Lost password?
The forums are currently locked and only available for read only access
[ RK3288 ROM ] IFive Air CM13 6.0.1 custom root firmware (2016/02/02)
This topic is locked
webfred
136
2016/10/05 - 09:46
hi, thanks for the feedback.
The reason to use Systemless is because some applications like Pokemon Go use Safetynet API to check the device.
If the device is rooted or if it detect Xposed framework installed on it, application don't start and give a message "incompatible device"
Magisk and Xposed systemless can bypass that by hiding the root and Xposed framework.
I will try another way that works fine on my Samsung Phone without Magisk,
by installing SuperSu 2.78 + Suhide 0.53 + Xposed Systemless and i will see, perhaps that will works.
TeutonJon78
Forum Posts: 26
137
2016/10/06 - 02:00
This tablet doesn't even have GPS so it can't play Pokemon Go anyway, nor NFC for things like Android pay, the other thing that typically trips on root being present.
Built in root is part of CM.
iFive Air (32GB) - XDA Discussion -- (including my iFive Air Nexus ROMs based on stock)
Forum Posts: 6314
138
2016/10/08 - 21:38
Some love for the Air 😉
Update post 1 with build v1.4. CM October Sources and Security Patches. Update by flashing boot and system.
v1.4.pngImage Enlarger
TeutonJon78
TeutonJon78
Forum Posts: 26
139
2016/10/11 - 19:36
Oma, I noticed the resources.img was different as well -- what's new in that?
Thanks for the work!!
Forum Posts: 6314
140
2016/10/13 - 17:35
It is just the missing battery day-dream.
master-w
Thanks Received: 4
141
2016/10/26 - 12:44
I have the Haier 971 tablet and forgot to save the original stock rom. Can somebody provide this one as download. I want to go back to stock. Also I have screen flicker problems with the CM13 build is there an workaround available?
regards René
The following users say thank you to master-w for this useful post:
Perdigon55
o0radryan0o
Forum Posts: 11
142
2016/11/11 - 22:02
Is there a problem with the D/L links on the first post?
Forum Posts: 6314
143
2016/11/11 - 22:33
The server is down. Try again tomorrow.
buzzly
Forum Posts: 14
144
2016/11/21 - 16:08
Q on Binj XS
Get a new Bin XS.    Flashed IFive Air CM13 6.0.1  with replacement Binj Kernel and resource img file in the /rockdev/img folder
Everything works  except  there was no default camera app and "Can't connect to the camera" via Gallery app.   Installed Open Camera, also got an "Can't connect to the camera"
Did I mess up something?
pldmich
145
2016/11/22 - 03:41
No, don't believe anyone has ever got the camera working.
buzzly
Forum Posts: 14
146
2016/11/22 - 12:36
I thought by flashing the original Binj kernel and resource img, every hardware function should work.   I guess I have it wrong.
starger
147
2016/12/01 - 16:28
I just installed CM13 (build 1.3) on HaierPad 971 and the camera is working.
i used the included kernel and followed the included instructions.
I installed the cam fix via TWRP after wipe and before the first boot.
Perdigon55
Forum Posts: 17
148
2017/01/24 - 19:34
Hello @Oma7144 install this rom in Haier Pad 971 with kernel # 74 and the bluetooth works and
when installing the fix of the camera does not start the tablet or the reverse. If I install the camera
fix first, then the # 74 kernel does not start the tablet. Do you know why? Thanks for everything.
Forum Posts: 6314
149
2017/01/24 - 22:50
Can I have the dump of the system.img (corresponding to kernel #74)?
Perdigon55
Forum Posts: 17
150
2017/01/25 - 19:48
Hello Oma7144 I leave you the link of the companion that extracted it, they are 4gb.
If you have problems with this server I upload it to another. A greeting.
system.img Kernel #74
275 Guest(s)
Devices in use: Desktop (87), Phone (188)
JEssicannn: 279
AnnaStockm
IAmTheOne86
tkowalski
Devlin
gitidi3813
goliad
Topics: 6129
Members: 266802
