[ RK3288 ROM ] IFive Air CM13 6.0.1 custom root firmware (2016/02/02)
Thanks Received: 1385
2016/02/03 - 20:08
Gents,
CM13 has landed on iFive Air
kernel #16 with battery daydream (just replace kernel and resoure in folder rockdev/Image before flash)
CrewRKTablets RK32 Air MM 6.0.1 build v1.3 - CM August sources and security patches
CrewRKTablets RK32 Air MM 6.0.1 build v1.2 - CM June sources and security patches
v1.1 improve UI performance
v1.1 fix for audio settings, touch volume, auto brightness
CrewRKTablets RK32 Air MM 6.0.1 build v1.1 - CM March sources and security patches
CrewRKTablets RK32 Air MM 6.0.1 build v1.0
– stock recovery 5.0.0
– recovery TWRP 2.8.7.0
– recovery TWRP 3.0.0.0 [v1.1, v1.2]
– sekernel #33 @ 1.8 GHz
– unified storage
– Multi-Windows
– CM su, su-binary
Confirmed installation on:
- Haier Pad 971 (full clone, volume keys are swapped, cam fix)
- binj XS, kernel (just replace kernel and resoure in folder rockdev/Image before flash)
hints:
– enable rotation in launcher settings
– compatibility: Gameloft games, Viper4AndroidFX, Xposed Framework, Kodi 16.1 Jarvis, Netflix
– Oma's favourite apps for MM
– Xposed Framework starter pack
– Oma -
crew.pngImage EnlargerCM13_Air_01.pngImage EnlargerCM13_Air_04.jpgImage EnlargerCM13_Air_08.jpgImage EnlargerCM13_Air_11.jpgImage EnlargerCM13_Air_07.pngImage EnlargerCM13_Air_09.pngImage EnlargerCM13_Air_10.pngImage EnlargerCM13_Air_02.jpgImage EnlargerCM13_Air_12.jpgImage Enlarger
lostinspace, CurvedAir, starger, yoguis
TeutonJon78
Forum Posts: 26
2016/02/05 - 20:07
Awesome.  Where is the MM base coming from?
Also, if the new version of TWRP just for MM? I tried using the 2.8.7.0 on a 5.1.x base and it just bootlooped.
iFive Air (32GB) - XDA Discussion -- (including my iFive Air Nexus ROMs based on stock)
StardustOne
2016/02/06 - 16:00
This is not awesome, this is not working. The ROM cannot be downloaded.
File CrewRKTablets_RK32_IFive_Air_CM13_6.0.1_v1.0.7z not found!
TeutonJon78
Forum Posts: 26
2016/02/06 - 18:34
I just tried as well, and it's down. I'm uploading them right now to my MEGA repo if you want.
Thanks Received: 3170
2016/02/06 - 19:31
I have just tried the file from post #1: CrewRKTablets RK32 Air MM 6.0.1 build v1.0
No problem to download here, but I ended up with a corrupted file.
Which download error are you getting, is that a DNS error, a server error (like 404) or other problems like slow or corrupted downloads ?
Thanks for letting us know with details so we can try to fix the issue.
2016/02/07 - 14:25
Sorry guys. Downloads are back to normal now.
racht
2016/02/09 - 11:19
any progress with ifive mini4 roms?
TeutonJon78
Forum Posts: 26
2016/03/21 - 02:45
Oma, not sure if you noticed or not, but iFive released a 6.0.1 based dev image for the Air (dev 2.0). I've uploaded to my Mega drive already, so no need for Baidu.
It has an updated bootloader for sure (2.30.10), and I'd assume the kernel. It has all of the additions that the previous dev images had as well, so it has the more complete/working power settings as well.
Also, isn't the system image part the same across all the RK3288 boards (other than maybe the build.prop)? Maybe it would be lighten the load on you guys to just release a generic rk3288 6.0.x images and then have the download packs for each device. That way you wouldn't have to make a new base build for each device.
2016/04/02 - 11:42
Update post #1 with build v1.1 - CM March sources and security patches.
Updated Xposed starter pack: http://crewrktablets.arctablet.com/?wpfb_dl=2848
v1.1_01.pngImage EnlargerXposed_04.pngImage Enlarger
TeutonJon78
TeutonJon78
Forum Posts: 26
2016/04/02 - 19:47
Awesome, Oma. Thanks.
soeren
2016/04/08 - 13:24
thank you for this ROM. I have this running perfectly on my Haier Pad 971. The only problem I had was with switching the Tablet into Flash-Mode. The rokchip flashing program didn't automatically switch the table into flash mode. So I had to press Power + Vol *down* to get into flash mode. Power + Vol. up just loaded the recovery mode. Maybe you should add this to your instructions within the CM13 ROM download.
lostinspace
2016/04/16 - 21:39
Thanks for your great work! I can confirm it works perfectly on my Haier Pad971 including TWRP. For the Flash mode (Haier Pad971) you have to go into the boot loader. Will you continue your work? In Germany, the Haier Pad917 is just very convenient to buy.
2016/04/18 - 16:16
Thank you soeren and lostinspace for feedback on the Haier Pad 971! The kernel is looking for the keys, that's the reason why it is switch with the Air kernel. I use this build as my daily driver. So, yes it will be supported and updated if necessary.
lostinspace
2016/04/18 - 20:26
Thanks for the answer! Do you know any way to get the cameras to work?
I tried to find the original firmware for Haier Pad 971. So far without success. My Pad has 2x2 MP cameras. But there is also a version with an 8 MP rear camera.
2016/04/18 - 20:35
Difficult. Is there no connection to the cams, or what is the issue exactly?
78 Guest(s)
Devices in use: Desktop (70), Phone (7), Tablet (1)
jackthomas
hakhiem
jenom
kfwacky
fer30
culo1
