[ RK3288 ROM ] IFive Air LineAgeOS 14.1 custom root firmware (2017/03/04)
CurvedAir
Forum Posts: 30
46
2017/06/17 - 09:15
For 5 GHz support pls install this via TWRP: http://crewrktablets.arctablet.com/?wpfb_dl=3063
Yeah, I installed the quoted patch.
47
2017/06/17 - 10:53
Pls try again: http://crewrktablets.arctablet.com/?wpfb_dl=3086
Could you also pls test the latest kernel #18: http://crewrktablets.arctablet.com/?wpfb_dl=3085
One can flash it separately into the running build.
flash_kernel-1.pngImage Enlarger
CurvedAir
Forum Posts: 30
48
2017/06/17 - 13:26
After installing the latest patch it finally worked, thanks Oma.
Screenshot_20170617-132134.pngImage EnlargerScreenshot_20170617-132202.pngImage Enlarger
CurvedAir
Forum Posts: 30
49
2017/06/17 - 14:23
Got a mismatch while trying to insert the new kernel.
Geekbench:
Screenshot_20170617-140057-1.pngImage Enlarger
50
2017/06/17 - 14:51
What do you mean?
CurvedAir
Forum Posts: 30
51
2017/06/17 - 15:02
Nothing special, everything seems to function properly.
After installing the latest 5GHz patch the tablet connected to my 5GHz network. Afterwards, I tried to install the new kernel, but according to 'Android tool' the device types didn't match.
Just for comparison purposes, I posted the Geekbench results. 😉
52
2017/06/17 - 15:09
Ok, fine. Thank you for testing and feedback!
CurvedAir
Forum Posts: 30
53
2017/06/17 - 15:17
You deserve all the credit, Oma.
Thanks to you we can now use Android 7 on our Haier Pad and I five Air/Pro tablets. If we had to wait for Haier and  Ifive we possibly never would have got it...
54
2017/06/19 - 22:09
Optimized battery stats for Air (install via TWRP): http://crewrktablets.arctablet.com/?wpfb_dl=3088
Hardcore testing: playing video nonstop and 1 hour video with short breaks.
v1.2.4_09.jpgImage Enlargerv1.2.4_10.pngImage Enlargerv1.2.4_10a.pngImage Enlarger
soeren
55
2017/06/30 - 10:55
thanks for your continued work on this, but I still can't use Lineage OS 14.1 on my Haier Pad.
If I follow your instructions - lower format and "Run" then the tablet automatically reboots into recovery, but I the touchscreen in TWRP doesn't react to touch actions. No "swipe to allow modifications" or anything - the only way out is a hard power-off. After a restart the tablet hangs in the lineage OS boot logo.
Needed to go back to CM13_6.0.1 again after that.
ciao, Sören
yukka
56
2017/06/30 - 15:22
soeren said
Hi, thanks for your continued work on this, but I still can't use Lineage OS 14.1 on my Haier Pad.
ciao, Sören
i have the same behaviour with my Haier 971. I can install the Lineage OS 14.1, the the TWRP comes up, but the touch screen is not working so I am not able to setup TWRP correctly (In both versions 1.2.4 and 1.2.2 with TWRP 3.0.2.0, they are both not working).
The CM13_6.0.1 (TWRP 3.0.0.0) is working fine for me.
If someone has a solution, I would be very happy
Kind regards,
Dirk
57
2017/06/30 - 15:35
Hm, sounds like there are different hardware revisions in the field.
soeren & yukka: pls let me have a dmesg log from a working firmware. Reboot the tab before doing the log.
58
2017/06/30 - 22:23
Goodix touch.
[ 1.607117] input: Goodix Capacitive TouchScreen as /devices/virtual/input/input2
[ 1.607255] <<-GTP-INFO->> GTP works in interrupt mode.
[ 1.607534] <<-GTP-INFO->> IC VERSION:9271_1040
[ 1.607544] <<-GTP-INFO->> Applied memory size:2562
[ 1.607561] <<-GTP-INFO->> Create proc entry success!
Pls check this kernel: http://crewrktablets.arctablet.com/?wpfb_dl=3103
http://crewrktablets.arctablet.com/?wpfb_dl=3104
yukka
59
2017/07/01 - 10:18
Goodix touch.
Hello Oma,
thanks for your work. I tried both kernels, but the touch screen still does not work.
Kind regards, Dirk
46 Guest(s)
Devices in use: Desktop (42), Phone (4)
merlin077
nrod
midnight-gr
Pajaro047
trroll171717
alsoft75
