[ RK3288 ROM ] IFive Air CM13 6.0.1 custom root firmware (2016/02/02)
151
2017/01/26 - 18:45
This big file is corrupted somehow. Can the guy please copy the two folders:
- /system/etc
- /system/lib
Perdigon55
Forum Posts: 17
152
2017/01/26 - 20:47
- /system/etc
- /system/lib
Hi Oma7144, I had to install and then extract those files. Here you go. A greeting
/system/etc and /system/lib
153
2017/01/26 - 20:58
Cams are identical. The cam fix from post #1 should work.
Perdigon55
Forum Posts: 17
154
2017/01/26 - 23:46
Hi Oma7144, the camera fix works perfect. The problem is when I install the kernel # 74
with which the bluetooth works, at that moment the tablet stays on the screen Rockchip Kernel
and does nothing more. A greeting.
155
2017/01/27 - 17:26
Curious. You got the same effect by
a) istalling the build with kernel #74 and then install the cam fix from post #1
b) installing the build with kernel #75 and cam fix from post #1 and then install kernel #74?
Perdigon55
Forum Posts: 17
156
2017/01/27 - 20:36
Hi Oma7144 if I install only the kernel does not start and if I put the kernel with the resourse
that corresponds with the kernel starts # 75 but with # 74 no. Then if I install the fix of the camera
it stays in a loop of initiating app and it does not leave it.
I will stick with 5.1.1 that everything is resolved. Thank you.
TeutonJon78
Forum Posts: 26
157
2017/02/18 - 04:11
I noticed the CM 13 1.4 build wasn't linked any more --- is there a problem with the build that it needed to be pulled for?
iFive Air (32GB) - XDA Discussion -- (including my iFive Air Nexus ROMs based on stock)
SbM_
Forum Posts: 24
158
2017/04/25 - 17:31
Same question here. I downloaded 1.4 back when it came out but never took the time to install it. Now I want to do it but noticed it's not linked anymore in the first post. Is there something wrong with it, should I stick to 1.3?
Haier Pad971 [(16 GB version) – CrewRKTablets RK32 Air CM13 build v1.3 (CyanogenMod 13.0, Android Marshmallow 6.0.1)]
reut3145
159
2017/04/27 - 13:54
Hi! Can anyone help with porting Android a newer version of the Archos 101 oxygen?? Have on hand the source code provided by the Russian representative of the manufacturer.You can download it via the link https://yadi.sk/d/Y2BhpUYC3GyLYH I do not know how, but willing to test the new build ))
86 Guest(s)
Devices in use: Desktop (83), Phone (3)
ferguiston
garant1
Androidos
fy789tr678
desluk
cimoral
