[ RK3288 ROM ] iFive Air Android 4.4.4 custom root firmware (2014/11/18)
Thanks Received: 1383
2014/11/21 - 16:03
Gents,
This is my first build for iFive Air ;-)
Build is based on stock v1.1.0, dated 14. Nov 2014 and kernel #44 preempt 14. Nov 2014.
Air by Oma build v1.0
update 02.01.2015:
- fix Chrome red frame issue
- multi-user enabled
- some minor corrections
- CWM 6.0.5.1 included
- TWRP 2.8.3.0 inlcuded
Air by Oma build v1.1
– stock recovery 4.4.0
– CrewRKTablets recovery CWM 6.0.5.1 [v1.1]
– CrewRKTablets recovery TWRP 2.8.3.0 [v1.1]
– kernel #44
– 4 GB internal storage
– init.d support
– multi-user [v1.1]
– Dateimanager HD (Root)
– Nova Launcher
Enable developer options - install zip via TWRP/CWM
Hints:
– to prettify the build use
Xposed Framework > Starter Pack
– Oma -
v1.0_03-1.pngImage Enlarger
 v1.0_01.jpgImage Enlarger
 v1.0_02.jpgImage Enlarger
 v1.0_05.pngImage Enlarger
admin, Krash, turist4, TeutonJon78, qasdff15
turist4
Forum Posts: 37
2014/12/12 - 20:50
thanks i did use your work and all works perfect!
I would like to ask if you could advice:
-how to delete the Nova (as the launcher included in the pack is not the pro version
-as it wouldn't install the pro if earlier is not deleted the one you included
I try to delete with Titanium backup but didnt find it...
TeutonJon78
Forum Posts: 26
2014/12/13 - 00:02
I'm curious as to why there is still the split between the internal memory and the emulated SD card, rather than doing it the modern way where it's all one giant partition for both.
Or, is there an easy to way to change the size between the two partitions if that isn't possible?
iFive Air (32GB) - XDA Discussion -- (including my iFive Air Nexus ROMs based on stock)
2014/12/13 - 06:43
You are right, Rockchip still not use the latest google standard. The footprint of that is in the framework, so no easy way to switch. However, it doesn't really matter.
If you'd like to run a build with an unified internal storage just check out our first OmniRom build: http://www.arctablet.com/blog/forum/rk3288-entwicklung-und-customroms-development-and-croms/rk3288-rom-teclast-p90hd-omnirom-4-4-4-custom-root-firmware-20141206/
Make sure you change Air kernel/resource in folder rockdev/Images.
2014/12/13 - 06:49
Fine. Thank you for feedback!
Use the included Datei Manager HD. Goto settings and enable Root and /system rw. Navigate to /system/apps and delete Nova.
turist4
Forum Posts: 37
2014/12/13 - 07:06
thanks for description , ill do it right now:-)
and i can report all fine, thanks
turist4
Forum Posts: 37
2014/12/13 - 08:15
do you have a CWM  link available for download for our RK3288? Please?
TeutonJon78
Forum Posts: 26
2014/12/13 - 08:57
Wow, awesome.
So that build of omnirom will work for this the iFive Air as well? It would be great to make sure to have a clean rom as the base.
turist4
Forum Posts: 37
2014/12/13 - 11:07
loaded and i can report is 4gb and the rest so it will be not unified as far i can see
turist4
Forum Posts: 37
2014/12/13 - 11:40
but if you load the latest firmware on the top of the post then it does the trick :-)
(stupid user...i did download the orlder one first and there it dosnt work haha)
All fine here ill check and report
2014/12/14 - 10:06
Yes, works also on iFive Air. Just change kernel & resource in folder rockdev/Images before flash.
turist4
Forum Posts: 37
2014/12/17 - 21:56
Is there a way to add or fix camera? As this rom has no working cam
TeutonJon78
Forum Posts: 26
2014/12/18 - 05:54
Are you referring to the right ROM?
This is one is based on stock and should probably have everything working (I haven't tried it yet though).
There is the OmniROM one which has the known issue of now hwcomposer and no cameras yet.
TeutonJon78
Forum Posts: 26
2014/12/24 - 06:50
Oma, I had a question for you. I was looking at making my own ROM, and I was curious about a few things in the rom.
kernel.img and resource.img are the same as the factory images, however, boot, misc, and recovery are different. I was curious as to where you got them, or what the changes are.
In the parameters files, I wasn't sure why the recovery keys were changed from #RECOVER_KEY: 1,1,0,20,0 to #RECOVER_KEY: 1,1,0,17,0. Although, I assume the # comments out the line, but not sure.
Thanks.
2015/01/04 - 09:38
Update post #1 with build v1.1.
update 02.01.2015:
– multi-user enabled
– some minor corrections
– TWRP 2.8.3.0 inlcuded
Oma-RK32-Air-build-v1.1-02.01.2015.pngImage Enlarger
 v1.1_apps_1.jpgImage Enlarger
 v1.1_lockscreen.jpgImage Enlarger
 v1.1_antutu_1.pngImage Enlarger
 TWRP_CrewRKTablets_v2.1_3.jpgImage Enlarger
 TWRP_CrewRKTablets_v2.1_4.jpgImage Enlarger
TeutonJon78
71 Guest(s)
Devices in use: Desktop (59), Phone (12)
alertscam
aolmail7448
Arc123456789
forty42
samih
macsierra2
