, can I use another RK3288 custom room like this one in this tablet?
Looks like a driver issue. What Windows? Did you use the DriverAssistant?
2016/06/23
Hello Oma,
Last week I bought other Ifive Pro 2 tablet for a mate so I was analyzing reported soft buttons layout since when I sent above pictures, I did not pictures to my own tablet with original rom.
As you can see in new enclosed images belonging to original rom, both portrait and landscape keep soft buttons alligned and they are not moved to right even if you enable RK screenshot option.
From my point of view, layout change in your rom because you added soft volume buttons rather that RK screenshot option. Do you think could be possible disable such soft volume buttons and let layout and icons as original rom?
Sure: http://crewrktablets.arctablet.com/?wpfb_dl=2937
Build v1.2.0 with optimized cam again. Possible there is a new batch out with a better cam (IMX214). Anyway, here is the stuff: http://crewrktablets.arctablet.com/?wpfb_dl=2936
2016/06/23
Sure: http://crewrktablets.arctablet.com/?wpfb_dl=2937- Oma -
Working like a charm
As i told you, I guess such layout is better specially if you need also switch keyboards..
Thanks again and cheers!!
2016/06/23
Build v1.2.0 with optimized cam again. Possible there is a new batch out with a better cam (IMX214). Anyway, here is the stuff: http://crewrktablets.arctablet.com/?wpfb_dl=2936- Oma -
Already applied without issues.
Since I never use camera in tablet, I can not give you any improvement feedback...hehehe
Thanks!!
Currently Online: Bachan, CSATA
74 Guest(s)
Devices in use: Desktop (71), Phone (4), Tablet (1)
mbq1965
aleho
kaschow88
CSATA
CHD
vincent1970
