[ RK3288 ROM ] IFive Air MM 6.0.1 custom root firmware (2016/01/28)
Ansuco
Forum Posts: 12
31
2016/03/09 - 12:52
Just one newbie question..If I want to try CM rom do I need to follow all the instructions?? or maybe I can just use TWRP to flash the new rom?? Don't know if my question makes any sense..
32
2016/03/09 - 17:11
For Rockchip stuff we always use the Flashtool.
potard
33
2016/03/15 - 03:17
TWRP Works well with Haier Pad with reboot of the Tablet.
But when hou Start from power off, touchscreen is not responding in the recovery.
Any idea?
34
2016/03/15 - 08:16
This is kernel related. Make yourself clear that you are running a strange kernel on the Haier Pad.
Ansuco
Forum Posts: 12
35
2016/03/17 - 20:06
I came back to say that everything working smoothly..Windows 10 couldn't show anything cause the tablet was in mode "charge" whenever I plug the usb cable, though the mode "Media transfer protocol" was chosen by default in developer options. So I simply changed the protocol to "charge mode" in developer options, went back and changed once again to "MTP" mode and it just worked.. Don't know why it wasn't working before. Now when the usb is plugged in, I have a notification with "Mtp" ticked on..
As for my 64gb sdcard, I formatted to ntfs on windows and now I can read and write on it from both pc and tablet..
Thanks a lot.. you guys rock..
36
2016/04/02 - 13:56
Fine. Thank you for feedback!
master-w
Thanks Received: 4
37
2016/10/29 - 13:55
Hi Oma,
I have an Haier 971 and using this rom right now it is really stable and fast. Only thing which is not working is the camera. There is no camera symbol. If I start the camera application with an third party app I get the error Not able to connect to camera. I believe this is an problem of the camera driver as the iFive Air has an different one. Are you able to fix this as done in the CM13 ifive air release.
best regards Rene
master-w
Thanks Received: 4
39
2016/10/30 - 11:34
still not workin 🙁 with this fix. But this fix helped in the CM13 rom. But I need it for this one as the CM13 build has the flicker failure.
master-w
Thanks Received: 4
41
2016/11/01 - 18:04
thanks but it is still not working. There is still no camera icon also third party apps are not able to connect to the camera.
42
2016/11/01 - 18:10
Can you pls check if you get other results with the Haierpad kernel?
http://crewrktablets.arctablet.com/?wpfb_dl=2931
d1mix
43
2016/11/05 - 12:00
Oma thanks for your great work! The Haierpad runs perfect with this build, much better than the CM 13.1 which is quite laggy.. Is it possible to bring this build to the newest security level like your CM build? 🙂
44
2016/11/05 - 15:04
Can you pls check if the CM13 build v1.3 runs better on the Haierpad?
d1mix
45
2016/11/06 - 10:33
I can confirm that CM 13 v1.3 runs much better on the Haierpad than the 1.4, even better than the non-CM-build! Thanks a lot for this great support 🙂
78 Guest(s)
Devices in use: Desktop (69), Phone (9)
trroll171717
alsoft75
Deaker
Gorael
WhiteD2125
Bokser
