A few more parts (install via TWRP):
- add Gello browser (in latest build already included)
- add HexoLibre - CM13 dark theme
- add Snap - just a test, do not use the Videocam
No. binj kernel is for binj tab 😉
No, it is not a clone. It is a cheap 7.9" tab, which is pretty perfect now 🙂
lurchi63 said
Me too. My Haier 971 with 16 GB works very fine. Many thanks for your Work Oma.
Fine. A few guys reporting BT not working with the stock LP firmware. Anything ok here?
Great. Thank you for feedback!
2016/08/01
No, it is not a clone. It is a cheap 7.9" tab, which is pretty perfect now 🙂- Oma -
Oh. Maybe you should create a specific topic for it then, instead of publishing here in the iFive Air CM13 topic? I don't know...
Haier Pad971 [(16 GB version) – CrewRKTablets RK32 Air CM13 build v1.3 (CyanogenMod 13.0, Android Marshmallow 6.0.1)]
2016/08/01
A little question: is there a way to change the "Rockchip Kernel" boot logo back to the original one (Haier in my case) or to another logo altogether? Thx!
@Oma : this 1.3 revision is absolutely brilliant, works like a charm on my Haier Pad971. Keep up the good work! 🙂
2016/09/19
Hi everybody and many thanks to Oma for this Rom
it works perfect on my Haier PAD971 ; after installing this CM13 rom it's like i have a new device.. 😉
I tried to install Magisk V6 to use it with Xposed Framework in Systemless version.
(http://forum.xda-developers.com/android/software/mod-magisk-v1-universal-systemless-t3432382)
Unfortunately, the tab don't boot after flashing Magisk in TWRP mode.
The tab stay blocked with logo Rockchip and it was not possible to access to TWRP menu to restore a backup..
However it's fortulately possible to reflash the rom with AndroidTool.exe (ouf 🙂 )
So i would like to know if it will be possible to use Magisk with this rom and if not if there is another rom i can use for that on my device
Thanks all
No need for systemless stuff. The build is not locked in any way. Pls use the Xposed framework linked in post #1.
271 Guest(s)
Devices in use: Desktop (87), Phone (184)
JEssicannn: 279
AnnaStockm
IAmTheOne86
tkowalski
Devlin
gitidi3813
goliad
Topics: 6129
Members: 266802
