2014/09/11
Hello everybody,
LineageOS 14.1 based on Android 7.1.2 is now 99% working on iFive Mini 4.
Special thanks and all my credits go to Oma7144, netlars and the rest of the team working on the Build!
Features:
- recovery TWRP 3.0.2.0
- homebrew sekernel @ 1.8 GHz
- unified storage
- LineAgeOS su, su-binary
- pico gapps
- 5Ghz Wifi Fix: http://crewrktablets.arctablet.com/?wpfb_dl=3063
- Cam Fix: http://crewrktablets.arctablet.com/?wpfb_dl=3093
Currently known issues:
- Battery is detected by kernel with 10,000mAh but it has only ~ 6500mAh
  - but has no impact on percentage - See Post #12 - Magnetic Cover recognizing - See Post #12
- Cameras dont work - See Post #12
- Tablet sometimes dies in deepsleep
- GUI sometimes laggy for a second
Hints by Oma7144:
- instructions are included in the download pack
- developer options: enable by tapping 5 times onto build number (settings/about the tab)
- screenshots: enable in settings/buttons/power menue
- advanced reboot: enable in settings/developer options
- root access: enable in settings/developer options (apps and adb)
- local terminal: enable in settings/developer options
- better UI performance: set all animation scales to 0 in settings/developer options
Please consider donating to the guys from CrewRKTables, they're fantastic!
Download & Please give Feedback.
https://mega.nz/#!piowGDpD!_xh3TUe7dYy4CZ-Sc5ogc6c7L0cdpuj7YGb2BXDeARA
Password: "www.arctablet.com"
The following users say thank you to MiGHT. for this useful post:
Oma7144, Perich Palots, slavan
Thank you for beeing obstinately on this!
Another two kernel to test:
kernel #6 - http://crewrktablets.arctablet.com/?wpfb_dl=3084
kernel #7 - http://crewrktablets.arctablet.com/?wpfb_dl=3081
MiGHT.Per aspera ad astra, we rock the Tablets !
2014/09/11
Thanks Oma, for being active in this!
Kernel #6 and #7 doesn't change anything, its still very usable and smooth.
Same issues as listed above.
Idea: for fixing the deepsleep dead, higher the lowest clockspeed from 126mhz to e.g. 242mhz?
Question: What about 5Ghz Wifi, hardwarebased the rk3288 should be compatible, i guess?
Thanks and have a great day.
Can I have a dmesg from a fresh boot? And if possible a dmesg from a running stock build.
Lowest clockspeed should already be 242 MHz.
As for deepsleep: pls check if the tab comes back pressing Power a few times. Need to know if this is only backlight or if the tab gets off. Also, if this happens pls reboot into TWRP and try to get last log (last_kmsg).
As for 5 GHz wifi install this via TWRP: http://crewrktablets.arctablet.com/?wpfb_dl=3063
2014/09/11
Here is dmesg from fresh boot after 5ghz fix install:
https://pastebin.com/S3SzvTJ7
No more deepsleep death till now, tablet was idle for at least 4 hours, no death and only 2% battery drain - thats great!
Lowest clockspeed is displayed at 126mhz - it does going down to that:
Still no 5ghz or display bug?
Look into the CPU stats. You cannot set below 216 MHz.
Android 7.1.x has no option to switch between 2.4/5 GHz. So, I guess detecting apps will not work.
Use Wifi Analyser to detect networks. Option is there, but hidden.
I do not see any magnet sensor. I really need a stock dmesg. Reboot the tab before and use the sensor a few times.
[ 3.147701] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV8858) register success
[ 3.165946] D1:camsys_extdev_register(268): Extdev(dev_id: 0x1000000 dev_name: NT99252) register success
As for the cams, they get loaded. What is or is not in Android?
2014/09/11
Hi Oma,
yes you are right.
CPU lowest clock is 216MHz and 5Ghz Wifi works, thanks.
Camera Apps say: No connection to camera possible, maybe used by other application?
And Camera App Icon is hidden in app drawer.
Here is dmesg from latest 4.4.4 Stock rom with working magnetic sensor:
https://pastebin.com/aTAmETmn
Info: Using "Switch" Button in Android Tool doesnt work on 7.1.2
[ 0.773591] RICOH_FG_DBG: PMU: ricoh619_init_fgsoca : * Rbat = 135 mOhm n_cap = 4100 mAH
This here is the issue. Mini4 has 5600 mAh, right?
Unfortunately I cannot see any footprint of the magnet sensor in your KK log. Pls keep investigating on this.
2014/09/11
As for cameras:
CameraHal: VERSION-WARNING: camsys_head.h version isn't match in Kernel and CameraHal
CameraHal: WARNING: NT99252 soft reset by i2c failed!, please check follow information:
CameraHal: Slave_addr: 0x6c 0x0
CameraHal: Soft reset reg: 0x3021 val: 0x61
CameraHal: Power/PowerDown/Reset/Mclk/I2cBus
CameraHal: NT99252 device register failed!
CameraHal: camera_get_number_of_cameras(711): load sensor name(OV8858) connect 0
CameraHal: camera_get_number_of_cameras(711): load sensor name(NT99252) connect 0
CameraHal: camera_get_number_of_cameras(764): Open /dev/video0 failed! strr: No such file or directory
CameraHal: camera_get_number_of_cameras(1128): camera_get_number_of_cameras(1128): Current board have 0 cameras attached.CameraHal: Check OV8858 ID: reg: 0x300a val: 0x88 default: 0x0
CameraHal: OV8858 device register failed!Versions:
CameraHal: Kernel camsys_head.h: v0.10.0
CameraHal: Kernel camsys_drv : v0.27.1
CameraHal: CameraHal camsys_head.h : v0.11.0
As for Battery Capacity:
DSOC (Design State of Charge) is set to 10000, thats why android says it has 10000mAh.
RICOH_FG_DBG: PMU: ------- STATUS= 6: IBAT= -471: VSYS= 4553000: VBAT= 4174600: DSOC= 10000: RSOC= 10000: -------
As for Magentic Sensor, its not a dedicated magnetsensor, it's a hallsensor. Please include hallsensor compatiblity in kernel config.
AKM8963 is false.
[ 0.911241] sensor_register_slave:akm8963,id=29
AK8963 is right.
[ 1.188391] i2c i2c-1: sensor_probe: ak8963,0xdd6eae00
Thanks and have a great sunny day.
2014/09/11
Hi Oma,
Kernel #8 crashes at boot.
<1>[ 0.952951] Unable to handle kernel paging request at virtual address f00004fe
<1>[ 0.952976] pgd = c0004000
<6>[ 0.948675] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p1 p1 p1 p1 p1! p[f 0004e] pg(000000 <42Q 0.130]0> .904 IF@erLl ePror: O.Ps: [ ] PEE PT LP M
hci]`etq0_bDB: ! gu$ clZmmc woBhar/dnd ut 00 0Hz for init[mmc1]
<4>[ 0.953126] CPU: 2 PID: 1 Comm: swapper/0 Tainted: G W 3.10.0 #8
<4>[ 0.953153] task: dd490000 ti: dd472000 task.ti: dd472000
<4>[ 0.953189] PC is at __kmalloc_track_caller+0xa4/0x148
<4>[ 0.953214] LR is at __kmal Fc_ raccaD er! x3 0x08
Camera fix works, thanks!
DSOC (Design) and RSOC (Remaining) is now swapped?
[ 161.062184] RICOH_FG_DBG: PMU: ------- STATUS= 6: IBAT= 891: VSYS= 4275000: VBAT= 4219725: DSOC= 6282: RSOC= 9200: -------
Full logs, please.
80 Guest(s)
2 Guest(s)
Devices in use: Desktop (71), Phone (8), Tablet (1)
hakhiem
jenom
kfwacky
fer30
culo1
dfrt
