[ RK3288 ROM ] IFive Air LineAgeOS 14.1 custom root firmware (2017/03/04)
Thanks Received: 1376
91
2017/08/08 - 12:07
Nice. Seems the touch controller firmware is corrupted somehow. Go back to stock and let me have the dmesg.
gllark
92
2017/08/08 - 20:56
First test kernel for Pro2: http://crewrktablets.arctablet.com/?wpfb_dl=3140
Unfortunately kernel does not work. Tablet boots into TWRP but touchscreen is still unresponsive. In TWRP adb does not recognize the tablet. Therefore it is not possible to make a dmesg.log. What else can we do?
93
2017/08/08 - 21:00
Pls flash this CWM: http://crewrktablets.arctablet.com/?wpfb_dl=3133
Maybe looks a bit strange but it should do the job to do a factory reset.
gllark
94
2017/08/08 - 22:39
Unfortunately, that didn't work. I´ll be on a trip till saturday. I´ll check back then.
str1ke
95
2017/08/09 - 10:13
I can't get any rom booting anymore and in the stock one there is no adb. But in the CM13 version for the iFive Air I can get into TWRP and the touchscreen works perfectly. I attached the dmesg from the TWRP and another one from the boot.
Actually made it once into the android start screen with the CM13 version, but it then greeted me with "Powering Off" and went down again. Also most the time it stays stuck at the Rockchip kernel logo or just goes dark. Do you have any idea, what could cause that problem? Only saw that in the TWRP dmesg it says it can't read battery status, but in the other one there is no such message.
I have to say that already when I had the original stock version, I had problems with boots. It would say "optimizing apps", but then at some point restart and do the same all over agian. It would sometimes take hours to properly boot. Actually the reason, why I flashed the new rom, but maybe it's a hardware issue.
Thanks a lot for your help.
96
2017/08/09 - 20:23
Ok, new set of information. Sounds like multiple hardware issues. Make use of your warranty.
str1ke
97
2017/08/10 - 16:33
Thanks for your reply again. I failed to make a backup. Do you by chance have an unmodified stock rom for the haier pad? I know you have this version: http://crewrktablets.arctablet.com/?p=6454, but it seems modified at least with the logo. I think even though it's probably a hardware issue, they might not want to look at it, if the rom is different.
98
2017/08/10 - 19:24
Anybody who can help out with Haier Pad 971 stock firmware?
99
2017/08/13 - 21:13
Xposed has landed on RK32 LineageOS 😉
http://crewrktablets.arctablet.com/?wpfb_dl=3141
v1.2.5_05.pngImage Enlargerv1.2.5_06.pngImage Enlarger
hotte1983
Forum Posts: 20
100
2017/08/21 - 17:41
Soundproblem under LineageOS,
when i use my Earphone on Haier Pad 971 than i hear the Sound over Earphone and Loudnessspeaker,i cant find the option in Android to hear the Sound only over the 3,5mm Earphone.
It this a bug?
gllark
101
2017/09/04 - 18:49
I´m back from vacation now.
Tried your CWM, but it doesn´t start, only loops eternaly. When I start the tablet with power button the lineage boot animation starts, but loops forever. I tried also to do a factory reset with adb and fastboot commands (erase data and cache), but I don´t get access. Anything we could try more?
Edit: Got it made to format data via adb and do a factory reset. Pro2 bootet into lineage. But the touching on the display is displaced although it looks well. The navigation bar starts above the middle line of the tablet. Below that middle line is the status bar. So the whole touchscreen is scrolled up half the display. So if I want to push a button which is correct shown in the navigation bar at the bottom I have to touch just above the middle line on the touchscreen. Also if I want to touch something in the status bar it lies just below the middle of the screen.
It is almost the same problem as described in post number 70. The location of the "touch zones" are similar, but for example if I want to drag the slider in TWRP at the bottom I have to drag it in the same direction as it should be, but above the middle of the screen. So it looks that the "touchscreen" has moved half the display upwards.
Would be nice if you could fix this. Thanks in advance.
Perdigon55
Forum Posts: 17
102
2017/11/25 - 11:10
Pls try again: http://crewrktablets.arctablet.com/?wpfb_dl=3086
Could you also pls test the latest kernel #18: http://crewrktablets.arctablet.com/?wpfb_dl=3085
One can flash it separately into the running build.
flash_kernel-1.pngImage Enlarger
Hello Oma7144 I installed the rum applying the kernel 31, fix 5g and the 5g does not work. Reading I have
found the comment of this partner, but I can not download the last fix that worked to 3086. Thank you for
your work.
zabnat
103
2018/03/19 - 20:46
I just upgraded from cm13 to this. However I noticed there is no more vibration and no options for it. Did it not work with lineageos?
Also I'm getting that "Device is not certified by Google" notification. Should I clear those properties from build.prop as per many instructions on the internet for this problem or is there another solution?
sophie-do
104
2018/12/02 - 21:39
sorry i'm french i use google translate to write this post.
I installed android 6 on my haier pad 971 with your tutorial, it worked except the camera.
I wanted to install android 7 (CrewRKTablets_RK32_iFive_Air_LineageOS_14.1_7.1.2_v1.2.5) the tablet started on TWRP and I did not pay attention I did not do:
      d) select wipe
      e) Data and confirm format by typing yes
      f) Factory Reset ...
since I restarted I have a black screen with a curve and a circle that goes from right to left.
I can not do anything since.
Can you help me or the tablet is dead? 🙁 thank you
Misterke
105
2018/12/27 - 16:06
With the CrewRKTablets site being unavailable, is there any place where I can find all the files referred to by the various threads for the IFive Air and the Haier Pad971? I guess I need the camera patch and possibly some other stuff, but all the links seem to refer to CrewRKTablets and as said, that one is down.
I'd also be very interested in the Android 5.1.1 stock ROM for the Haier Pad971. It ran fine for years, until things (I think flash I/O considering high mmcqd load) got so slow that it got unusable. As I had no stock ROM available, I jumped and installed an IFive Air ROM, but that broke the cameras ...
Thanks in advance for any help!
71 Guest(s)
Devices in use: Desktop (61), Phone (9), Tablet (1)
Vovk88
pacman123321
josecabal
souperman
qaswed
hl2341685
