[ RK3288 ROM ] Haier Pad 971 LP 5.1.1 custom root firmware (2016/08/04)
Perdigon55
Forum Posts: 17
31
2016/08/27 - 17:00
Hi I have installed and still the same. I'll have to reinstall the firmware everything and then apply new fix? Thank You
32
2016/08/27 - 17:35
No, just let me have the logs.
josvic
Forum Posts: 11
33
2016/08/28 - 23:28
I applied both fixes, but they still don't work. I send you the logs by PM. Thanks.
34
2016/08/30 - 17:29
I am of the opinion that the kernel does not contain the right driver. In other words we might have more than one hardware revision in the field. Maybe somebody else could provide other firmware else than kernel #75.
For the time beeing you should consider to use the MM build.
portlins
35
2016/09/07 - 12:48
Hello everyone.
I am very interested in this tablelle HAIER PAD 971 .
Is it quality ?
Can I play with ?
Is it difficult to rooter ?
I'm new to this forum .
How do I install patches for bluetooth
thank you in advance
Stéf
murigny64
Forum Posts: 48
36
2016/09/25 - 12:33
I used a dump from a French user. Maybe there are differences.
What is the connection issue exactly?
Hello Oma7144.
I have a PAD971 and i can't flash any rom, strange.
My dump is corrupted, can you share this french dump?
thanks
Samsung Galaxy Note 10.1 2014 - 5.1.1
Haier Pad971 5.1.1
Asus Memopad10 ME102A 4.4.2
Alcatel Idol3 6.0.1
Moto G2013 7.0.0
Moto G3 6.0.1
37
2016/10/02 - 10:39
I do not store all this stuff. However, the build in poist #1 is based on the dump.
murigny64
Forum Posts: 48
38
2016/10/05 - 20:42
Hello Oma. Flash issue solved, i have to wait 5mins between 2 flashs (?!?)
Everything work, LP, MM, CM13 but allways the same issue for me: no BT
One thing: i can unpack my dumped boot.img (ramdisk and kernel) but i can't do the same with your boot.img.
I think my original LP firmware is not structured as yours. Perhaps it's that causing BT issue.
EDIT: after opening my tab, Wifi/BT chipset is AP6212, not AP6330 !
Haier Pad971 5.1.1
Alcatel Idol3 6.0.1
Moto G2013 7.0.0
Moto G3 6.0.1
39
2016/10/08 - 10:04
Yes, we have seen it in post #26. And all the AP6212 stuff gets loaded with no success. That's why I am guessing there are some dirty workarounds in the genuine kernel for your hardware revision. We need to find that kernel.
murigny64
Forum Posts: 48
40
2016/10/08 - 12:30
I upload my dumped stuff here:
https://drive.google.com/drive/folders/0B4fJ6tTNcqItelhwN2ozcW5wS1E?usp=sharing
thanks
Haier Pad971 5.1.1
Alcatel Idol3 6.0.1
Moto G2013 7.0.0
Moto G3 6.0.1
41
2016/10/08 - 14:20
This does contain the same kernel #75.
42
2016/10/09 - 12:28
Do you have a dump of the system.img, too? Maybe I can find something ...
murigny64
Forum Posts: 48
43
2016/10/10 - 06:59
Yes, you can look again in my google drive folder.
Haier Pad971 5.1.1
Alcatel Idol3 6.0.1
Moto G2013 7.0.0
Moto G3 6.0.1
44
2016/10/10 - 20:51
Wow ... it's software.
Used build:
ro.build.display.id=Haier.Pad971.GM20160420-1106.SV1.LMY47V release-keys
ro.product.locale.language=fr
ro.product.locale.region=FR
ro.device.type=Pad971_ap6330_Fr
Your dump:
ro.build.display.id=Haier.Pad971.GM20160203-0037.SV1.LMY47V release-keys
ro.product.locale.language=es
ro.product.locale.region=ES
ro.device.type=Pad971_ap6212
Pls try this: http://crewrktablets.arctablet.com/?wpfb_dl=2968
josvic
Forum Posts: 11
45
2016/10/10 - 21:36
Used build:
Your dump:
Not. Bluetooth not work...
66 Guest(s)
2 Guest(s)
Devices in use: Desktop (60), Phone (6)
