2016/03/06
I'm on windows 10.
It seems I can't power off the device when its connected to PC. its get rebooted automatically and now I have this weird problem, the lower menu bar (with volume, home etc button) is not centered when the tablet is in mode "portrait". Its nearly 1cm offside to right but no issue when the tablet is in "landscape" mode.
2016/03/06
Hello Oma !
Thx very much . MM works for me ..
How could I install:
- Oma's favourite apps for MM
– Xposed Framework starter pack
I don't know how to do .. can you help please..
Thx a lot
2016/03/06
Ansuco said
I just realized that one of the photo you posted have the same issue, that means its a normal behavior all I miss is camera icon. Sorry to bother you with this ..now i'm trying to install your favorites apps but instructions files are empty.
I'm trying too.. Oma can you help us..? please
jack78 said
Hello Oma !Thx very much . MM works for me ..
– Xposed Framework starter packI don't know how to do .. can you help please..
Thx a lot
Fine. In the download packs there are some instructions (just the file name, nothing more):
# Install apps via FileManger
# Install Viper4AndroidFX via TWRP
# Install xposed_v79 via TWRP
Copy the apps and the zips (do not unzip) to the external sdcard.
Navigate with the FileManager to the app and click on it. On the first one you maybe asked to allow installation from unknown sources.
For the zips reboot to recovery via the app RebootMenue (you need to flash the TWRP first) and install the zips.
This indicates a different camera. When android does not find the hardware then it will not show the icon.
Mass_storage mode in Android 6.0 is gone: http://www.androidcentral.com/inside-marshmallow-usb-connection-options
Use MTP for the filetransfer.
2016/03/06
Here are some feedback...
Overall everything works great except sd card. I have 64Gb sdxc Samsung sdcard installed as portable external card but impossible to write anything on it. I tried with es explorer and file manager hd with the same negative result but no problem to read from it.
Windows 10 recognize the device as ifiveair but it shows nothing inside as described above by jack78. I tried both MTP and PTP usb configuration but the result was worse. It made the "icon ifiveair" disappear and windows tried to reinstall the device but it end up with the message "unknown device". The only time I was able to access sdcard from pc was when i used ftp protocol as proposed by File manager hd (over wifi) but no way to write anything on it. So I haven't found the procedure to write on the sd card without removing from the tablet. Btw the tablet must be power offed while inserting sdcard, otherwise it will be shown as "corrupted" ..
Well beside this sd issue, I'm happy with this rom. Many thanks to you and the team behind this project.
Thank you for feedback!
The build does not support exfat. So, only sdcards up to 32 GB will work.
To get proper connection use the MTP option in developer settings (see picture in post #26).
2016/03/06
Thank you for feedback!The build does not support exfat. So, only sdcards up to 32 GB will work.
You are right, when I tried on 8Gb card(Fat32) I was able to read and write on this card ..So I formatted my 64gb exfat card to Fat32 and retried but no success..I can only read from it and no write permission though the same card worked on galaxy 3 without any issue. I presume this rom doesn't support sd card greater than 32Gb no matter which file format.
Thanks for the link to CM13..
98 Guest(s)
Devices in use: Desktop (87), Phone (10), Tablet (1)
dubsiki
dubsi
vblxcimdwqgcztgrve
billcamp1984
simoxor33
kontra007
