[ RK3288 ROM ] Haier Pad 971 LP 5.1.1 custom root firmware (2016/08/04)
2016/08/05 - 19:11
Gents,
This is a build based on Haier Pad 971 stock ;-)
Oma HP LP 5.1.1 build v1.0
– stock recovery 5.0.0
– kernel #75 preempt 7 Apr 2016.
– Reboot Menue
– Soft Volume Buttons
If there are issues with Bluetooth pls use kernel #74 preempt 25 Feb 2016
hints:
– Oma's favourite apps for LP
– Oma -
084.jpgImage EnlargerHaierPad_01.pngImage EnlargerHaierPad_02.jpgImage EnlargerHaierPad_03.jpgImage EnlargerHaierPad_08-1.pngImage EnlargerHaierPad_06-1.pngImage EnlargerHaierPad_04.pngImage EnlargerHaierPad_05.pngImage EnlargerHaierPad_07.jpgImage EnlargerHaierPad_10.jpgImage EnlargerHaierPad_09.jpgImage EnlargerHaierPad_11.jpgImage EnlargerHaierPad_12.jpgImage Enlarger
gogo17
Perdigon55
Forum Posts: 17
2016/08/05 - 21:25
Simply fantastic, everything works and the sound problem is under some games and viewing multimedia content on the app previously ragged. If you have made a sound touch buttons. Fantastic, thank you very much and great happiness for me.
Donation for his effort. Thank you
Edit: The TWRP recovery CrewRKTablets 1536x2048 v3.0 is not installed. I could install this TWRP_1536x2048_CrewRKTablets_v2.2 and works perfectly.
2016/08/06 - 13:11
Hm, TWRP works here. Anyway, thanks a whole lot for your feedback and the donation!
hotte1983
Forum Posts: 20
2016/08/06 - 14:57
one thing is to mentionFrown, xposed framwork can not install on this firmware after the installation ,all apps new loading and after the loading i become a error message "android stress test has stopped"and Tablet not started.
I 3 try to install after the clean install your rom
framework/sdk22/arm/xposed-v86-sdk22-arm.zip
with twrp ,always with the same result "android stress test has stopped".
all other works perfectly thank you very much oma for your great workLaugh
2016/08/06 - 16:24
Well, this is a known issue on all rockchip LP builds.
Perdigon55
Forum Posts: 17
2016/08/06 - 16:34
Hi, sorry it is the google translator, now if V3 was installed TWRP leaving clicked parameter, as indicated in the instructions. All perfect.
2016/08/06 - 17:20
Fine. Thanks for feedback!
josvic
Forum Posts: 11
2016/08/14 - 22:20
Hola, la ROM genial, pero no funciona el bluetooth, que pena, por que la uso con una diana de dardos electronica por bluetooth y ahora no voy a poder... ÂżPodras arreglarlo? ÂżEs imposible?
Google traslation
Hello, the great ROM , but does not work bluetooth, what a pity , because the use electrĂłnica Dart board connected via Bluetooth, and now I will not be able to ... can you fix it? It is impossible?
Thx
2016/08/15 - 18:30
What was on the tab before? Does it work before?
josvic
josvic
Forum Posts: 11
2016/08/15 - 19:13
Everything worked before. It had the original firmware.
2016/08/15 - 19:54
KK or LP?
josvic
Forum Posts: 11
2016/08/15 - 21:05
KK or LP?
LP. Spanish version.
2016/08/15 - 21:10
I used a dump from a French user. Maybe there are differences.
What is the connection issue exactly?
josvic
Forum Posts: 11
2016/08/15 - 22:49
When I activate the bluetooth, it shows the following message:
Activating bluetooth
But after two seconds, it switches off and disconnects.
2016/08/16 - 16:14
So, BT isn't working at all?
For me it works fine here. Can somebody else pls give feedback?
HaierPad_08-2.pngImage Enlarger
Currently Online: skydiver4ever
19 Guest(s)
Devices in use: Desktop (20)
cutierogue
