[ RK3288 ROM ] IFive Air CM13 6.0.1 custom root firmware (2016/02/02)
46
2016/06/10 - 20:18
This fix just contains the stuff prepared by snailgary in post #29. It could however be there are different hardware revisions (minor differences i.e. other cam) in the field. And be in mind you are running a strange kernel on the HaierPad.
-Oma -
47
2016/06/10 - 20:21
PLanB2007 said
Ya indeed its a strange problem... Maybe I should mention it is a Haierpad 971 and I had the same problem with the stock ROM too.
New information. This indicates a hardware issue. If the LP build works for you stay with it.
hotte1983
Forum Posts: 20
48
2016/06/10 - 20:23
i hope you find the Problem, i can you understand its not easy to find this bug, i wish you luck greeting from germany
hotte1983
Forum Posts: 20
49
2016/06/10 - 20:29
on my Haier Pad 971 original rom worked the cams i update your firmware (OMA custom) and i have the problem whit the cams and youtube playback no 60 fps.
Unfortunately no have the Backup from the Haierpad stock rom ,shit.
PLanB2007
50
2016/06/10 - 20:56
Well of course this is a possibility. But is a hardware issue definetly reasonable? Cause its only the playstore...
EDIT: Does someone have the Haierpad Stock Rom? So I would be able to open a call on my distributor about this issue.
51
2016/06/10 - 21:12
I agree not very lilkely. However, the issue (connection) is there in more then one firmware.
Perdigon55
Forum Posts: 17
52
2016/06/12 - 22:15
Hello fellow , thanks for the rom . I have just installed version 1.1 and fix the camera for Haier Pad 971. With regard to the
camera to say according to camera app you install from google store you work the right front camera or vice versa . For example,
with Mx camera app Appic Labs Corp. of placing the tablet landscape looks right image and the app Open House of Mark Harman if
you have the tablet in portrait image recording backwards . I have noticed that the module com.android.camara2 not let me select it
as an option when get a menu to choose which app you want to open .
On the other hand the sound recording app closes when used , have installed other google app store and work well. I keep trying
their hard work . Thank you and sorry for use google translator.
hotte1983
Forum Posts: 20
53
2016/06/14 - 12:04
i found a lot of driver for RK Bord i hope this is usefull for """camera fix"""", can anyone test / try ?
included :"camera rk 30 board .so" / a lot of : "OV  ...  .so" driver and other driver
http://expirebox.com/download/7e023217e2c63a34d2e164d508da2702.html
extract with winrar
thanks to snailgary for the last workWink
Perdigon55
Forum Posts: 17
54
2016/06/15 - 22:47
Hi mate, I would like to use, but not what I have to do with that file winrar . Thank you.
hotte1983
Forum Posts: 20
55
2016/06/17 - 03:22
the last link dont work ,here the new link ....plz test / try to fix the Cams!
http://wikisend.com/download/529972/hw.rar
hotte1983
Forum Posts: 20
56
2016/06/18 - 17:03
i think anyone can use the cam driver (rar file) to intigrate in the cam fix .zip and
remedy the backcam problem?
2 megapixel Cam's are from factory "Omniversion" http://www.ovt.com/products/category.php?id=10
i dont know wich cam driver is correct ?!?!?!
can anyone search the correct driver for the Cam's....
StardustOne
57
2016/06/18 - 18:14
Could someone please fix this mess with this V1.1 ROM please?
There are so many security vulnerablility issues, unbelievable that those are still in this ROM.
Screenshot_20160618-181001.pngImage Enlarger
58
2016/06/18 - 18:48
Security patch level of this build is 1 March 2016. Your picture shows later found bugs. There is however nothing which makes me nervous. Other apps detects nothing. So, one may not follow each hype 😉
v1.1_06.pngImage Enlarger
PLanB2007
59
2016/06/19 - 13:16
I would like to bring this topic up once again. I did some research and figured some things out.
When flashing the original chinese firmware 4.4 (for example this ROM from XDA F405_V1.1.2_201508111400_AP6330_8858_99252_2155_VTL_GOODIX.img)  PlayStore is working for me. So despite PlayStore wasn't working on the haier971 firmware it is on the original Chinese one.
I also tried to flash your CM13 ROM and update the PlayStore Tools by myself. So I deleted all the related files using the adb shell and flashed the Opengapps Pico version. Although this worked I was again unlucky login in to google / failed to establish a reliable connection to the server.
In addition I tried the official Android 6 dev-ROM. Here I wasn't able to flash the Opengapps due the lack of a working custom recovery. I tried to use the TWRP you offer with this ROM which did not work, as I assume, because of the different partition layout of these two ROMs.
I know this is not necessary related to your ROM but maybe you, as a developer, can give me some hints how to debug the problem. Is there any possibility to get some logfiles or strace the applications? Despite I know a lot about Linux I'm new to Android.
60
2016/06/19 - 14:46
Sure. Here is our AOSP build, or if you'd like the MM build . Both are including TWRP, SuperSU and google stuff.
68 Guest(s)
Devices in use: Desktop (66), Phone (2)
trroll171717
alsoft75
Deaker
Gorael
WhiteD2125
Bokser
