[ RK3288 ROM ] IFive Mini 4 LineAgeOS 14.1 custom root firmware (2017/06/09)
MiGHT.
Germany
Forum Posts: 67
Thanks Received: 13
2017/06/24 - 20:03
Alright,
last_kmsg kernel #8 - some debugsymbols are missing
https://pastebin.com/dAuksz9r
dmesg #7
https://pastebin.com/AsSWDAnq
See this, too:
[    1.575762] init: finit_module for "/system/lib/modules/mali_kbase.ko" failed: Exec format errorinit: insmod: open("/system/lib/modules/rk30_mirroring.ko") failed: No such file or directoryinit: insmod: open("/system/lib/modules/rk29-ipp.ko") failed: No such file or directoryinit: insmod: open("/system/lib/modules/wlan.ko") failed: No such file or directoryinit: write_file: Unable to open '/sys/kernel/debug/tracing/tracing_on': No such file or directory
2017/06/24 - 20:52
This is what KK log tells us:
<6>[ 1.186304] i2c i2c-1: sensor_probe: gs_mma8452,0xdd6eac00
<7>[ 1.186318] of_get_named_gpio_flags exited with status 256
<7>[ 1.186324] of_get_named_gpio_flags: can't parse gpios property
<7>[ 1.186328] of_get_named_gpio_flags: can't parse gpios property
<7>[ 1.186333] of_get_named_gpio_flags: can't parse gpios property
<4>[ 1.186343] sensor_chip_init:gs_mma8452:devid=0x0,ops=0xc0d1f538
<6>[ 1.188072] input: gsensor as /devices/ff140000.i2c/i2c-1/1-001d/input/input2
<4>[ 1.188336] sensor_misc_device_register:miscdevice: mma8452_daemon
<4>[ 1.188345] sensor_probe:initialized ok,sensor name:mma8452,type:2,id=17
<4>[ 1.188345]
<6>[ 1.188391] i2c i2c-1: sensor_probe: ak8963,0xdd6eae00
<7>[ 1.188402] of_get_named_gpio_flags exited with status 257
<7>[ 1.188407] of_get_named_gpio_flags: can't parse gpios property
<7>[ 1.188412] of_get_named_gpio_flags: can't parse gpios property
<7>[ 1.188416] of_get_named_gpio_flags: can't parse gpios property
<4>[ 1.188423] sensor_chip_init:ops is null,sensor name is ak8963
<3>[ 1.188431] i2c i2c-1: sensor_probe failed -1
<3>[ 1.188431]
<4>[ 1.188444] sensors: probe of 1-000d failed with error -1
<6>[ 1.188471] i2c i2c-1: sensor_probe: ewtsa_gyro,0xdd6eb000
<7>[ 1.188480] of_get_named_gpio_flags exited with status 258
<7>[ 1.188485] of_get_named_gpio_flags: can't parse gpios property
<7>[ 1.188490] of_get_named_gpio_flags: can't parse gpios property
<7>[ 1.188495] of_get_named_gpio_flags exited with status 265
<4>[ 1.188504] sensor_chip_init:ewtsa_gyro:devid=0x0,ops=0xc0d1f594
<6>[ 1.246096] input: gyro as /devices/ff140000.i2c/i2c-1/1-0069/input/input3
MiGHT.
Germany
Forum Posts: 67
Thanks Received: 13
2017/06/24 - 21:15
Yes, there is the ak8963 sensor - this is a hallsensor, did you include hallsensor compatibilty in kernel config?
MiGHT.
Germany
Forum Posts: 67
Thanks Received: 13
2017/06/24 - 22:45
Kernel boots, no reaction to magnetic sensor
dmesg #9
https://pastebin.com/ZJwyGpQ1
[    2.115124] init: Service akmd does not have a SELinux domain defined.
2017/06/25 - 08:02
Is the compass working? Play around with detecting apps.
Is the sensor located where the flipcover magnet is? Use this app for detecting the magnetic field: https://play.google.com/store/apps/details?id=at.lab.sensorcollection
MiGHT.
Germany
Forum Posts: 67
Thanks Received: 13
2017/06/25 - 13:04
Compass is not working and any SensorTools doesnt recognize any valuechanges from sensor.
Maybe the problem is android-related?
MiGHT.
Germany
Forum Posts: 67
Thanks Received: 13
2017/06/25 - 19:38
I would.... 😉
File Oma_RK32_P4_LineageOS 14.1_v1.2.4_modell_fix_mini4.zip not found!
MiGHT.
Germany
Forum Posts: 67
Thanks Received: 13
2017/06/25 - 19:55
Still no sensor and no compass recognizing.
dmesg after Model Fix:
https://pastebin.com/tt1mQkaf
[    2.109183] init: Service akmd does not have a SELinux domain defined.
MiGHT.
Germany
Forum Posts: 67
Thanks Received: 13
2017/06/25 - 21:25
Alright, we got further.
Compass is working now, magentic sensor does change value.
But no action defined in android, so technically its working, but android dont know what to do with it.
Model Fix #2 dmesg
https://pastebin.com/qE6XJXad
Service is starting successfully:
[ 2.050491] type=1400 audit(1498418600.480:6): avc: denied { entrypoint } for pid=196 comm="init" path="/system/bin/akmd" dev="mmcblk0p10" ino=933 scontext=u:r:akmd:s0 tcontext=u:object_r:system_file:s0 tclass=file permissive=1
Thanks again for your effort.
2017/06/25 - 22:03
Pls install Androsensor (see Play Store). Open the graph for Magnetic field. Do a screenshot while holding the flip cover magnet on its place.
MiGHT.
Germany
Forum Posts: 67
Thanks Received: 13
2017/06/26 - 07:47
I did that, see sir:
No reaction to that cover...if i move the tablet or hold an speaker on it, the graph peaks out.
screen.pngImage Enlarger
209 Guest(s)
Devices in use: Desktop (190), Phone (19)
ppaofe
kabelodinternetu
waterwall
sufak79
ntukinal
Miguelcnc
