[ RK3288 ROM ] IFive Mini 4 LineAgeOS 14.1 custom root firmware (2017/06/09)
Perich Palots
Forum Posts: 13
Thanks Received: 6
46
2017/07/07 - 21:50
Ok perfekt, I will do  tomorrow.
Will inform of results.
.....zzzzzz...........
thx
Perich Palots
Forum Posts: 13
Thanks Received: 6
47
2017/07/08 - 11:31
Hello again,
Finally did a full reflash with Ifive Air v1.2.4 build + IFive 4 mods ( post 33),  and the winner is.......
***1000% total success***Smile
Now, in Tablet info, model shows Ifive Air instead of Ifive mini shown with image from post 1. So means images/kernel are a bit different.
Now,  a joy to play , GApps, PlayStore  working fine from beginning, no camera issues,  and so far so good.
Just two little questions:
-I have a original tablet cover with magnetic switch. Previous to update, when opening/close cover pad was awakening/standby. Now not working now.
-There is an option under Screen options to allow awake with double touch. not working for me.
-Front cam is still active? could not find the way to swtich front/rear.
But honestly, these are absoluteley minor issues.
Fully want to thank Oma,Might all team for this fabulous project.
-Perich-
The following users say thank you to Perich Palots for this useful post:
slavan
48
2017/07/08 - 12:10
Fine. Thank you for feedback!
Model info corrected in model fix: http://crewrktablets.arctablet.com/?wpfb_dl=3097
As for the magnetic switch, I do not understand how it works in KK. So, for the moment no idea to implement this.
As for awake with double touch, this is not implemented in kernel.
The front cam you should find when using the "three-dot-button".
Pls let us know if the build runs stable on your Mini 4.
Perich Palots, slavan
Perich Palots
Forum Posts: 13
Thanks Received: 6
49
2017/07/09 - 21:10
Hi Oma,
Have been testing for a while, (......via the best beta tester in the world: my son!)  and so far so good, no issues at all.
Specially excel on battery behaviour. Much better than before.
Mini4 still is a god tablet, even better after this upgrade.
Thx again.
50
2017/07/09 - 21:23
Great. Thanks again for testing and feedback!
Perich Palots
Forum Posts: 13
Thanks Received: 6
51
2017/07/15 - 19:09
Hello Oma,
Have one litle issue that maybe you know how to fix. Prevoiusly to upgrade, when plugin a pair of headphone set, internal sound was muted, so only sound would come frome phones.
Now, after upgrade, even with phones plugged in, sound is coming simultaneously from phones and internal speaker.
I know its a hardware switch, so tried diferent phones plug to see cause, but no way;  internal speaker does not mute. for sure its software control.
Does Andrewd 7.1 behave different to 4.1 on this?
thx
Perich
slavan
52
2017/07/17 - 15:36
Confirm the issue. Holiday break now. Will catch this up in two weeks or so.
Perich Palots
slavan
53
2017/08/08 - 08:23
Perich Palots said
Hello Oma,
Hi! Thanks for testing this firmware. A couple of questions:
1. Russian language is available in the settings?
2. The battery consumption did not increase in comparison with the previous firmware from OMA (Oma_RK32_Ifive_Mini4_KK_4.4.4_v2.0) ?
3. There were no glitches on this firmware, such as spontaneous overload, or hang?
4. What are the bugs of this firmware you noticed, except those already mentioned above?
  Thanks!
Perich Palots
Forum Posts: 13
Thanks Received: 6
54
2017/08/08 - 12:13
Hello Slavan,
I think so, if is this: Pyccknñ.
Yes, sure russian is available. Tons of languages are available.
2 from my experience, battery behaviuor is much better thanprevius versions. Keep mind that our tablet is not new, and batteries are used. But, mi opinion, much better.
3 I have not seen special glitches, overloads, etc, but remeber to keep system optimized, clean of overloading apps, etc.
4 No special bugs apreciated. ( i also use tablet as user, i'm not a deep system scratcher). Only described hardware problems.
highly reccomend update to turn tablet to a new resurrection!
cheers
slavan
slavan
55
2017/08/08 - 15:22
Perich Palots
Thank you for the answers! More 2 questions:
1.  You confirm bug about the sound is coming simultaneously from phones and internal speaker?
2.  You installed  CrewRKTablets_RK32_iFive_Air_LineageOS_14.1_7.1.2_v1.2.4 and then  CrewRKTablets_RK32_P4_LineageOS 14.1_v1.2.4_model_fix_Mini4, through recovery TWRP , as it is written in the post number 33 ? It's all?
   Thanks, Perich Palots! Best regards!
api182
56
2017/08/12 - 12:27
Hi! This may be a silly question, but will this work on the Mini 4s?
57
2017/08/12 - 18:47
No, completly other hardware.
slavan
api182
58
2017/08/13 - 00:21
Oh No! ☹️
I thought they were similar hardware? (Same SOC RK3288 right?)
Is there any development work in the pipeline for the 4s? Is this one portable?
I'd be very happy to be a tester! 😀
***Just spotted the thread for the Mini 4s, I'll head over there! Exciting times!!! 😀***
Perich Palots
Forum Posts: 13
Thanks Received: 6
59
2017/08/14 - 00:37
Hi Slavan,
Yes, in my tablet bug is present. Maybe Oma can find a fix for this issue.
Yes, this is exactly how I proceed. Fairly easy.
luck!
slavan
GnomenKrieger
60
2017/08/24 - 19:41
The link to the kernel doesn´t work. Can anyone reupload it?
205 Guest(s)
Devices in use: Desktop (190), Phone (15)
ppaofe
kabelodinternetu
waterwall
sufak79
ntukinal
Miguelcnc
