Gents,
This is a build based on ifive Pro 2 LP stock v1.1.7
– stock recovery 5.0.0
– Reboot Menue
– Soft Volume Buttons
hints:
– Oma's favourite apps for LP
– Oma -
Opimization of the cam (install via TWRP): http://crewrktablets.arctablet.com/?wpfb_dl=2886
2016/06/23
Hello Oma, IF
First of all, give you thanks for your wonderful work. I had IFIVE Air and from last week, already updated to IFIVE PRO 2 so as soon as I received it, I downloaded your rom and flashed it 🙂
Initally everything is going perfect, but perhaps because I am using cover with physical keyboard that IFIVE created for this new tablet, I can see that touch bottoms in the bottom are not alligned in portrait mode (they are not centered and they are closer to right side).
Do you know if it could be some DPI change or anything which could be fixed?. When I am in landscape mode, allignment is ok with and without keyboard.
Thanks again for ur work!!
First feedback, thank you very much!
Pls enable the RK screenshot option in settings, then you will se why the place at the left side is "free".
2016/06/23
Hi Oma,
Thank you so much for your response and, obviously, thanks to you for allowing foreigners like me living in China be able use these devices with clean roms 🙂
Well, I have enable screenshot in settings as noticed and I can see still it is not very well alligned at all...For me, I guess it should have circle alligned over fingerprint but...at the end...it is more look&feel issue rather functional trouble.
Kindly, if you give me some email or explain how manage it, I can send you two pics done with tablet using keyboard and not using and screenshot settings enabled.
In the other hand, only issue I have experienced is that when I open browser and go automatically to homepage, url is not resolved and I need reload page and then connection is established. Perhaps it happen with other apps requesting network but in browser is where you can see it clearer (I have tried both Firefox and Chrome). Do you have any idea about if it can be a bug? Maybe some wifi setting?
Again, thanks a lot for your support.
Kind Regards
Jorge
Well, that's the way the RK screenshot option is implemented.
You can upload pictures using the Attachements button which is located at the bottom left side. I guess other guys are interested in a short review of the tab too.
Sorry, not really sure if I understood the browser/wifi issue.
2016/06/23
Here I share screenshots in portrait mode and landscape mode using included keyboard.
Regarding to connection issue, when I open browser it normally connect automatically to tab I have opened if I did not close it when leaving browse and always report error like there was not connection. If I reload page after receive error, it load perfectly. For me it is like in first attempt, WiFi connection can be like standby and need wake up it.. It is not hard trouble but it is annonying need reload page that I left open in previous session.
About review, I am quite happy with the tablet (I had Ifive Air before), perhaps it is such thin that sometimes look too weak though 🙂
Xposed will crash the UI in RK customized LP builds. The reason is unknown. In MM however it works.
In last stock v1.1.9 the changelog reads: improved fingerprint sensor. This is most likely only kernel related.
Here is kernel #951 preempt 23 Jun 2016: http://crewrktablets.arctablet.com/?wpfb_dl=2892. You can flash it into the running build (see screenshot).
As for MM, we can rock the tab. Pls let me have a dmesg and a logcat log. Here is a tool.
2016/06/23
Hi Oma,
Already kernel updated sucessfully..Thanks!!
Please, find attached requested outputs (logcat and dmesg) and do not hesitate request me further data if I can help you.
By the way, in your first post you mention "enable Entropy Fixer with value 256" which I am not able to find where it should be configured 🙁 Could you kindly tell me how I can manage it?
Best
Thank you for the logs!
Load sEFix from Play Store and set it to Ultra (so called in the latest version).
CM13 build v1.2: http://crewrktablets.arctablet.com/?p=6073
Kernel: http://crewrktablets.arctablet.com/?wpfb_dl=2892
Model fix: http://crewrktablets.arctablet.com/?wpfb_dl=2894
Just replace kernel and resource in folder rockdev/Image and copy the model fix to the external sdcard.
In FlashTool do LowerFormat, then Run. In TWRP format data (see also instructions.txt) and install the model fix.
Not really sure what the kernel is doing, but I guess this will boot and you will have screen.
2016/06/23
Hi Oma,
Honestly I am not very fan of CM builds since I had not very good experiences in the past. In fact, my target with my devices is as much as possible run AOSP for all of them.
I guess we will need wait to IFIVE releasing Android 6.0 and then you will be able create custom rom if I want AOSP right?
BTW sEFIX downloaded and running as you recommendtion. Thanks 🙂
95 Guest(s)
Devices in use: Desktop (81), Phone (14)
floki
orocamora
Ellocojoe
Tonysc17
olegator
Ur
