ย Please donate to support OMA and CrewRKTablets firmware work, thank you !
[ RK3288 ROM ] IFive Air CM13 6.0.1 custom root firmware (2016/02/02)
lostinspace
2016/04/18 - 22:12
Yes, no connection or cam in use says every App I have testet so far.
snailgary
2016/04/19 - 21:07
Hi, I am new to android hacking, but had partial success with the Haierpad 971 front camera.
Here is the cam_board.xml from Android 5.1.1 stock rom: cam_board.xml
The front cam is using GC2155 hardware while the back cam seems to have OV2680 chipset. Unfortunately the CM13 rom is missing libisp_isi_drv_OV2680.so driver lib. Also when back cam is not found, the lockscreen camera icon crashes (don't know if that can be prevented in a "cleaner" way than my solution below..)
However by adding the stock's GC2155 section to cam_board.xml with the following modifications, the front cam will be usable for skype at least.
<SensorFacing facing="back"></SensorFacing>
<SensorOrientation orientation="90"></SensorOrientation
Note: since front camera is now treated as "back", image will be upside down in portrait positions. (Landscape mode works fine for me.)
ย
I suspect that the real back camera can be made to work if the missing hardware driver is found/compiled... but my skills are not good enough for this yet ๐Ÿ™‚
2016/04/19 - 21:43
Pls test.
lostinspace
2016/04/19 - 21:58
I thank you both for the efforts.
@snailgary: can you tell me where you have exactly inserted this lines?ย
<?xml version="1.0" ?>
<BoardFile>
<BoardXmlVersion version="v0.0xd.0">
</BoardXmlVersion>
<CamDevie>
<HardWareInfo>
<Sensor>
<SensorName name="OV8858" ></SensorName>
` <SensorLens name="SUNNY-3813A"></SensorLens>
<SensorDevID IDname="CAMSYS_DEVID_SENSOR_1B"></SensorDevID>
<SensorHostDevID busnum="CAMSYS_DEVID_MARVIN" ></SensorHostDevID>
<SensorI2cBusNum busnum="3"></SensorI2cBusNum>
<SensorI2cAddrByte byte="2"></SensorI2cAddrByte>
<SensorI2cRate rate="100000"></SensorI2cRate>
<SensorMclk mclk="24000000"></SensorMclk>
<SensorAvdd name="NC" min="0" max="0"></SensorAvdd>
<SensorDovdd name="NC" min="18000000" max="18000000"></SensorDovdd>
<SensorDvdd name="NC" min="0" max="0"></SensorDvdd>
<SensorGpioPwdn ioname="RK30_PIN2_PB7" active="0"></SensorGpioPwdn>
<SensorGpioRst ioname="RK30_PIN2_PB6" active="0"></SensorGpioRst>
<SensorGpioPwen ioname="RK30_PIN0_PC1" active="1"></SensorGpioPwen>
<SensorInterface interface="MIPI"></SensorInterface>
<SensorMirrorFlip mirror="0"></SensorMirrorFlip>
<SensorOrientation orientation="90"></SensorOrientation>
<SensorPowerupSequence seq="1234"></SensorPowerupSequence>
<SensorFovParemeter h="60.0" v="60.0"></SensorFovParemeter>
<SensorAWB_Frame_Skip fps="15"></SensorAWB_Frame_Skip>
<SensorPhy phyMode="CamSys_Phy_Mipi" lane="2" phyIndex="1" sensorFmt="CamSys_Fmt_Raw_10b"></SensorPhy>
</Sensor>
<VCM>
<VCMDrvName name="BuiltInSensor"></VCMDrvName>
<VCMName name="NC"></VCMName>
<VCMI2cBusNum busnum="3"></VCMI2cBusNum>
<VCMI2cAddrByte byte="0"></VCMI2cAddrByte>
<VCMI2cRate rate="0"></VCMI2cRate>
<VCMVdd name="NC" min="0" max="0"></VCMVdd>
<VCMGpioPwdn ioname="NC" active="0"></VCMGpioPwdn>
<VCMGpioPower ioname="NC" active="0"></VCMGpioPower>
<VCMCurrent start="10" rated="100" vcmmax="100" stepmode="4" drivermax="100"></VCMCurrent>
</VCM>
<Flash>
<FlashName name="NC"></FlashName>
<FlashI2cBusNum busnum="0"></FlashI2cBusNum>
<FlashI2cAddrByte byte="0"></FlashI2cAddrByte>
<FlashI2cRate rate="0"></FlashI2cRate>
<FlashTrigger ioname="NC" active="0"></FlashTrigger>
<FlashEn ioname="NC" active="0"></FlashEn>
<FlashModeType mode="1"></FlashModeType>
<FlashLuminance luminance="0"></FlashLuminance>
<FlashColorTemp colortemp="0"></FlashColorTemp>
</Flash>
</HardWareInfo>
<SoftWareInfo>
<AWB>
<AWB_Auto support="1"></AWB_Auto>
<AWB_Incandescent support="1"></AWB_Incandescent>
<AWB_Fluorescent support="1"></AWB_Fluorescent>
<AWB_Warm_Fluorescent support="1"></AWB_Warm_Fluorescent>
<AWB_Daylight support="1"></AWB_Daylight>
<AWB_Cloudy_Daylight support="1"></AWB_Cloudy_Daylight>
<AWB_Twilight support="1"></AWB_Twilight>
<AWB_Shade support="1"></AWB_Shade>
</AWB>
<Sence>
<Sence_Mode_Auto support="1"></Sence_Mode_Auto>
<Sence_Mode_Action support="1"></Sence_Mode_Action>
<Sence_Mode_Portrait support="1"></Sence_Mode_Portrait>
<Sence_Mode_Landscape support="1"></Sence_Mode_Landscape>
<Sence_Mode_Night support="1"></Sence_Mode_Night>
<Sence_Mode_Night_Portrait support="1"></Sence_Mode_Night_Portrait>
<Sence_Mode_Theatre support="1"></Sence_Mode_Theatre>
<Sence_Mode_Beach support="1"></Sence_Mode_Beach>
<Sence_Mode_Snow support="1"></Sence_Mode_Snow>
<Sence_Mode_Sunset support="1"></Sence_Mode_Sunset>
<Sence_Mode_Steayphoto support="1"></Sence_Mode_Steayphoto>
<Sence_Mode_Pireworks support="1"></Sence_Mode_Pireworks>
<Sence_Mode_Sports support="1"></Sence_Mode_Sports>
<Sence_Mode_Party support="1"></Sence_Mode_Party>
<Sence_Mode_Candlelight support="1"></Sence_Mode_Candlelight>
<Sence_Mode_Barcode support="1"></Sence_Mode_Barcode>
<Sence_Mode_HDR support="1"></Sence_Mode_HDR>
</Sence>
<Effect>
<Effect_None support="1"></Effect_None>
<Effect_Mono support="1"></Effect_Mono>
<Effect_Solarize support="1"></Effect_Solarize>
<Effect_Negative support="1"></Effect_Negative>
<Effect_Sepia support="1"></Effect_Sepia>
<Effect_Posterize support="1"></Effect_Posterize>
<Effect_Whiteboard support="1"></Effect_Whiteboard>
<Effect_Blackboard support="1"></Effect_Blackboard>
<Effect_Aqua support="1"></Effect_Aqua>
</Effect>
<FocusMode>
<Focus_Mode_Auto support="1"></Focus_Mode_Auto>
<Focus_Mode_Infinity support="1"></Focus_Mode_Infinity>
<Focus_Mode_Marco support="1"></Focus_Mode_Marco>
<Focus_Mode_Fixed support="1"></Focus_Mode_Fixed>
<Focus_Mode_Edof support="1"></Focus_Mode_Edof>
<Focus_Mode_Continuous_Video support="0"></Focus_Mode_Continuous_Video>
<Focus_Mode_Continuous_Picture support="0"></Focus_Mode_Continuous_Picture>
</FocusMode>
<FlashMode>
<Flash_Mode_Off support="1"></Flash_Mode_Off>
<Flash_Mode_On support="1"></Flash_Mode_On>
<Flash_Mode_Torch support="1"></Flash_Mode_Torch>
<Flash_Mode_Auto support="1"></Flash_Mode_Auto>
<Flash_Mode_Red_Eye support="1"></Flash_Mode_Red_Eye>
</FlashMode>
<AntiBanding>
<Anti_Banding_Auto support="1"></Anti_Banding_Auto>
<Anti_Banding_50HZ support="1"></Anti_Banding_50HZ>
<Anti_Banding_60HZ support="1"></Anti_Banding_60HZ>
<Anti_Banding_Off support="1"></Anti_Banding_Off>
</AntiBanding>
<HDR support="1"></HDR>
<ZSL support="1"></ZSL>
<DigitalZoom support="1"></DigitalZoom>
<Continue_SnapShot support="1"></Continue_SnapShot>
<InterpolationRes resolution="0"></InterpolationRes>
<PreviewSize width="0" height="0"></PreviewSize>
<FaceDetect support="0" MaxNum="1"></FaceDetect>
<Cproc support="1" contrast="1.1" saturation="1.0" hue="0" brightness="0"></Cproc>
<Gammaout support = "0" gamma = "1.0" offset = "0"></Gammaout>
<DV>
<DV_QCIF name="qcif" width="176" height="144" fps="10" support="1"></DV_QCIF>
<DV_QVGA name="qvga" width="320" height="240" fps="10" support="1"></DV_QVGA>
<DV_CIF name="cif" width="352" height="288" fps="10" support="1"></DV_CIF>
<DV_VGA name="480p" width="640" height="480" fps="10" support="0"></DV_VGA>
<DV_480P name="480p" width="720" height="480" fps="10" support="0"></DV_480P>
<DV_720P name="720p" width="1280" height="720" fps="10" support="1"></DV_720P>
<DV_1080P name="1080p" width="1920" height="1080" fps="10" support="1"></DV_1080P>
</DV>
</SoftWareInfo>
</CamDevie>
<CamDevie>
<HardWareInfo>
<Sensor>
<SensorName name="NT99252" ></SensorName>
<SensorDevID IDname="CAMSYS_DEVID_SENSOR_1A"></SensorDevID>
<SensorGpioPwdn ioname="RK30_PIN2_PB6" active="1"></SensorGpioPwdn>
<SensorGpioRst ioname="NC" active="0"></SensorGpioRst>
<SensorFacing facing="front"></SensorFacing>
<SensorInterface mode="CCIR601"></SensorInterface>
<SensorOrientation orientation="270"></SensorOrientation>
<SensorAWB_Frame_Skip fps="4"></SensorAWB_Frame_Skip>
<SensorPhy phyMode="CamSys_Phy_Cif" sensor_d0_to_cif_d ="0" cif_num="0" sensorFmt="CamSys_Fmt_Raw_10b"></SensorPhy>
</Sensor>
<VCM>
<VCMDrvName name="NC"></VCMDrvName>
<VCMI2cBusNum busnum="0"></VCMI2cBusNum>
<VCMCurrent start="20" rated="80" vcmmax="100" stepmode="13" drivermax="100"></VCMCurrent>
</VCM>
<Flash>
<FlashTrigger ioname="NC" active="1"></FlashTrigger>
<FlashEn ioname="NC" active="1"></FlashEn>
<FlashModeType mode="0"></FlashModeType>
</Flash>
</HardWareInfo>
<SoftWareInfo>
<AWB>
</AWB>
<Sence>
</Sence>
<Effect>
</Effect>
<FocusMode>
<Focus_Mode_Auto support="0"></Focus_Mode_Auto>
<Focus_Mode_Infinity support="0"></Focus_Mode_Infinity>
<Focus_Mode_Marco support="0"></Focus_Mode_Marco>
<Focus_Mode_Fixed support="0"></Focus_Mode_Fixed>
<Focus_Mode_Edof support="0"></Focus_Mode_Edof>
</FocusMode>
<FlashMode>
</FlashMode>
<AntiBanding>
</AntiBanding>
<InterpolationRes resolution="8000000"></InterpolationRes>
<PreviewSize width="800" height="600"></PreviewSize>
<FaceDetect support="0" MaxNum="0"></FaceDetect>
<DV>
<DV_VGA name="480p" width="640" height="480" fps="10" support="1"></DV_VGA>
</DV>
</SoftWareInfo>
</CamDevie>
</BoardFile
snailgary
2016/04/21 - 20:29
Oma: Thanks for the file! Sad to say that it did not work as I hoped... ๐Ÿ™ Right now I am a bit lost on how to debug this stuff. For reference I have attached the dmesg output from both haierpad stock firmware and from CM13. CM13 just seems to fail initializing the second camera.
I could do more tests or provide more data if needed.
ย
@lostinspace: You could modify lines 419 and 422 of the file I linked in my first post. Or even easier: just replace your /etc/cam_board.xml with this file.
Better backup/rename the original file first. Also make sure that the access permissions of the file are at least set to -rw-r--r-- (= bitmask 644)! Otherwise your pad's user interface might not start.
After reboot, the builtin camera tool should at least display the front camera image. Note there will still be no camera icon in the apps section.. use the camera icon on the lockscreen.
Hope this helps.
lostinspace
2016/04/23 - 21:41
snailgary: THX!!!
2016/05/01 - 16:53
Update post #1 with small fix for audio settings, touch volume, auto brightness.
v1.3_16.pngImage Enlargerv1.3_21.pngImage Enlargerv1.3_23.pngImage Enlarger
CurvedAir
2016/05/01 - 17:21
Pls test this cam fix for Haierpad 971: http://crewrktablets.arctablet.com/?wpfb_dl=2869
CurvedAir
lostinspace
2016/05/01 - 19:08
Thank you! The front camera is now working, but the image is reversed. The rear camera is not working. Thanks again for your effort.
CurvedAir
Forum Posts: 30
2016/05/02 - 15:51
shot_2016-05-02_12-45-38.pngImage Enlargershot_2016-05-02_12-47-30.pngImage Enlargershot_2016-05-02_12-51-45.pngImage Enlarger
Another confirmed install on Haier Pad 971, or even better, two. Cyanogen as well as AOSP did fine. Just two minor remarks: rear camera not working (no driver installed, I suppose), Cyanogen update not working: internet connection not found. Cores @ 1.8 Ghz, benchmark improvements. See attachments, some Dutch language is used.
ย
Let's hear it for Oma and his team, you guys rock!
shot_2016-05-02_12-54-35.pngImage Enlargershot_2016-05-02_12-45-06.pngImage Enlarger
The following users say thank you to CurvedAir for this useful post:
2016/05/02 - 18:34
Thank you for feedback! Where can I find the Haier Pad 971 stock firmware?
CurvedAir
Forum Posts: 30
2016/05/02 - 19:12
Can't help you with that, Oma, lookin' for that myself. Had no idea how to Back up the Haier installation, so i took a jump by installing another ROM.
snailgary
2016/05/02 - 20:55
Hi all, there's good news for the haierpad back camera! It works (mostly..) ๐Ÿ™‚
For some reason, it requires two things: the OV2680.so driver that is installed with Oma's cam fix, but also the 'OV5648' device section that was included in my modified cam_board.xml from above.
ย
@Oma: Please add the <CamDevie> section which contains the <SensorName name="OV5648"...> to your fix (or just use my file if you like)
ย
Minor drawbacks exist:
  • The builtin camera app is unable to switch between cameras - no switch icon found. (No idea why..) I installed OpenCamera instead and there everything works fine.
  • Front camera is still upside down in portrait mode. The camera still needs to be marked as "back" or else the builtin camera app just crashes. Also skype does not seem to work with the original orientation. However Skype also shows upside down image in portrait mode on a stock Haierpad... so nothing is lost ๐Ÿ™‚
The following users say thank you to snailgary for this useful post:
CurvedAir
snailgary
2016/05/02 - 21:14
I got a second Haierpad which is still in its sealed box. What is the best way to dump firmware without changing anything?
69 Guest(s)
Devices in use: Desktop (67), Phone (2)
trroll171717
alsoft75
Deaker
Gorael
WhiteD2125
Bokser
