Lost password?
The forums are currently locked and only available for read only access
[ RK3288 ROM ] IFive Air CM13 6.0.1 custom root firmware (2016/02/02)
This topic is locked
SbM_
Forum Posts: 24
91
2016/08/02 - 18:30
OK I'll upload a zip archive containing these 5 partitions. Might take some time though as my upload speed is quite slow and it's a 1.02 GB archive. 🙂
Haier Pad971 [(16 GB version) – CrewRKTablets RK32 Air CM13 build v1.3 (CyanogenMod 13.0, Android Marshmallow 6.0.1)]
SbM_
Forum Posts: 24
92
2016/08/02 - 23:06
Done. I've just sent you a private message with the download link. 🙂
Forum Posts: 6314
93
2016/08/03 - 20:21
Thanks! Download again and try: http://crewrktablets.arctablet.com/?wpfb_dl=2928
SbM_
Forum Posts: 24
94
2016/08/03 - 20:33
Seems to work better, but it still sometimes adds weird artefacts (I sent you a link to a pic to show you).
Forum Posts: 6314
SbM_
Forum Posts: 24
96
2016/08/03 - 21:43
Still the same artefacts, unfortunately...
Forum Posts: 6314
SbM_
Forum Posts: 24
98
2016/08/03 - 22:07
Tells me it can't connect to the camera 🙁
Tell me: when I install your fix(es), do I have to do anything else than flashing your .zip file (like wipe cache or something)?
Also until you find the solution, maybe we should continue through private messages instead of "polluting" this thread? What do you think?
Forum Posts: 6314
99
2016/08/03 - 22:18
Ok, we need a proper kernel driver. Here is the HaierPad kernel #75: http://crewrktablets.arctablet.com/?wpfb_dl=2931
You can flash it separately. Copy kernel and resource to folder rockdv/Images and just untick all other options.
v1.3_haierpad.pngImage Enlarger
hotte1983
Forum Posts: 20
100
2016/08/04 - 14:54
Can i have the Original backup.img/rom from the Haier Pad 971 (downloadlink)?
You can send me as Email.
SbM_
Forum Posts: 24
101
2016/08/04 - 15:05
Hi!
"Can't connect to the camera" again 🙁
And the battery indicator seems stuck at 100%. 🙁
Should I wipe some cache or something?
@hotte1983: sent via PM. 🙂
Forum Posts: 6314
102
2016/08/04 - 15:47
No, not necessary. Pls try again: http://crewrktablets.arctablet.com/?wpfb_dl=2932
SbM_
Forum Posts: 24
103
2016/08/04 - 16:08
Still the same "can't connect" error.
And there's definitely something wrong with the battery indicator : now it says 19%, then 16% then 19% again... and there's not entry for Battery prefs in the settings panel.
Forum Posts: 6314
104
2016/08/04 - 16:11
Last try, download again: http://crewrktablets.arctablet.com/?wpfb_dl=2932
SbM_
Forum Posts: 24
105
2016/08/04 - 16:18
OK now it connects to the camera, but I still get the same artefacts on pictures. Could it be that my camera itself is faulty? I must admit I haven't used it a lot with the stock ROM...
326 Guest(s)
2 Guest(s)
Devices in use: Desktop (82), Phone (244)
JEssicannn: 279
AnnaStockm
IAmTheOne86
tkowalski
Devlin
gitidi3813
goliad
Topics: 6129
Members: 266802
