Gents,
This is a Multi-Window build for iFive Air
– stock recovery 4.4.0
– CrewRKTablets recovery CWM 6.0.5.1
– CrewRKTablets recovery TWRP 2.8.3.0
– kernel #44
– 4 GB internal storage
– multi-window 2.0
– init.d support
– Dateimanager HD (Root)
– Nova Launcher
not working: camera > solved build v2.1
some corrections on UIÂ (install zip via TWRP/CWM)
How multi-window works.
Hints:
– to enable multi-user use the Xposed module Multi UsersÂ
– Oma -
turist4, SnorchPer aspera ad astra, we rock the Tablets !
Fine. Thank you for feedback!
2014/12/12
(Recreating post as best I can)
I was doing my ROM analysis of all the different Air ROMs and I think I came across some bugs for this one. Based on the differences, it seems to me that the 2.x line is from another device and patched for the Air. Is this correct? what's the original device?
- missing build.prop entries
ro.rk.hdmi=false
ro.rk.vibrator=true
ro.rk.gps=false
ro.rk.3g=false
ro.rk.autobrightness=false
- potentially wrong build.prop added
ro.rk.btchip=broadcom.bplus (not sure if we have the Broadcom chip or not)
- manifest.xml seems to be a generic android one (not sure if it matters)
- /bin - added GPS files which aren't needed
- /etc/bluetooth/bt_stack.conf enabled GPS
- /etc/firmware/nvram_AP6335.txt was downgraded with parameter changes
- /etc/firmware/nvram_AP6476.txt had parameter changes
- /etc/permissions had added files for GPS features and removed the usb.host and usb.accessory permissions (which might disable OTG and 3g modem use, I'm not really sure)
The following users say thank you to TeutonJon78 for this useful post:
adminiFive Air (32GB) - XDA Discussion -- (including my iFive Air Nexus ROMs based on stock)
Currently Online: andre92
72 Guest(s)
Devices in use: Desktop (61), Phone (12)
andre92
firmwarefile
mongol
country822
vovandolgan
kenjakenjavitis
