[ RK3288 ROM ] ifive Air AOSP 5.1.1 custom root firmware (2015/05/20)
46
2015/06/27 - 23:34
Yes, please. Do a clean install of build v1.1 and install the BT fix.
miniplus
miniplus
Forum Posts: 13
47
2015/06/27 - 23:37
Okey perfect thank you very much! I'll try it tomorrow in the morning.
Thanks for the effort and help!!!
48
2015/06/28 - 13:10
Happy now with the build v1.1 battery stats 😉
v1.1_video.pngImage Enlargerv1.1_download.pngImage Enlargerakku_v1.1_deep_sleep_01.pngImage Enlargerv1.1_depp_sleep_02.pngImage Enlargerv1.1_depp_sleep_03.pngImage Enlargerv1.1_charging.pngImage Enlarger
StardustOne
49
2015/06/29 - 19:23
Netflix playback does not work with Android 5.1.1. Can a fix be provided for Netflix, please?
50
2015/06/29 - 19:41
Unfortunatly I cannot test Netflix. What is or is not exactly?
Maxdome works for me.
LP_v1.1_14.jpgImage EnlargerLP_v1.1_14a.jpgImage Enlarger
StardustOne
51
2015/06/29 - 20:51
Netflix starts fine, browsing the collection works too. But when trying to play anything on the tablet, nothing is played. Loading... and a red circle is shown.
I have posted on Freaktab and got one reply saying that some DRM is missing in the Android 5 SDK build. If this could be fixed, that would be really great.
http://freaktab.com/forum/tablet-support-android/ifive-tablets/506994-netflix-playback-on-tablet-not-working-anymore-with-android-lollipop-on-rk3288-deviceScreenshot_2015-06-29-20-46-26.pngImage Enlarger
52
2015/06/29 - 21:25
Hm, the German provider Maxdome works without any DRM or Root issues.
Can you pls disable "Use of AwesomePlayer" in developer options? Maybe you need to reboot.
53
2015/06/29 - 21:52
Test kernel for ifive Mini4: http://crewrktablets.arctablet.com/?wpfb_dl=2588
Change kernel and resource in folder rockdev/Image before flash.
Untestet ... so use on your own risk!
MiGHT.
Germany
Forum Posts: 67
Thanks Received: 13
54
2015/06/30 - 11:38
Thank you so much for your effort Oma, really appreciate it.
Few questions before testing:
1. how sure are you, that the kernel will boot?
2. what can i do if it fails, the ifive mini4 has no hardwarebuttons nor reset hole
3. should i flash an TWRP image prior flashing the kernel/lollipop or will the recovery partition be overwritten?
4. whats the worst thing that can happen?
5. how can i support you with development?
Finally again: thanks !!
55
2015/06/30 - 15:37
So, to start the tab into flash modus unplug USB cable, hold Power for 12 sec until screen goes black and plug USB cable. If this is not longer possible one need to open the tab and short NAND pins to start tab into mask-rom modus.
You need to do a clean install, incl. LowerFormat.
PMU is the same then in Air and flashing of the touch controller firmware is off. It could be that  you do not have screen or the boot-up process stops at the kernel logo. Enable sound on your PC to hear if there is action. In any case wait 5 minutes and try to get some logs - use this tool: http://forum.xda-developers.com/showthread.php?t=1944776
gaetanolip
Forum Posts: 28
56
2015/06/30 - 15:42
hi oma
why don't you build a rom for ifive mini 4
please
57
2015/06/30 - 15:46
The build in post #1 will also work on Mini4. What we do not have is a selinux kernel that boots LP.
Saikamur
58
2015/07/06 - 09:45
I have installed this great ROM on my iFive Air and it works pretty well. So far, I have found only two "issues":
- The screen sometimes goes crazy and starts detecting touches everywere. So far it has happened two times in two days. The first time it happened, it was fixed when I closed the running app (Strategy & Tactics). The second time (running the same app), I had to reboot the tablet to fix it. Also, this is a tablet that has just come back from the SAT because of a faulty screen, so I can't be sure if the cause is the app, the ROM, or the screen. I will keep testing to try to clearly identify the source.
- I can't charge the tablet while powered off. As soon as I plug the USB charger, the tablet starts. If I poweroff the tablet while plugged, it just restarts. With OMA v1.1 ROM I was able to charge it while powered off. I would like to do it, because it takes ages to fully charge the tablet when powered on.
It would be a pity to have to go back to OMA v1.1 just because of this issue, because the ROM is working great. 🙁
Anyway, thank you very much for your great work!
59
2015/07/06 - 17:45
Thank you for feedback!
We have two of this tabs and no issues with the touchscreen noticed so far.
As for the charge mode this is the so called always power on strategy. One can only power down the tab if no cable is plugged.
This is mainly driven by the new loader. I guess it can be changed by using a specific uboot.
But hey, I do not have any issue with that. I leave the tab on the charger over night and it is good for the next day. Charging time is about 5 hours (emty to full).
Btw. to charge the tab the kernel is booted anyway. The only difference is that it will reboot to give you screen on.
Recently the tab runs about 4 days without charging. I just put in on a few times to check my emails.
charge.pngImage Enlargeridle.pngImage Enlarger
Snorch
60
2015/07/11 - 13:36
Downloading right now!!! Also great work on your 4.4.4 ROM, is great except for some green lines and video distortion sometimes. I'm buying you a beer for your work!
107 Guest(s)
Devices in use: Desktop (100), Phone (7)
Twotrains
alexanddercrb
tsmfallen
TwiceBT
Alpifer
NavyMeso
