[ RK3288 ROM ] IFive Air MM 6.0.1 custom root firmware (2016/06/05)
2016/06/19 - 14:35
Gents,
This is a build based on IFive Air MM dev 2.2 - video decoding is working now ;-)
Oma RK32 Air MM 6.0.1 build v1.0
– stock recovery
– sekernel #13 preempt 17 March 2016
– unified storage
– Multi-Windows
– Reboot Menue
hints:
– Oma's favourite apps for MM
– Xposed Framework starter pack
– Oma -
084-2.jpgImage Enlargerv1.0_01.pngImage Enlargerv1.0_02.jpgImage Enlargerv1.0_03.jpgImage Enlargerv1.0_01a.pngImage Enlargerv1.0_06.pngImage Enlargerv1.0_04.pngImage Enlargerv1.0_11.pngImage Enlargerv1.0_05.jpgImage Enlargerv1.0_07.pngImage Enlargerv1.0_09.pngImage Enlargerv1.0_10.pngImage Enlarger
SbM_
Forum Posts: 24
2016/08/01 - 23:28
Hi!
About this ROM based on dev2.2, can you tell us what you changed as compared to the "official" dev2.2 version? Thx!
Meanwhile, congrats and thanks a lot for your great work on the iFive Air/Haier Pad971. I'm currently running your CM13 on my Pad971 and it's working great. Keep up the good work!
Haier Pad971 [(16 GB version) – CrewRKTablets RK32 Air CM13 build v1.3 (CyanogenMod 13.0, Android Marshmallow 6.0.1)]
2016/08/02 - 16:48
Not much, only things mentioned or shown in the pics in post #1. It was worth it because dev 2.2 fixes the broken video decoding (like in the attached pic).
viedo_crap.jpgImage Enlarger
SbM_
Forum Posts: 24
2016/08/02 - 16:56
Thx. In terms of performance, do you think this one is better than the CM13 or not?
2016/08/02 - 17:01
It is no up to me to comment such things. My daily driver is the CM13 build.
murigny64
Forum Posts: 48
2016/10/04 - 21:18
Samsung Galaxy Note 10.1 2014 - 5.1.1
Haier Pad971 5.1.1
Asus Memopad10 ME102A 4.4.2
Alcatel Idol3 6.0.1
Moto G2013 7.0.0
Moto G3 6.0.1
2016/10/04 - 21:45
Build in this thread is based on unoffical ifive build, done by a dev, which may or may not working for ifive.
The build you linked is done by us from scratch.
JEssicannn
Forum Posts: 252
2019/10/24 - 00:03
79 Guest(s)
Devices in use: Desktop (69), Phone (10)
cutierogue
hans41
rickybk
