[ RK3288 ROM ] IFive Air CM13 6.0.1 custom root firmware (2016/02/02)
31
2016/05/02 - 21:17
Cam will not show up when hardware is not detected. Maybe the lens is the issue. The stock cam_board.xml (or better the full system) would help to analyse. Try this: http://www.arctablet.com/blog/forum/rk3288-entwicklung-und-customroms-development-and-croms/rk3288-root-and-dump-the-stock-firmware/?lang=fr
CurvedAir
Forum Posts: 30
32
2016/05/02 - 21:35
Snailgary: Back-camera is working indeed. Using 'Open Camera' app front camera cannot be monitored, using the switch button no front camera is shown either.
Thanks for the XML. 😉
CurvedAir
Forum Posts: 30
33
2016/05/02 - 22:56
Two rear facing camera's detected, that's the trouble.
shot_2016-05-02_22-41-41.pngImage Enlarger
MasinAD
34
2016/05/13 - 15:02
today, I installed your ROM and it works great, much better than the original ROM.
But how do I get root? I tried SuperSU with normal binary installation, SuperSU with TWRP binary installation – to no avail. What am I missing?
Masin
35
2016/05/16 - 08:43
Thank you for feedback!
Build is rooted by default with CM superuser. You can enable it in settings/developer options (see also "some hints for basic settings.txt" in the download pack).
PLanB2007
36
2016/06/09 - 10:22
Hey there!
First of all, thank you for your great work!
I was using the "Oma's 5.1.1 Custom v1.0 (based on 2.0.3)" Rom before.
After flashing your CM13 Rom I'm not able to connect to the Play Store anymore (see attached Screenshot).
Screenshot_20160609-101226.pngImage Enlarger
I tried to do a factory reset, flash another Rom and checked the /etc/hosts (which is empty except the local host lines.) without any success.
Do you have any suggestions how to solve this problem?
Best regards,
PLanB
37
2016/06/09 - 17:20
Nothing to do with the host file. I do not see wlan connection on your screenshot.
PLanB2007
38
2016/06/09 - 22:04
Wifi is working without any flaws... It was just disabled when I did the screenshot. I could take another screenshot containing the wifi icon or browsing the web. This is working without any problems.
The only issue is the google play service. Is it possible to reinstall the google play services or update it?
39
2016/06/09 - 22:15
I guess this is only a timing issue. After first boot up wait until the Play Store is updated. Then load google apps until gmscore will be updated.
PLanB2007
40
2016/06/09 - 22:26
If I go back to Oma_RK32_Ifive_Air_LP_5.1.1_v1.1 play Service is working again. Couldn't get it work for all your Android 6 based Roms.
Is it possible that some (probably wrong) settings are saved even after wiping the device? If yes, is there a way to get the device back to 100% Stock? I remember having an similar issue back then, when I was flashing CM11 on my S4 Mini. When I flashed the stock image afterwards I had to do some hacks / terminal commands to get NFC working again.
Okay, just saw your new post. Is Play Store updating without being logged in? I will give it another try and flash the CM13 6.0.1 Image, log into WiFi and give it some time. I assume I do not have to flash the v1.0 before flashing v1.1, right?
Thanks for your support!
EDIT:
Hey there. I flashed the rom yesterday again and waitet, but still I'm not able to connect to play Store. Wifi and surfing through the web is working fine. (See attached Screenshots)
Screenshot_20160610-123408.pngImage EnlargerScreenshot_20160610-123708.pngImage Enlarger
Any further suggestions?
hotte1983
Forum Posts: 20
41
2016/06/10 - 15:54
back Cam not working ....WHY on CM13 601, i install the fix for front Cam this is working ...Back Cam not working plz fix it
Haier Pad 971 original rom has Youtube playback in 60 fps by CM 13 601 or MM 601 not working 60 fps.
all other is Working thanks for the great job
42
2016/06/10 - 17:28
Pls install this via TWRP: http://crewrktablets.arctablet.com/?wpfb_dl=2869
43
2016/06/10 - 17:32
Curious. Just installed the CM13 build v1.1 and works flawlessly here.
v1.1_05.pngImage Enlargerv1.1_05a.pngImage Enlargerv1.1_05b.pngImage Enlargerv1.1_05c.pngImage Enlargerv1.1_05d.pngImage Enlarger
PLanB2007
44
2016/06/10 - 19:17
Ya indeed its a strange problem... Maybe I should mention it is a Haierpad 971 and I had the same problem with the stock ROM too.
First I wanted to send it back but before I wanted to try another ROM and your 5.1 ROM worked like a charm. Sadly the 6.0 ROM isn't working... I'm not sure why it is working with the other ROM.
Maybe its not a specific ROM problem but I don't know how to debug the problem.
hotte1983
Forum Posts: 20
45
2016/06/10 - 19:57
i install the TWRP: http://crewrktablets.arctablet.com/?wpfb_dl=2869
front cam is working ,but the image is reversed backcam is not working , and i have no Cam app on the Device ,i install a many cam apps on the device all have only front cam (selfi cam) . And i con not install Google Camera app dont list in the PlaystoreCry
my device installed firmware:
v1.1 improve UI performance
v1.1 fix for audio settings, touch volume, auto brightness
CrewRKTablets RK32 Air MM 6.0.1 build v1.1
and your cam fix . zib
greeting
67 Guest(s)
Devices in use: Desktop (65), Phone (2)
trroll171717
alsoft75
Deaker
Gorael
WhiteD2125
Bokser
