[ RK3288 ROM ] ifive Air AOSP 5.1.1 custom root firmware (2015/05/20)
jed57x
2015/05/29 - 14:32
Waiting for my TECLAST version ; Thanks for sharing OMA . That possibility must have a stable rom for P90HD.
pylly
2015/06/02 - 09:02
I have huge battery drain with this rom. Seems like process 'miscellaneous' is using all the battery.
Any idea how to fix this?
2015/06/02 - 16:36
There is a wrong setup of the Ricoh619 driver in the kernel. We try to understand the issue but due to the lack of sources this is all reverse-engineering and trial and error. But time will come ...
2015/06/02 - 16:39
Enr1988 said
I've tried, but the tablet don't boot after flash..
The kernel boots but you do not see anything due to a different framebuffer handling.
P1.pngImage Enlarger
2015/06/02 - 16:43
kallesone said
Hi oma,will you make a versión for pipo p9?
First test kernel boots on Pipo P9. However, it will take some time to make everything run.
kallesone
Forum Posts: 46
Thanks Received: 7
2015/06/02 - 21:38
thanks for your hard work.
tarm66
2015/06/06 - 20:34
Hi Oma pls put the Pipo P8 on your Android L list
Smile
fermin
2015/06/09 - 13:42
Hello. That logs you need my Ifive Mini 4 to modify the kernel? As I get them?
Thanks for the great work.
A greeting.
2015/06/15 - 19:59
Update post #1 with build v1.1.
Battery stats and headphone fixed now.
LP_v1.1_02.pngImage EnlargerLP_v1.1_04.pngImage Enlarger
Krash
gaetanolip
Forum Posts: 28
2015/06/16 - 16:55
hi
i have an ifive mini 4 too. Any chance to port the rom on it?
Krash
2015/06/17 - 03:21
Thanks for the update!
Does gyoscope and OTG work in 1.1?
2015/06/17 - 19:10
The tab does not have a gyroscope sensor. OTG works.
Ne77
2015/06/18 - 19:55
I have a mini 4 too.
How we install the lollipop to mini 4?
miniplus
Forum Posts: 13
2015/06/20 - 08:53
Oma!
One short question. Do you recommend installing v1 or 1.1? Because i need bluethooth and wor what i can ee, v1 has it and the only bug is the battery one. Is this a serious problem?
Thanks for the help!
Cheers
2015/06/20 - 11:02
The build is still in beta stadium. That means you can use this build only as a daily driver, when you usually don't use functionallity which is notiecd as not working.
112 Guest(s)
Devices in use: Desktop (110), Phone (2)
Twotrains
alexanddercrb
tsmfallen
TwiceBT
Alpifer
NavyMeso
