Hopefully no hardware issue. Pls install the build again, incl. LowerFormat.
josvic said
After two seconds, it turns off Â
Can I have a dmesg and a logcat log from this situation? To do the logs one can simply use SysLog app (see Play Store). Reboot the tab, try to enable BT a few times and then do the logs.
If you'd like you can also try the CM13 build: http://www.arctablet.com/blog/forum/rk3288-entwicklung-und-customroms-development-and-croms/rk3288-rom-ifive-air-cm13-6-0-1-custom-root-firmware-20160202/page-9/?lang=fr#p58677
2016/08/14
- Oma -Â Â
Los done. Pm.
Thx
I don't see the AP6330 chip running. Is wifi on?
Pls enable wifi first and then do the logs again.
-Oma -
josvicPer aspera ad astra, we rock the Tablets !
You need to also tick parameter.
As we are having still server issues and the PM functionallity is down, can you pls attach the logs here?
Ok, got the log.
<4>[Â Â 18.255731] Current WiFi chip is AP6330.
<4>[ 19.390934] dhd_conf_set_fw_name_by_chip: firmware_path=/system/etc/firmware/fw_bcm43438a0.bin,nv_path=/system/etc/firmware/nvram_ap6212.txt
<4>[ 19.390946] Final fw_path=/system/etc/firmware/fw_bcm43438a0.bin
<4>[ 19.390953] Final nv_path=/system/etc/firmware/nvram_ap6212.txt
<4>[ 19.390960] Final conf_path=/system/etc/firmware/config.txt
<4>[ 19.672036] NVRAM version: AP6212_NVRAM_V1.0_20140603
The firmware gets loaded for the AP6330 chip doesn't make sense.
Pls install this via TWRP: http://crewrktablets.arctablet.com/?wpfb_dl=2955
Can I have the logs, pls?
2014/10/11
Can I have the logs, pls?- Oma -Â Â
Hello here you have them log After applying fix https://www.mediafire.com/folder/h2ota8hcbzmdo/Log_después_de_aplicar_fix
Log before applying fix https://www.mediafire.com/folder/utvyb16ul1i81/Log_antes_del_fix  Thank You.
Download again and try: http://crewrktablets.arctablet.com/?wpfb_dl=2955
61 Guest(s)
Devices in use: Desktop (54), Phone (7)
