Very last idea. Download again: http://crewrktablets.arctablet.com/?wpfb_dl=3063
No, the log shows me only that the right firmware (same as stock) gets loaded and the chip should work as specified. Sorry for now.
For 5 GHz support pls install this via TWRP: http://crewrktablets.arctablet.com/?wpfb_dl=3063
2016/05/02
Did a fresh install of Lineage and applied the 5GHz patch, as well as the Camfix. No 5GHz networks visible.
Syslog:
Seems for the log I need a key.
Can you pls check with this app: https://play.google.com/store/apps/details?id=ua.com.wifisolutions.wi_fi5ghzsupport&hl=en
Still ask for a key.
Does not work. Just attach the log here to your post.
Can you pls check with Wifi-Analyser if the Band is seen? Push the button 2.4G/5G. With the patch it is now there, but hidden 😉
Is the patch installed?
83 Guest(s)
Devices in use: Desktop (68), Phone (15)
cutierogue
hans41
rickybk
