[ RK3288 ROM ] ifive Air AOSP 5.1.1 custom root firmware (2015/05/20)
NRKL
South KOREA
76
2015/09/12 - 12:31
Try again: http://crewrktablets.arctablet.com/?wpfb_dl=2647
Install this model fix in TWRP: http://crewrktablets.arctablet.com/?wpfb_dl=2648
I can go into developers mod. I turned on touch pointer setting. I think screen size is not correct and up,down,right,left side is reversed.
Also i failed to apply zip from TWRP cause i can't select install button both touch screen and volume key.
PS) volume key is not working
JochenKauz
Forum Posts: 450
Thanks Received: 76
77
2015/09/15 - 19:01
I think I need more exact values for the touch. Can you attach a mouse and install a multi touch app to get exact values what the touch reported as the touch point value? (https://play.google.com/store/apps/details?id=com.rn.yamtt&hl=de)
Please give me the x,y values on top, on bottom, right, left and middle of the screen.
Cheers
JochenKauz
NRKL
South KOREA
78
2015/09/17 - 12:34
JochenKauz said
Cheers
JochenKauz
sadly, i bought otg cable, but it is not working both mini4, Air kernel.
I checked otg cable working on original firmware.
Edited at KST: GMT+9 EST 21:30
I finally got my touch screen value
approximate value is calculated by myself cause i can't touch each side
제목-없음.pngImage Enlarger
MiGHT.
Germany
Forum Posts: 67
Thanks Received: 13
79
2015/09/22 - 16:05
Anything new in here?
NRKL
South KOREA
80
2015/09/23 - 20:48
Nothing changed.
I gave it few days ago, maybe he's working on it..?
The following users say thank you to NRKL for this useful post:
StardustOne
MiGHT.
Germany
Forum Posts: 67
Thanks Received: 13
81
2015/10/08 - 10:40
@JochenKauz
@Oma7144
...still no process?
82
2015/10/08 - 11:35
Unfortunately not. Without kernel sources and having the tab at hand this does not make sense. Sorry.
johnss74
83
2015/11/07 - 13:58
HELLO,OMA
Can you tell me ,how to root on 5.1.1,plase?
thanks!
alfyz
84
2015/12/04 - 14:42
hello but I can install this ROM on my tablet RK3066 mediacom 101 s2?
ThunderRoad
85
2015/12/13 - 16:41
Any chance we can get 32GB of internal memory?
86
2015/12/13 - 16:46
What do you like to do? What is limiting you?
ThunderRoad
87
2015/12/13 - 22:27
Usually you can't install apps in the flash storage, if you need to install more than 4gb of apps you can't.
88
2015/12/13 - 22:39
Well, larger apps will store its obb data on the internal sdcard (NAND flash). Only a base app is stored to the internal storage. So, everything is fine with the given partition layout.
ThunderRoad
89
2015/12/13 - 23:15
Uhmm not only the base app is stored in internal storage, a lot of apps' data cant be moved to the sd (i.e., Chrome base app is 66MB and for me has another 25MB (90 total) of data that you cant move to the sd, prove:
View post on imgur.com
So in the 4GB you can get around 40-60 apps.
Also, I want to say this is much better than 2GB and i thank you for your job. 🙂
116 Guest(s)
Devices in use: Desktop (101), Phone (15)
Twotrains
alexanddercrb
tsmfallen
TwiceBT
Alpifer
NavyMeso
