[ RK3288 ROM ] iFive Air AOSP 4.4.4 custom root firmware (2015/01/08)
2015/01/09 - 10:45
Gents,
This is our first AOSP 4.4.4 build for iFive Air ;-)
Build is at beta stage, so let us have much feedback!
Air by CrewRKTablets AOSP 4.4.4 build v1.0
– stock recovery 4.4.0
– CrewRKTablets recovery CWM 6.0.5.1
– CrewRKTablets recovery TWRP 2.8.3.0
kernel #44
– 4 GB internal storage
– init.d support
– Dateimanager HD (Root)
– Nova Launcher
Hints:
use Nova launcher and set animation/scroll to “faster than light” and
enable Entropy Fixer with value 256
– to prettify the build use
Xposed Framework > Starter Pack
– Oma -
CrewRKTablets-RK32-Air-AOSP-4.4.4-build-v1.0-08.01.2015.pngImage Enlarger
 v1.0_apps.jpgImage Enlarger
 v1.0_antutu_2.pngImage Enlarger
 v1.0_antutu_1.pngImage Enlarger
 v1.0_BT.pngImage Enlarger
 v1.0_video.jpgImage Enlarger
 v1.0_browser.jpgImage Enlarger
 v1.0_asphalt.jpgImage Enlarger
v1.0_cam.jpgImage Enlarger
 CWM_CrewRKTablets_v1.1_1-6.jpgImage Enlarger
 TWRP_CrewRKTablets_v2.1_3-6.jpgImage Enlarger
 TWRP_CrewRKTablets_v2.1_4-4.jpgImage Enlarger
 TWRP_CrewRKTablets_v2.1_5-2.jpgImage Enlarger
admin, Hekatombe
2015/01/09 - 12:17
Some tests with Exposed Modules.
v1.0_exposed.jpgImage Enlarger
 v1.0_exposed_2.pngImage Enlarger
 v1.0_exposed_3.pngImage Enlarger
TeutonJon78
Forum Posts: 26
2015/01/10 - 07:43
Wow, another rom -- that brings us to 4.
What's really the difference between the ROMs in the two groups?
There is the stock v1 and v2 line, which seems like multiwindow is the main difference.
Then there is the AOSP based line, which has OmniROM generic (which is almost pure AOSP) and a pure AOSP. Both of which have added apps, same as the stock line.
Which of the ROMs are you considering to be the active ones? Or are you going to keep them all around?
Thanks for all the work -- it's so nice to see a Chinese tablet with such support, even if it's not from the company itself. Once I can finally dive into them in 1.5 weeks, it will be nice to have all these options.
iFive Air (32GB) - XDA Discussion -- (including my iFive Air Nexus ROMs based on stock)
MiGHT.
Germany
Forum Posts: 67
Thanks Received: 13
2015/01/30 - 10:52
Hi Oma,
is it possible to get an AOSP Build for iFive mini 4?
I would love to have an clean android without chinese crap in it.
Thanks in advance.
2015/01/30 - 11:03
It should work also on Mini 4.
Change kernel/resource in folder rockdev/Images before flash: http://crewrktablets.arctablet.com/?wpfb_dl=2158
miniplus
Forum Posts: 13
2015/09/12 - 17:43
OMA!
Please, I have a question. Do you think this is the best ROM above the rest (is this one better than the lollipop version, in terms of smoothness?)
How is the overall performance, as well as the UI feel? The 5.1.1 version was a bit laggy sometimes, and GPU's performance harshly fell since i updated it.
Thanks.
miniplus
Forum Posts: 13
2015/09/18 - 21:37
And in the end...
I installed it. I have to say I don't regret for doing it. Its the fastest one I've ever tried. I got more than 48000 points in Antutu Benchmark, and the smoothness is great.
WiFi, Bluetooth, speakers... All working at the moment!
Big thanks to the developers for this ROM.
2015/09/19 - 13:09
Great to hear that. Thank your for feedback!
33Brenx
2016/03/21 - 18:00
Hi @Oma7144 can you do a custom rom for this device? http://www.bluewave-global.com/wave_8_hd.php#frame4 here in the Philippines we are so many users of this tablet now. Because our telecom provider reward us as their loyal customer to have this. Unfortunately this tablet have so frustrating issue like quick draining battery life, over heating and etc. If you can make a custom rom for this device then probably this site would be first to visit of many growing users of Wave 8 HD+
I have installed TWRP recovery with theme successfully using your tools. And thanks for that
Hoping my request will be grant
tnx and advance
2016/04/02 - 13:54
The issues you decriped sounds like a hardware/kernel issue. This could not be corrected by a custom rom. Make your provider aware of your huge problems. This is the only way to get a proper bugfix update from the manufacturer.
85 Guest(s)
Devices in use: Desktop (56), Phone (28), Tablet (1)
Kaka88
Donalbert
halum
BlackCero044
BlackCero04
taylordahmer
