Pipo P1 stock firmware
PrEzi
Forum Posts: 57
61
2014/08/04 - 08:52
Pipo P1 WiFi/3G RileyROM 1.2 :
This ROM is based on yet another Pipo firmware update, dated 7.31.14. I have no idea what has changed.
This ROM is:
Rooted
Debloated
English as default language
init.d support added
Busybox commands added
Google Play Store fixes added
Reboot app by Petrus
Your choice of 2, 6, 12gb user app space (select the parameter file you want to flash).
Download :
http://www.freaktab.com/showthread.php?15735-Pipo-P1-RileyROM-1-2-(RK3288)
EDIT : It seems that Riley has messed up the other Parameter files... so... either use the default one (with 2GB user space) or calculate the Parameter file by yourself if you want to have a custom partition layout.
EDIT2 : found the error -- it is the starting point po userdata and user partitions. 2GB Version is ok (the default one). For the sake of others -- I am also posting just the last lines to replace :
Correct sizes / starting points :
4GB :
0x00800000@0x00194000(userdata),-@0x00994000(user)
6GB :
0x00C00000@0x00194000(userdata),-@0x00D94000(user)
The starting point of userdata is always 0x00194000 and not 0x00C94000 (1.2 6GB Param) or 0x01894000 (1.2 12GB Param).
You can use the Param Files from 1.1 or post a reply and I will post them here... (or calculate them by yourself -- knowing the starting point, size of userdata -- you can calculate the user partition by yourself.
PrEzi
Forum Posts: 57
62
2014/08/04 - 17:50
TIP from Riley - to smootth the WiFi refresh rate / icon -- manually edit build.prop and change the wifi supplicant scan interval to 150 from 15.
The Parameter files from RileyROM 1.1 seem to work fine with 1.2 Version... I'll try to find the difference and post the 4GB Version which I was using.
UPDATE (again ;) ) : Riley posted the updated Param files (untested by me - I have calculated the params by myself myself / cross checked with 1.1 and updated files posted below - they match and should be fine for all, however I take no responsibility for bricked devices) :
https://docs.google.com/file/d/0ByxbjJg99RBrNTEyelQzbnFnT0E/edit
PrEzi
Forum Posts: 57
63
2014/08/04 - 21:31
With the new ROM WLAN throughput has increased MASSIVELY -- with old builds I've had 7-7.5 Mbps download TOPS... now with the new build -- 33 - 38 Mbps (better then most mobile devices I have tested with WiFi speedtest).
Unfortunately the sound is still too quiet (workaround via ViperFX) but at least they have fixed one major reported issue.
Thumbs up !!
Don123
64
2014/08/04 - 21:42
Thumbs up !!
gibts einen link zu dem rom?
Kannst du beschreiben, wie genau man die ROM aufs P1 bekommt? (evtl. Screenshots?)
PrEzi
Forum Posts: 57
65
2014/08/04 - 22:03
Post Nr 61 -- RileyROM 1.2  und Post 62 -- korrigierte Parameter Dateien.
Genaue Beschreibung findest du auch dort unter den 61 Link.
Womit ich am meisten Probleme hatte waren die Treiber unter Win8.1 zu installieren -- wenn du auch Win8.1 hast - such nach meinem Workaround -- auch hier auf Seite 3 denke ich mal. Lädt dir beide Dateien runter - ROM Zip Paket und die korrigierte Param1.2 Datei und ersetze einfach die Dateis im RileyROM Verzeichnis.
BOZ77
Forum Posts: 15
66
2014/08/05 - 18:29
HELLO TO ALL I just received my pipo p1 and already a lot of problem, I try all rom available and nothing changes.
problem: application stopped to work. and reboot all the time
else if it is a problem or if you find the solution thank you shared
PrEzi
Forum Posts: 57
67
2014/08/05 - 22:40
No problems on my side with the stability nor any apps that are stopping to work or reboots.
You need to provide more specific informatons -- as many as possible... Which version of tablet ? 3g ? wifi ?
Which ROMs have you tried ? which Parameter files ? Followed the flashing instructions EXACTLY as described with Erasing IDB ?? Rooted or not ? What apps stop working ? with which error messages ? What have you "customized" by yourself ?  Do you know how to provide logcats ? If so - please upload to a sharing site and post link here.
BOZ77
Forum Posts: 15
PrEzi
Forum Posts: 57
69
2014/08/06 - 11:31
RileyROM 1.3 -- Basiert auf dem ROM von PIPO der von 4.08.2014 ist.
Changelog unbekannt aber laut Riley soll GPS einwandfrei funzen.
Download für WiFi und 3G Version :
http://www.freaktab.com/showthread.php?15835-Pipo-P1-RileyROM-1-3-(RK3288)&p=212330#post212330
BOZ77
Forum Posts: 15
70
2014/08/06 - 22:31
I also have my second tablet pipo p1 which heats much right side you have it? then reboot during games.
I ordered 2 pipo m9pro (both on the problem)
pui I ordered 2 pipop1 (and still problem)
I do not recommend the store on aliexpress eternal team sends in very longt ups, lots of fresh returned to the tablet that is not controlled, I am disgusted
PrEzi
Forum Posts: 57
71
2014/08/06 - 23:38
I gets warm, yes.... but I was playing several demanding games (e.g. Batman) for an hour or two non-stop and it never rebooted.
Might be a hardware problem on your side.
PrEzi
Forum Posts: 57
72
2014/08/11 - 23:41
Oma provided a custom ROM for our Tablets. Also a mod-pack for the P1 !
Download P4 ROM + P1 Kernel and Resources :
http://crewrktablets.arctablet.com/?p=3882
I haven't tested it yet.
Oma - maybe it would make sense to open up a new Thread for all the non-Stock // modded ROMs for the P1 ?
What do you think ?
73
2014/08/12 - 16:03
Why not.
Can you run this benchmark for me on your P1 and post a screenshot of the result? https://play.google.com/store/apps/details?id=com.a1dev.sdbench&hl=de
Thank you in anticipation!
PrEzi
Forum Posts: 57
74
2014/08/14 - 19:49
Sorry dass ich erst so spät antworte.
Die Ergebnissen von A1 SD Bench :
Long Benchmark, Internal SD Card 24,572MB Cached read
Read : 57,59 MB/s
Write : 17,84 MB/s
Kekskruemel
75
2014/08/14 - 20:07
my Moga Pro Bluetooth controller only works ~30 seconds. He is still paired and if i disable bluetooth, Android enable bluetooth by itself.
Controller is working fine on another device.
Problem exist with original pipo firmware, Riley 1.3 and P4 ROM + P1 Kernel and Resources :
greetings
50 Guest(s)
Devices in use: Desktop (44), Phone (6)
hoholms
rammaiden
iongeorge411@gmail.com
legrandhommer
mindra
xstouf
