[ RK3288 ROM ] IFive Air LineAgeOS 14.1 custom root firmware (2017/03/04)
yukka
61
2017/07/01 - 15:51
Next try: http://crewrktablets.arctablet.com/?wpfb_dl=3107
I installed the new kernel, but it does not bring the touchscreen to work for me.
Best regards,
Dirk
62
2017/07/01 - 16:09
Pls let me have a dmesg log.
yukka
63
2017/07/01 - 18:53
Hi, here are new logs, made on the HAier 971 with CM6.0.1.
Regards, Dirk
64
2017/07/01 - 19:08
I meant a dmesg log of the latest test kernel. Just to see what the touch driver is doing.
You can flash kernel/resource into the running CM13 build. Do the log via ADB.
flash_kernel.pngImage Enlarger
yukka
65
2017/07/01 - 20:35
Hi Oma,
I flashed kernel/resource to the CM13, but only TWRP comes up 1 time. After that android does not start, it stucks with a black screen after 'Rockchip kernel' is displayed.
I made a adb logfile, it is attached to this message.
Kind regards, Dirk
66
2017/07/01 - 20:37
This is the Android log. The kernel log (dmesg), please.
67
2017/07/01 - 20:54
Next one: http://crewrktablets.arctablet.com/?wpfb_dl=3110
Just check touch in TWRP.
yukka
68
2017/07/01 - 22:55
Hello Oma, I checked your last kernel (in CM13 and 14.1), but touch still does not work in TWRP.
I attached 4 dmesg-logs (i managed to read them out with adb):
1.2.4 firmware with original kernel, both boot in twrp and then when the second boot stops, an after that the same firmware with your latest kernel/ress, also the twrp and after that the second boot which also stops.
Thanks for your work. Dirk
yukka
70
2017/07/02 - 17:10
Ok, try again: http://crewrktablets.arctablet.com/?wpfb_dl=3112
Hello Oma, I tried the new kernel, and it works in some kind. You are on the right way. I attached a dmesg log, and a picture. The touchscreen is working, but rotated. In the picture you can see where I have to touch to move the slider. Regards, DirkIMG_20170702_170009-1.jpgImage Enlarger
yukka
72
2017/07/02 - 18:04
Pls try: http://crewrktablets.arctablet.com/?wpfb_dl=3113
Hello, now the touch is mirrored to the last kernel (but not rotated. i think it has to be rotated 90 degrees clockwise from the first working kernel). to move the slider in the red box, ich have to touch in the green box. Regards, Dirk.
By the way, I touched me through TWRP with the last kernel (wipe, reset and format), and after that linage14.1 ist booting up to setup (where the touch is also working like in TWRP). It is quite difficult to go through the setup then with rotated touchpanel, but then you come into lineage14.1.
IMG_20170702_175604.jpgImage Enlarger
yukka
74
2017/07/02 - 19:36
Let me know which one it is:
Hello Oma,
CrewRKTablets_RK32_sekernel_N_310_air_27_ifive.zip.7z is working for me. Now the touch screen is correct.
I write again in 1 or 2 hours after a little testing whether everything works fo far.
Kind regards, Dirk
-UPDATE-
I tested now a little, so far everthing is working. This means:
- Tablet is working, Wlan is working, Bluetooth is working, MTP is working
- Touch is working correct
- Cameras are both working (with Haier971 cam fix)
- Orientation sensor is working
- I installed some apps, and the tablet is working until now without a problem
Seems that my Haier is now Android 7.1.2. Thank you Oma! Regards, Dirk
(If I find some problems, I will write a message here.)
75
2017/07/02 - 20:52
Great, thank you for testing!
Update post #1 with kernel #27 - HaierPad 971 with Goodix touch.
84 Guest(s)
Devices in use: Desktop (77), Phone (7)
cutierogue
hans41
rickybk
