Gents,
LineAgeOS 14.1 has landed on iFive Air 😉
CrewRKTablets RK32 Air LineAgeOS 14.1 build v1.2.5 - 10.07.2017 - Google July security patches
CrewRKTablets RK32 Air LineAgeOS 14.1 build v1.2.4 - 09.06.2017 - Google June security patches
- add 5 GHz wifi (install via TWRP)
- Haier Pad 971 with Goodix touch, pls change kernel #27 in folder rockdev before flash
CrewRKTablets RK32 Air LineAgeOS 14.1 final build v1.2.2 - 20.05.2017
CrewRKTablets RK32 Air LineAgeOS 14.1 build v1.2 - 04.05.2017
CrewRKTablets RK32 Air LineAgeOS 14.1 build v1.1 - 17.04.2017 & kernel #6 (change files in folder rockdev/Image)
CrewRKTablets RK32 Air LineAgeOS 14.1 build v1.0 - 04.03.2017
– recovery TWRP 3.0.2.0
– homebrew sekernel @ 1.8 GHz
– unified storage
– LineAgeOS su, su-binary
– pico gapps
issues: ./.
Confirmed installation as is:
- Haier Pad 971, install cam fix via TWRP
- Ifive Mini4, change kernel/resource in folder rockdev/Image before flash, install cam fix via TWRP
- should also work on Ifive Pro2
hints:
– developer options: enable by tapping 5 times onto build number (settings/about the tab)
– screenshots: enable in settings/buttons/power menue
– advanced reboot: enable in settings/developer options
– root access: enable in settings/developer options (apps and adb)
– local terminal: enable in settings/developer options
– better UI performance: set all animation scales to 0 in settings/developer options
Special thanks to netlars & mussonero
– Oma -
Still heavily under construction, but here we go: http://www.arctablet.com/blog/forum/rk3288-entwicklung-und-customroms-development-and-croms/rk3288-rom-pipo-p9-lineageos-14-1-custom-root-firmware-20170101/?lang=fr#p59858
2013/03/13
I just tested the v1.1 build on my Haier Pad as an upgrade from CM13 (6.0.1), but I found out that it doesn't work.
Tablet boots once into recovery after the upgrade, but TWRP doesn't react to touch actions. So TWRP can't be used.
After that I do a hard-power-off and the Lineage OS boot animation starts, but the tablet shows this animation forever and doesn't finish booting. What could be the problem? I would love to keep my data partition so I didn't do a full wipe, but just a "lower format" in the AndroidTool.
[Edit: Even a clean install (after using "lower format") didn't work]
ciao, Sören
You need to flash the build as is, incl. the kernel. I clean install is mandatory.
TeutonJon78Per aspera ad astra, we rock the Tablets !
2014/12/13
Awesome! Thanks.
iFive Air (32GB) - XDA Discussion -- (including my iFive Air Nexus ROMs based on stock)
2016/05/02
I'm sorry to say i 'd have to agree with Soeren: the upgrade didn't work. I tried version 1.2 as well as 1.1.
- Using the Android tool, all the options are ticked.
- TWRP works fine, data can be swiped with the exclusion of the cache (can not be mounted, as stated by TWRP).
- Using TWRP, a factory reset can not be done, as stated in the instructions.
- After system reboot, all I get is a boot animation: a greenish blue bow with a moving circle in it.
I guess we are talking about Haier Pad 971, too?
Please read instructions carefully:
c) tab will reboot into TWRP
d) select wipe
e) Format Data and confirm by typing yes
f) Factory Reset
If it still loops, please try the cam fix: http://crewrktablets.arctablet.com/?wpfb_dl=2928
If it still loops, pls provide a dmesg and a logcat log.
2016/05/02
Yes, Oma, I'm talking about the Haier Pad. Tried four times with the same result, and followed the instructions, just don't understand what you mean by ' Factory reset', TWRP has no option for this.
Today I reinstalled CM Android 6.01 again, without any issues. One of these days I'll try again, and install the cam fix.
Thanks for your reply.
2016/05/02
Thanks, Oma, it worked after the factory reset.
Lineage boots, but it is very buggy.
- No camera (as could be expected)
- Spontaneous reboots
- No auto-rotation, device stays in portrait mode.
- No 5 GHz wifi networks.
- Freezing system UI
- No MTP
- Nonresponsive apps.
So it might work for an Ifive Air, but a Haier Pad 971 seems to be another ballgame.
Sounds more like a corrupted partition. Pls try again, incl. Lower Format. Use the pack as is. In TWRP format data and do a factory reset.
2016/05/02
Reflashed, did lower format. Wiped afterwards, and did a factory reset.
Some improvement, but:
- No camera. Tried to install the camfix with TWRP (3.0.2.0), but TWRP spontaneously reboots before the zip file installs.
- No 5GHz WiFi.
- No auto rotation, device stays in portrait modus.
- Restart didn't work, the device switches off, had to manually restart a few times.
- No MTP, USB configuration stays in charging mode.
80 Guest(s)
2 Guest(s)
Devices in use: Desktop (71), Phone (9)
cutierogue
hans41
rickybk
