I know that. Our miracle is that boot, kernel and system are identical.
Very last try: http://crewrktablets.arctablet.com/?wpfb_dl=2969
2016/08/14
I know that. Our miracle is that boot, kernel and system are identical.Very last try: http://crewrktablets.arctablet.com/?wpfb_dl=2969
Bootloop
2014/10/11
Hi, I leave the link for a copy that a colleague made of your device. I tried to install it but it does not boot. Have if you
lend a hand and look if the copy is well done. Thank you @Oma7144
Edit: Hello colleagues thanks to some tests, I can say that using this boot.img to replace Oma7144, we will have the
bluetooth operating. Tested on my Pad971. Thanks to Oma7144 for her great work.
Link boot.img
The following users say thank you to Perdigon55 for this useful post:
There is another kernel in that boot.img. After flashing boot.img is the running kernel #74 preempt 25 Feb 2015 now?
2014/10/11
There is another kernel in that boot.img. After flashing boot.img is the running kernel #74 preempt 25 Feb 2015 now?- Oma -
Hi Oma7144 I understand why you say that in the boot.img is included another kernel that is installed together?
Just took the rom and I replaced the boot.img and the famous bluetooth of the commercialized in Spain.
The teacher is you, sorry to use google translator.
Could you include what boo.img has in CM 6.0.1 to work on that too? Some patch like you did for the
camera, but for bluetooth?
Thank you
Edit:
Hello Oma7144 I just looked at the information on the tablet and put
kernel candy @ candy-pc # 74 Thu Feb 25 10:40:11 CST 2016
Ok, build is post #1 comes with kernel #75 preempt 7 Apr 2016.
Here is kernel #74 preempt 25 Feb 2016: http://crewrktablets.arctablet.com/?wpfb_dl=2978
So, for tabs having issues with Bluetooth, just use kernel #74. One can flash it separately (see pic).
2014/10/11
Ok, build is post #1 comes with kernel #75 preempt 7 Apr 2016.Here is kernel #74 preempt 25 Feb 2016: http://crewrktablets.arctablet.com/?wpfb_dl=2978
Hello Oma7144 I installed the rom of post # 1 replacing those two files kernel and resourse and the
bluetooth a works also the first one. Thank you so much.
Great to hear that!
2012/03/25
Nice! I saw this boot in htc forum yesterday and i just replace boot.img from oma rom to this one. My BT come back on my french pad971 !!!
I'll post later a patch for widevine for oma LP.
Samsung Galaxy Note 10.1 2014 - 5.1.1
Haier Pad971 5.1.1
Asus Memopad10 ME102A 4.4.2
Alcatel Idol3 6.0.1
Moto G2013 7.0.0
Moto G3 6.0.1
2012/03/25
Hello
Here is files to enable widevine in Oma LP5.1.1 :https://drive.google.com/file/d/0B57Q-f4sogZ_bTNEamdfTGtrZXc/view?usp=sharing
You have to make some place in system partition (ex: erase apps like gmail or hangout) because there is not enought space.
Then copy files from my zip in system folder
Haier Pad971 5.1.1
Alcatel Idol3 6.0.1
Moto G2013 7.0.0
Moto G3 6.0.1
68 Guest(s)
2 Guest(s)
Devices in use: Desktop (63), Phone (5)
