Gents,
Lollipop has landed on ifive Air
CrewRKTablets AOSP 5.1.1 build v1.1
update: BT fix (install via TWRP)
– stock recovery 5.0.0
– CrewRKTablets homebrew kernel jk #11 [v1.0]
– kernel #10 [v1.1]
– Reboot Menue
outdated:
- front & back cam fix (install zip via TWRP)
- kernel #29 for better audio experience (flash via AndroidTool)
- CrewRKTablets AOSP 5.1.1 build v1.0
not working: ./.
hints:
- Oma's farourite apps for LP (install via apk installer)
Special thanks to Rockchip !
– Oma -
Krash, admin, miniplusPer aspera ad astra, we rock the Tablets !
Yeah, currently working on this. The code for the rt5616 audio chip is very creapy.
Here is a orientation correction for the back cam (install via TWRP): http://crewrktablets.arctablet.com/?wpfb_dl=2537
Krash, miniplusPer aspera ad astra, we rock the Tablets !
The Android yes. But needs to build a kernel/dtb. Let me have a dmesg log.
Kernel #29 will give a better sound experience via tab speakers: http://crewrktablets.arctablet.com/?wpfb_dl=2539
If you'd like it extra loud, you can use Viper4AndroidFX: http://crewrktablets.arctablet.com/?wpfb_dl=2538
vk2r said
The Android yes. But needs to build a kernel/dtb. Let me have a dmesg log.- Oma -
How i do?
As suggested by Oma, you can use tools like: AIOlog - All in One Android Logger
Please make sure you extract the dmesg as soon as the tablet has booted.
2013/04/16
Hi Oma, happy to see Lp landed on rk3288..my question is if it's possible to port this on Pipo p1...there are also a fw for P1 based on lp 5.0.2.
maybe it can be used for kernel.. This is the link https://mega.co.nz/#!vk5HAZKS!RuiERho9I9GPovrVwcjKS4J7dvTxvfCPN6UvdmYDTTs
Original Chinese forumhttp://www.pipo.cn/bbs/forum.php?mod=viewthread&tid=13802&extra=page%3D1&mobile=2
Check it out: http://crewrktablets.arctablet.com/?wpfb_dl=2545
Just change kernel and resource in folder rockdev/Image before flash.
Enr1988, miniplusPer aspera ad astra, we rock the Tablets !
2013/04/16
Check it out: http://crewrktablets.arctablet.com/?wpfb_dl=2545Just change kernel and resource in folder rockdev/Image before flash.
I've tried, but the tablet don't boot after flash..
If I flash all fw 5.0.2 it works, but there is a bug that make it unusable,because after the screen turn off it won't turn on and need to force reboot with power button.
57 Guest(s)
Devices in use: Desktop (46), Phone (11)
cutierogue
