ย Please donate to support OMA and CrewRKTablets firmware work, thank you !
[ RK3288 ROM ] IFive Air LineAgeOS 14.1 custom root firmware (2017/03/04)
2017/05/10 - 18:05
Pls provide the dmesg and logcat log.
CurvedAir
Forum Posts: 30
2017/05/10 - 19:24
I assume i do have to use TWRP file manager to copy them.
Where can I find these files in the hierarchy?
CurvedAir
Forum Posts: 30
2017/05/10 - 20:15
I just managed to install Syslog, but just before i could upload the files to another device the Haier Pad started to reboot all of the time, so I couldn't get to the interface anymore.
Thanks for all your advice, but I will reflash it with MM and use this for the time being. Perhaps later on a new build will do the trick.
2017/05/21 - 17:27
Update post #1 with final build v1.2.2 - RK Videoplayer is floating again ๐Ÿ˜‰
- add charger mode and battery daydream
- add USB-OTG support
- add RK screenshot button
- add RK Videoplayer
- fix video after screen off
- replace Gello by Jelly
- Google May security patches
v1.2.2_01.pngImage Enlargerv1.2.2_05.jpgImage Enlargerv1.2.2_02-1.jpgImage Enlargerv1.2.2_06-1.pngImage Enlargerv1.2.2_07-2.pngImage Enlargerv1.2.2_09.pngImage Enlargerv1.2.2_12.pngImage Enlargerv1.2.2_11.pngImage Enlarger
2017/06/11 - 19:01
Update post #1 with build v1.2.4 ๐Ÿ˜‰
- Google June security patches
- kernel should also work for Haier Pad 971
v1.2.4_01.jpgImage Enlarger
CurvedAir
Forum Posts: 30
2017/06/12 - 19:14
Confirmed install on Haier Pad 971. (Build 1.2.4)
ย
I had to install the Camera-fix. For now, there's just one glitch left; 5GHz networks are not visible. I had to connect to my 2,4 GHz network for internet connection.
Any patch forthcoming?
And of course, thanks for the ROM Oma.
2017/06/12 - 19:24
Just for documentation purpose: which cam fix?
Install this and let me have a dmesg log if 5 GHz still not work: http://crewrktablets.arctablet.com/?wpfb_dl=2955
CurvedAir
Forum Posts: 30
2017/06/12 - 19:55
https://mega.nz/#!z9UGhTrQ!WG3lj6BYHeIr0n1sm6xj4mlbOYHTwHo3vO82LTefu9E
ย
I just put a logfile online. May be incomplete, device is not rooted yet.
I installed camfix number one. Camera front and rear works, though it seems to be upside down, using the 'Open Camera' app.
2017/06/12 - 20:22
Root is included, just enable in settings/developer options.
Pls try this: http://crewrktablets.arctablet.com/?wpfb_dl=3063
CurvedAir
Forum Posts: 30
2017/06/12 - 20:37
Tried the patch, no 5 GHz WiFi covered.
Took another log:
https://mega.nz/#!zw9ACIYQ!6OJDBWWbTfiJLMtUPL7TBZIzhi6OuoZ7Yrvxc6s4MgE
2017/06/12 - 21:08
Ok, last try for today. Downlaod again: http://crewrktablets.arctablet.com/?wpfb_dl=3063
CurvedAir
Forum Posts: 30
2017/06/12 - 21:23
Failed, no 5GHz.
2017/06/12 - 21:31
But still 2.4 GHz, right?
The firmware gets loaded as it should. Not really anything what can be done.
[ 21.192318] dhd_conf_set_fw_name_by_chip: firmware_path=/system/etc/firmware/fw_RK903b2.bin
[ 21.192325] Final fw_path=/system/etc/firmware/fw_RK903b2.bin
[ 21.192331] Final nv_path=/system/etc/firmware/nvram_AP6330.txt
[ 21.192336] Final conf_path=/system/etc/firmware/config.txt
[ 21.218547] NVRAM version: AP6330_NVRAM_V1.0_20121130
CurvedAir
Forum Posts: 30
2017/06/12 - 21:38
Yep, 2.4 GHz works fine. But of course I prefer 5 GHz, there's a considerable difference in speed, especially when downloading from Usenet. ๐Ÿ˜€
78 Guest(s)
2 Guest(s)
Devices in use: Desktop (63), Phone (15)
cutierogue
hans41
rickybk
