Gents,
This is a Multi-Window build for iFive Mini4
– stock recovery 4.4.0
– CrewRKTablets recovery CWM 6.0.5.1
– CrewRKTablets recovery TWRP 2.8.3.0
– kernel #14
– 4 GB internal storage
– multi-window 2.0
– init.d support
– Dateimanager HD (Root)
– Nova Launcher
some corrections on UIÂ (install zip via TWRP/CWM)
How multi-window works.
Hints:
– to enable multi-user use the Xposed module Multi UsersÂ
– Oma -
Gogenzuller, slavan, panzol, lavinski, magicsword, vk2rPer aspera ad astra, we rock the Tablets !
Sorry. Now it is there.
Fine.
To enable developer options click 5 times onto the build number.
slavanPer aspera ad astra, we rock the Tablets !
lavinski said
Hi Oma!Great job congrats!
Rom is faster than stock.
I found a pair of bugs in this version:
1) when hide virtual buttons and turn screen andoid process stopped
2) When you choose in Settings- more 4G android stopped
Ok, thanks for feedback!
To correct the bugs, pls install this via TWRP/CWM: http://crewrktablets.arctablet.com/?wpfb_dl=2366
- Oma
Fine. Post #1 updated with the fix.
To play flash contents under 4.4 use FlashFox (Play Store) or in Chrome the mobile version of the pages should also work.
Design intend of these tabs is to only shut-off when no cable is plugged.
62 Guest(s)
Devices in use: Desktop (48), Phone (13), Tablet (1)
FreddyBerlin
Lioterson
titi1975
artnovabobo
sebnju
miami76
